Competition Exhaust
30 replies to this topic
#1 A9X
Posted 23 November 2006 - 04:25 PM
Specifically speaking, who makes the best extractor/exhaust system for 5litres in the LX, and what combination?
Would the tried and true L34 system still be the best choice?
Welby
#2 _82911_
_82911_
Posted 23 November 2006 - 09:57 PM
In my opinion,Gonzo pipes make the best pipes for motorsport.
1&5/8" x 14" stepped to 1&3/4"x20" into a merge collector 3.5" choked to 3" at the venturi. Fit an oval megaphone muffler with a reverse cone and that is about the ultimate set up.
Cheers Greg..
#3 micklx
micklx
  • 1,785 posts
Posted 23 November 2006 - 10:07 PM
So does the merge collector join the 2 into 1 ?
Didn't the Race A9X's run a twin system?
Where is Gonzo Pipes located ?
#4 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 24 November 2006 - 03:14 PM
Cheers Greg..
Personally I like a smaller collector choke, 2.5" or 2.75". This gets a bit more torque. Have to agree with everything else tho..........
#5 _82911_
_82911_
Posted 24 November 2006 - 05:01 PM
Gonzo is in QLD at Toowoomba as far as i know...sorry don't have a contact, fairly well know, try directory assistance maybe?
Struggler... I have never been quite that brave, to choke the venturi down that far.. I guess it is a follow on from the old days of "bore a bigger hole in it" and it must go faster!!!Syndrome!!!
So it fattens up the midrange.. But do you loose a lot of topend? the car I'm thinking of is amidleweight 3300lbs with big revving 308, so small cubes...
Wadddaya rekon?? worth a try?
I was actually thinkin of trying a set of these.....
All input appreciated...
BTW: sorry about the thread steal..... :spoton:
Cheers Greg..
#6 A9X
Posted 24 November 2006 - 05:34 PM
Steal away Greg,
I'll get better info more input we get.
I'm specifically after torque in the low - mid rev range out of a 308.
Welby
BTW, whose/what are they ^ ?
Edited by A9X, 24 November 2006 - 05:35 PM.
#7 _82911_
_82911_
Posted 24 November 2006 - 05:46 PM
There a set of tri y slip ons made by Robert Yates Motorsport in the USA for the Nascar Busch cup cars. Ford though....
Cheers Greg..
#8 _rorym_
Posted 24 November 2006 - 06:05 PM
PM majiva33...he lives in Toowoomba and races..used to..a LC XU1.
#9 _MRNOS_
_MRNOS_
Posted 24 November 2006 - 07:43 PM
I think GONZO's are around the birkdale area still, if you've got the bucks to spend, Custom Exhaust Specialists at Meadowbrook do very good work, but are pricey-so are Gonzos
#10 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 24 November 2006 - 08:59 PM
Exhaust is a peculiar thing, what works well on one motor may not work so well on another. It is however the one area where small changes can net large gains in torque and horsepower. I have spent a lot of money on computer programs and books and a lot of theory does not work in reality. Changing exhaust on the dyno is quick and easy and will usually point you in the right direction.
FWIW I have made the following observations, on engine dynos and cars running the quarter.......
I have never seen stepped 4:1 pipes produce more power than straight 4:1s,
Every time I have reduced collector size on 4:1 pipes the car has gone faster, quicker and made more peak horsepower, (much to the surprise of owners and dyno operators alike !!),
The tri-Y design is very efficient and can produce great power but exhaust manufacturers have got the sec. and collector ID sizes all wrong, to get them to work they need help,
The pipes that outright made the most power and torque on a VN headed stroker were homemade 1 7/8 primary tri Y's, on HQ headed engines the Pacemaker 1 3/4" tri Ys with larger sec. and collector pipes are gold,
My own SBC engine that pushes my HQ tonner to 11.0's only has 2 3/4" collectors,
Using too small a pipe is way better than using too large, by a long shot,
Collector size is crucial.
The best money I have spent on information came from this guy... https://www.headersbyed.com/ and I knew about him long before he got written up in Street Machine.
These are just my observations made over the last 15 odd years. If you want to talk specifics let me know, it all relates to CID and peak RPM.
Hope this helps.
#11 A9X
Posted 24 November 2006 - 09:55 PM
That's gold Struggler.
My situation is a 308 , carb fed, that will be used for tarmac rallies.
Ideally, you want most torque/power low to midrange, for punching out of low speed corners and chicanes.
4 speed box at present , waiting on rule clarification before going 5 speed.
