LH /VL Difs Part 2
31 replies to this topic
#1 _rorym_
Posted 07 October 2006 - 11:12 AM
Distance from BUF to BUF:
LH: 1435 MM
VL: 1526 MM
VN: 1564 MM
From Chopper.
I spent all morning at 3 wreckers...here is what I found.
I got 1450 on 2 LH diffs I just measured.,One was a Sunbird UC with Salisbury, the other banjo.
VL drum or disc 1540..close enough
Here is the interesting bit
Pintara/R31 Skyline B/W diff housing with rear cable handbrake discs is 1460mm
Comes with Panhard rod fitting as well.Bare with no brakes on it the housing measures 1335mm, the LH one is 1325mm. Iam guessing fit 28 spline HQ pattern axles and drill some blank rear discs or the ones that are there and away you go after welding on the suspension brackets.
I need to confirm that the centre is the same size and fit as a VL so I can just bolt in a full spool with the axles.
The wrecker said $150 complete.
He also says he sells them to the sprint car guys here running 600HP and they fit a full spool with 28 spline axles and no one has ever broken one.
I am in if that is the case.
Comments?
#2 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 07 October 2006 - 11:15 AM
Don't know about the centers themselves but ALOT of vl owners run Pintara/R31 diff gears in the commodores as lots of R31/Pintara came with 4.11's
This is very interesting as Pintara/R31 diffs are very easy to get hold of and lots of them a rear disc already aswell..
Let us know how the research goes Rory
#3 _LHoon_
_LHoon_
Posted 07 October 2006 - 11:31 AM
They're all rear disc (R31).
Yep, Skyline is 28 spline. Don't get Pintara though - they're 25 spline.
I think they're 2 pinion though... but if you're running a spool that won't matter at all. They're the same centre as VL.
I couldn't buy blank skyline rotors - I don't think they sell them. I just drilled new holes, but with one of the 4 holes slotted. The diff shop was fine with that.
The rear brakes on the skyline diff are awesome. The handbrake works directly on the disc brakes, rather than having a small drum system like the VL.
I've done a fair bit of research into these when I was converting my LC to skyline borgwarner. What else can I tell you....
Your plan to use HQ axles is an interesting one, and something I hadn't thought of. I want to change my diff to HQ stud pattern now!! I will look into axle lengths now! Thanks!!
PS. There are 9 second VLs still using BW diffs, with transbrakes and never have any problems with the strength. Just get billet axles and full spool if you are concerned. I have a transbrake in my LC with 450hp and don't plan on changing to 9 inch. I think it should hold up fine.
Edited by LHoon, 07 October 2006 - 11:34 AM.
#4 _rorym_
Posted 07 October 2006 - 11:44 AM
I think HQ because there are more wheels available and it is an L34 Replica anyway.
Awesome guys!
I reckon the brake cables are even long enough to get to the Torana junction.
This is a HUGE win!!
Funny thing..one of the wreckers said an auto diff was $150 and a manual diff was $395.??? No idea why..maybe the manuals were all LSD.
The Pintara diffs are exactly the same so it doesnt matter if I get either as the axles and centre all have to be changed.
Edited by rorym, 07 October 2006 - 11:46 AM.
#5 _MRNOS_
_MRNOS_
Posted 07 October 2006 - 12:24 PM
Rory my engine guy can get blank disc's drilled to any pattern down here
#6 _CHOPPER_
Posted 07 October 2006 - 03:30 PM
HQ V8 Salisbury axles I'm sure have 23 splines. I will be removing a pair at some stage, so I can check if you can't.
#7 _rorym_
Posted 07 October 2006 - 03:47 PM
Thet will be too long and I will need to respline them anyway Chop, so I might go billet axles..Moser or something.
#8 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 07 October 2006 - 04:18 PM
99% sure they are 28 chop
#9 _MRNOS_
_MRNOS_
Posted 07 October 2006 - 04:19 PM
Yep got a pair here, 28 spline
#10 _CHOPPER_
Posted 07 October 2006 - 07:23 PM
I was just going off what I was told many years ago.
#11 _LHoon_
_LHoon_
Posted 08 October 2006 - 09:40 AM
No, manuals were not all LSD. The 'Silhouette' and GTS models had factory fitted LSD. It was probably an upgrade option as well, but most are open wheelers.
The manual version has 3.7:1 ratio, whereas the automatic version has 3.9:1. (You might want to check that I have them around the right way - as I may have them confused). But this still doesn't seem to worthy of charging $395!!! No idea why they want that much. I bought my R31 skyline diff complete with the disc brakes, centre and axles for about $175. I bought the tailshaft as well for the yoke/flange, the handbrake and handbrake cable.
#12 dattoman
Posted 08 October 2006 - 07:12 PM
Pintara auto is 4.11 and 23 spline
I have one in the shed
I will be shoving it in once of the dattos
#13 _LX8VD69_
_LX8VD69_
Posted 08 October 2006 - 07:20 PM
just out of curiosity isnt there any way of toughen up a salisbury out of a poo c?
#14 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 08 October 2006 - 07:41 PM
Rory and MRNOS, another option could be an XF Fud. I am pretty sure that they have a watts linkage instead of panhard, and you know how many XF's there are lying around!
#15 Peter UC
Peter UC
  • 771 posts
Posted 09 October 2006 - 02:42 PM
And XFs have vented rear disks
#16 _CHOPPER_
Posted 09 October 2006 - 06:06 PM
XE/XF only have 2 pinion centres and 25 spline axles. Ford went to 28 spline around the EL model.
#17 _rorym_
Posted 09 October 2006 - 06:42 PM
The width would be a killer...The Nissan attraction is it is within the right width...no need to cut it..just add the suspension pickup points....cheeep!!
Edited by rorym, 09 October 2006 - 06:42 PM.
#18 _rorym_
Posted 12 October 2006 - 01:13 PM
For $150 I will get the skyline axles and just redrill them for the moment. All reports are they stand up no worries.
#19 _rorym_
Posted 12 October 2006 - 04:21 PM
OK,
Scored a complete Skyline R31 diff /axles/brakes/cables and all for $100.
First quote is..Into jig, weld on suspension pickups. $330 Weld up and redrill axles (28 spline) and discs $190.
$600 for a set up VL style diff ready for a full spool centre. Skyline also comes with a 3.7 crown wheel.
Bonus! :spoton:
#20 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 12 October 2006 - 06:41 PM
So much cheaper without shortening hey!
Will be looking at this when it comes to diff change time...
Keep us posted Rory
#21 _rorym_
Posted 22 October 2006 - 09:35 AM
Right..Did a spot on with the Skyline diff and it is 1468mm between bolt up faces. If someone can do an accurate measure on a LH banjo..flat face drum to drum we will have an accurate picture but if it is 1440 as Chopper says or 1450 like I measured it is bugger all. At worst its 12mm/1/2" each side or 9mm eachside. Easy! :clap:
#22 ls2lxhatch
Posted 22 October 2006 - 12:19 PM
I was told by Phil Taverna Chassis that the standard LX torana diff is 56.5 inches or 1435mm. I measured by original LX diff as 1438mm and my 9 inch is also 1438mm.
A 1468mm diff would put the track out by 30mm with standard rims. The National code of practice allows a maximum track increase of 25mm.
#23 _rorym_
Posted 22 October 2006 - 01:31 PM
No drama on a race car.
#24 _CHOPPER_
Posted 22 October 2006 - 02:37 PM
You mean John Taverna Chassis in Leo St. Fawkner, VIC?
#25 ls2lxhatch
Posted 22 October 2006 - 03:18 PM
Yes. I meant to write Phil at John Taverna Chassis.
