Killin Batterys!
#1
Posted 28 February 2008 - 10:25 PM
now the alternator is new and the battery has still shit itsself,what could be causing this????battery is under warranty so ill get another 1,but dont want to always do this exercise.also running a gilmer belt from die crest(i think).
Posted 28 February 2008 - 10:29 PM
If you are running a different belt size they may be over revving and cooking themselves.
Welby
#3
_WantOneNow!_
Posted 28 February 2008 - 10:33 PM
Cheers Mick.
#4
Posted 28 February 2008 - 10:35 PM
Does the car sit for long periods, e.g. 3 weeks or more?
#5
Posted 28 February 2008 - 10:38 PM
#6
Posted 28 February 2008 - 10:41 PM
#7
Posted 02 March 2008 - 06:57 PM
now something has flaterned my battery,wat could it possibly be?only after market part i have is the au thermos but they only run when the motor is on and like over a certain temp.
the alt is new so is there anyway i can check wat is causing the battery to go flat?
#8
Posted 02 March 2008 - 07:25 PM
Edited by rorym, 02 March 2008 - 07:26 PM.
#9
Posted 02 March 2008 - 08:06 PM
#10
Posted 02 March 2008 - 08:09 PM
Have you done what I suggested in my previous post?the alt is new so is there anyway i can check wat is causing the battery to go flat?
#11
Posted 02 March 2008 - 08:34 PM
Alarm bells are ringing...yeah
Posted 02 March 2008 - 08:52 PM
Drive it, park it, and try to start it after a week. Is the battery flat? Charge it, drive it, park it again, except this time, disconnect he battery. Reconnect it and start it. If it starts OK, then you have something drawing power from the battery when the car is sitting. This doesn't happen with standard Toranas, as nothing is connected with the ignition off - even the factory clocks draw so little current, they wouldn't make a difference. Look for culprits such as the thermo fans being wired incorrectly, car alarm, extra gauges or amplifiers hooked up to the battery when they should be hooked up via the ignition switch.
#13
_Chriskoss-79uc_
Posted 02 March 2008 - 09:03 PM
so you're saying in an old car eg. a torana, its best to hook up amplifiers via the ignition so it doesn't drain the battery?Turn the headlights on. Start it, and bring it above idle, and check to see that the headlights get a bit brighter. They should do, as even a perfect battery will not output as much voltage as a charging system (ie alternator) in good condition.
#14
Posted 03 March 2008 - 11:41 AM
#15
_Brewster_
Posted 03 March 2008 - 09:39 PM
#16
_Chriskoss-79uc_
Posted 03 March 2008 - 10:18 PM
...... I wasn't the guy who started the thread chopYou can hook them straight up to the battery, provided you remember to turn the bloody thing off. If you can remember to turn off headlights, you can remember to turn off a stereo.
#17
Posted 04 March 2008 - 08:58 AM
#18
Posted 05 March 2008 - 10:12 PM
My point is my forklift at work went through 2 heavyduty batteries in quick time and i had fitted them directly on the steel frame, was also constantly charging them, the latest new one (Standard duty) i threw a piece of doubled up cardboard under it and it's been fine for about six months and havent had to charge it once.
(I only use the forklift, if its lucky once or twice a month)
I dont think batteries like being directly on cold steel surfaces?
#19
Posted 05 March 2008 - 10:22 PM
#20
_Brewster_
Posted 05 March 2008 - 10:33 PM
#21
Posted 05 March 2008 - 10:41 PM
The only thing that i have changed is the cardboard & the standard duty battery was a 2nd hand one that was sitting under my bench for at least a year, was dead flat, i charged it once and its been perfect since.
#22
Posted 05 March 2008 - 10:51 PM
The problem is worse in forklifts, because they have a couple of tonnes of cold hard metal in the counterweight. The more metal, the more heat it extracts out of everything, including batteries. The colder the battery, the slower it cranks. Until it gets to the point where it doesn't crank.
#23
Posted 06 March 2008 - 03:02 PM
I can vouch for the cold though... Over summer if i dont drive the car for a few weeks, I can start it no problems at all. In winter, i leave it for a week and it will have heaps of trouble starting!
#24
Posted 06 March 2008 - 05:33 PM
guys was just curious bout the small black wire that comes off the back off the alternator,does it just connect into a spade on the back off the alt?
#25
Posted 06 March 2008 - 10:51 PM