Diff ratio can be swapped to suit, probably 3.09/3.55.
Exhaust can exit before the rear wheels.
Welby
#12 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 25 November 2006 - 07:52 PM
Welby
If its got HQ heads get the Pacemaker 1 3/4" tri Y pipes and be prepared to at least modify the collector. From the collectors merge the two pipes into a single after about 18-24" then maintain another 18-24" before a chambered muffler or dump pipe. The modified 1 3/4" tri Y pipes lose no torque to modified 1 5/8 tri Y so buy the big ones first.
Edited by Struggler, 25 November 2006 - 07:55 PM.
#13 _82911_
_82911_
Posted 25 November 2006 - 08:36 PM
Good on ya Struggler for sharing, there is no more hard won knowledge that exhaust tech! It's a tough slog.
What areas of concern are there with the pacemakers? Do you modify just the collectors or is there a problem with the secondaries sizing?
as an aside i have an article here on sand bending pipes and I'm thinking about making up a set just for fun.. well not really "fun" but just to try something different from the usual "mecano set" fabrication that is the norm with pipe building. i'll let you know if it works or if i fail miserably!!
Cheers Greg..
#14 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 25 November 2006 - 09:48 PM
Changing the collector only shows the best gains for the least work. It is also easy to swap collector sizes on a dyno or track to get the best compromise for your combo. Changing the sec. sizes without testing can easily lead you up the wrong path !!!
Without going right into the maths, it all has to do with area ratios as the steps are made, ie to provide effective scavenging a reduction in area has to be made to ensure gas velocity is maintained, without becoming a restriction. This reduction ratio has to be tailored to the operating range of the motor. As an example, the total area of 4x 1 5/8 pipes compared to the total area of a 3" pipe is around 1.11. The same for a set of 4x 1 3/4 into a 3" collector is 1.40. This means the reduction and therefore scavenging capacity of the 1 3/4 - 3" pipes is greater than the 1 5/8 - 3" pipes. In practice I have found that 2.5" collectors on 4x1 5/8 pipes work really well (2-3 tenths faster over the 1/4). This should indicate the sort of ratio we are after. It should be noted that you can overdo the ratio and start to restrict the engine.
As another example the Pacemaker Tri -y that makes good power on VN heads has 1 3/4 primaries, 2" sec and 2 1/4 tertiary or collector size. Opening up the collector to 2.5" increases the power and torque. This set up is fairly fool proof and works well on all 355 type VN headed strokers. Now lets look at the HQ 1 3/4 primary tri Y's. The sec are 1 7/8 and the collector 2". The reduction ratios for these step downs are near 2. This works OK for a stocker but if you want to use the performance advantage a 1 3/4" primary offers you really need to open up the sec and collector size to get the ratio near 1.5. This lands fairly close to the VN pipe sizes of 2 and 2.5 ". I have seen cars use 1 3/4, 2 1/4 and 3" but they utilized convertors of over 6000 rpm stall.
This may all sound like a little too much but have a few reads of the info and do some math. There is no real magic in the right ratio, just different ratios for different applications. Like I said in the first paragraph, you really need to test to find the best setup for your engine and application, but what I have given you here will get you on the right track.
Hope no-one loses any sleep over this !!
Greg, as for the sand forming...... a friend of mines father is a real old school tuner, and has been for ever. He still hand builds open wheelers and such and I have seen him make some beautifully formed sand bent extractors. Real works of art with gentle curves to die for. They look great on the open wheel race rigs.
#15 _Oldn64_
_Oldn64_
Posted 26 November 2006 - 06:32 AM
As an aside i have an article here on sand bending pipes and I'm thinking about making up a set just for fun.. well not really "fun" but just to try something different from the usual "mecano set" fabrication that is the norm with pipe building. i'll let you know if it works or if i fail miserably!!
Cheers Greg..
Hey Greg,
Allow me to state you do need alot of heat to do this and need to take things slow. Also make sure your sand in not wet or anything. I bake mine in the oven first (wifie not thrilled with this, think when I get my own place the shed will have its own oven.. :D).
The trick is to heat the whole circumference of the pipe before bending anything. Pack the sand bloody well too, as not packed enough will crease thew pipe. Suggest a number of practise runs before you go doing the final one. Map everything out with coat hanger and above all have fun. It really is great when you turn to others to state I made them myself.. :D
#16 ls2lxhatch
Posted 26 November 2006 - 01:45 PM
Welby,
When I was looking for someone in WA to make extractors to suit an LS2 in a Torana the Butler's names kept coming up. Apparently they are brothers but two separate businesses.
