My HB Torana
12 replies to this topic
#1 _HB1200_
_HB1200_
Posted 01 September 2006 - 01:38 AM
Hi Guys,
I thought I would share some pics & info of my HB Torana restoration/modification. Its a 1968 series 2 HB 2 door SL with 1159cc engine and 4 speed. I am the fourth owner and it had original 50000 miles on the clock when I picked it up.
The body is relatively rust free except for the back edge of both front guards and some surface rust where the underbody tar has fallen off. There is a dent in the right hand rear quarter and the paint is extremely weathered.
The interior is close to immaculate except for the crash pad and top of the rear seat. The car came with all the original books and tools, the only missing part is the original rubber spare tyre holder and block of wood for jacking (may have been in Brabhams only).
I have begun buying up bits for it as required when ever I come across them. I have so far been able to find a nos steering coupling, nos rear quarter panel, nos front number plate panel, nos rear indicator lenses, nos clutch cable and an almost complete set of bushes/ball-joints from rare spares. I have also bought a Brabham carby setup minus air-cleaners, GTR dash and a black GTR steering wheel (minus horn button).
The car is currently off the road as I get ready to put a rebuild a 70 series motor from a LC. I will also take the opportunity to rebuild the front suspension, convert to disc brakes and re-tar the floor pan & wheel arches.
The only alterations I have made so far is the addition of some eyelids. I am keen to try and find some of the original nasco options and maybe a rear venitian.
The Brabham carby setup came without air cleaners and I was keen to try out an idea I had to put small ram tubes inside a slightly higher than standard a/c assembly. I have made tooling to spin the lids and ram tubes from aluminium and they have come up quite nice using the repro dotloc wingnuts. In hind sight I'm not sure if my ram tube idea will work that well but it is easy to run them without so I will try both setups when I get it running.
The 70 series motor is supposedly rebuilt so I will strip it down and check it over and get the head sent off for some mods. From my research, the main place to get extra power from these motors is the heads. I will be running the standard cast iron sports headers untill find a set of extractors (unlikely).
Why spend time & money on a HB you might ask. I just love the styling of the car and after reading an old wheels "Hot Up Guide" I was inspired to carry out some period performance mods with the hope that I may some day have the power to overtake slow moving tractors.
See below for pics. I will post more as the work progresses.
HB1200
#2 _Flamenco_
_Flamenco_
Posted 01 September 2006 - 07:02 AM
Looking good HB1200... Like the headlight covers!
#3 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 01 September 2006 - 11:37 AM
looking good! I like the carb/ram tube setup, do you have any pics/information on how you made them?
#4 _UCV80_
_UCV80_
Posted 01 September 2006 - 11:41 AM
Thats cute!
Looks awsome :rockon:
#5 _HB1200_
_HB1200_
Posted 01 September 2006 - 05:01 PM
Thanks for the coments guys.
Makka, The spun items were made on a small lathe at home using a metal spinning method Metal Spinning. I basically make a steel or wooden mandrel of the inside shape that I want and clamp a round flat sheet of aluminium to that. I then flow the sheet over the form and then trim off any excess material. The ram tube was slightly more complicated in that I had to mate the tube to the billet base and re-roll the back edge of the tube to lock it on.
HB1200
#6 _Aquarius - LC_
_Aquarius - LC_
Posted 01 September 2006 - 07:19 PM
Very cool HB1200 !!
It's a TORANA , so i love it !! :D :rockon:
#7 _lcxu1_
_lcxu1_
Posted 02 September 2006 - 07:19 PM
That is so cool, looks in great condition, keep the pics coming,
Regards Simon
#8 _Keithy's_UC_
_Keithy's_UC_
Posted 03 September 2006 - 06:33 AM
Thats great! I like your ideas of keeping it 'period modded'!!
I rekon thats in great condition considering age! I'm holding my breath for the end result!
Keith
#9 _73LJWhiteSL_
_73LJWhiteSL_
Posted 03 September 2006 - 11:57 AM
Looks great mate! :spoton:
Personaly I like the LC/J best, but I like the HB next... in front of the LH/X/UC Toranas :tease: :tease: :tease:
*flamesuit on*
Steve
Edited by 73LJWhiteSL, 03 September 2006 - 11:58 AM.
#10 RIM-010
Posted 03 September 2006 - 12:00 PM
Lookin good HB1200.
The LJ that i bought from ya is still sitting under the carport, waiting for the Xmas holidays.
I love hte carb setup youve got there.
Good luck.
RIM
#11 _HB1200_
_HB1200_
Posted 04 September 2006 - 09:03 PM
The HB project will take a while as my time and money are spread across a LH, LX & HJ as well. The new engine is on the stand now so I will make a start on that over the next couple of weeks.
I have bought a few books relating to Vauxhall Vivas from the UK which detail many interesting mods for their Viva HB. The Viva HB is almost identical mechanicaly to the HB Torana so most of the information is applicable. Some of the mods include chassis stengthening kits, swaybars, side draft webers, oil coolers and even fine detail such as where to massage the inner gaurds to fit larger rims. Alot of these mods are way over the top for what I want but some do make sense. When I rebuild the front cross member I will incorporate some of these mods and I'll post some pics.
HB1200
#12 _RpM_
_RpM_
Posted 05 September 2006 - 08:46 AM
Lookin good mate, cant wait to see it all done... got any pics and info on the LJ,LX and HJ aswell? lol...
#13 _HB1200_
_HB1200_
Posted 05 September 2006 - 05:29 PM
Cheers Rpm,
heres some pics:
I might post some info on the LH soon but briefly, the LH is getting fully restored, new suspension etc, its got a 9" 3.25 LSD, Im starting to get bits together for the motor build atm, decent paint to follow after its on the road. The LX is my rust bucket/weekend hack, runs a worked 186 with a supra 5 speed, currently converting from twin su to tripple. The HJ is my own personal nightmare, It was supposed to be a HZ (my first car). The paint shop got a new shell for it but got the wrong type. I got screwed on that project, what you see cost 12K. The paint (platinum metallic) is excellent though, all rust has been removed.
HB1200