Butler Built Performance Products
16 Cohn St
Carlisle 6101
Norm Butler – 9472 7373
Andy Butler
9361 0144
0439 995 123
I ended up purchasing extractors off the shelf from CAE because then custom made extractors we going to cost around $1700, there was a one month waiting list and they would need the car for a week. I intend to get my CAE extractors coated by this company once they have been test fitted.
Competition and Industrial coatings
Unit 1/8 Brant road
Kelmscott
(08) 9495 4237
#17 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 26 November 2006 - 10:35 PM
As said above, Butler built (Norm) makes some awesome systems, from exhaust port to tail pipe. Have seen and heard only good reults from his workmanship.
Dave
#18 A9X
Posted 27 November 2006 - 11:09 AM
Thanks all. that's a bucket load of info to keep me going for a few weeks.
Welby.
#19 _Poinsdexter_
_Poinsdexter_
Posted 27 November 2006 - 11:28 AM
A9X,
The national tarmac rally rules are now posted on the CAMS website. If you run in MS (Modified Special), you can have any gearbox as long as it fits in the standard tunnel and has no more the 5 forward speeds and 1 reverse, and operates via H pattern shift.
I have a 308 hatchback with 420HP and 385ft/lbs and use an M21 case with a PPG straight cut dog gearset. These cost about $7000 but you will never break it. It is also a joy to use as it shifts very quickly without the clutch.
As per the exhaust, I have assymetrical Yella Terra aluminium heads with Pacemaker 1 3/4 primaries and a cossover pipe, all discussed above. My engine makes over 300 ft lbs at 2000rpm, which results in serious traction problems. Please note that the exhaust must exit at the rear of the car, as control keepers don't like the noise/fumes associated with side exit.
What is the spec of your car, and what rallies are you planning on?
#20 A9X
Posted 27 November 2006 - 12:47 PM
Thanks Poinsdexter,
I'll check the CAMS website as i have what i thought were the final rules following Targa West.
There is no mention of Modified Special as a category in my rules.
The rules we are building the car too at present don't allow us much modification at all, past the usual suspension/exhaust etc. Although we can have the exhaust exit before the rear wheels if clarance is an issue.
We must maintain carby feed, no EMS, no 9 inch etc. The major hiccups are the gearbox, my rules state 4 speed but otherwise free, and wheels size, my rules state 1 inch over diameter and 1 inch over width. So that gives me 15 x 7's to play with. Not a lot of variety in tyre choice.
Brakes are free but obviously are dictated by rim size.
Best i check out these rules you mention before going any further. I'll be pissed if they've changed them again. It'll be the 3rd version in 12 months.!
Thanks,
Welby
#21 A9X
Posted 27 November 2006 - 04:25 PM
Poinsdexter i have had a look at the CAMS site, the tarmac rally rules are the same as given at Targa West 06 back in September.
These are the rules i am constructing the car to (C2).
I don't quite see where you are refering to Modern Special??
I do see that C3 allows five speeds however, and i am awaiting clarification from CAMS as to the reason for C3/C2 differences.
Welby
Edited by A9X, 27 November 2006 - 04:25 PM.
#22 _Poinsdexter_
_Poinsdexter_
Posted 29 November 2006 - 08:28 AM
Sorry for the confusion.
CAMS use C1, C2, C3 which refer to a level of modification you can use. Classic Adelaide use SS - Standard Specification, LMS - Limited Modification Specification, and MS or Modified Specification which relate directly to C1 - C3.
As per the exhaust, I would get approval to run a side exit before pay for it to be done, as you might find you are doing it twice.
#23 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 30 November 2006 - 05:24 PM
With the tarmac rally rules, is there a class you can enter that is open allowing any modifications to any vehicle?
Thanks,
Dave
#24 A9X
Posted 30 November 2006 - 06:29 PM
in short , no.
In targa this year we had a number of cars 'by invitation"
A chev powered xjc jag and 2 commodores, 1 turbo powered. The organisors have told me that they allowed the jag entry bacause he had paid up well before CAMS imposed their new tarmac regs, and the commodore wasn't discovered to be that modified until pre event scrutineering, so they let him run under invitational.
The new tarmac rules have been accepted by the organisors because they see a greater benefit in having a possible 'circuit' between the other events like tassie and adelaide, than in bringing in highly modified cars.
There will not be an invitation category in this years targa west.
Welby
#25 _rorym_
Posted 21 January 2007 - 12:00 PM
What does Croad run the Monaro under then?..cause those wheels aint 15 x7!!
