Convert UC to LX?
39 replies to this topic
#1 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 07 July 2008 - 10:23 AM
I did a search and couldn't find anything, but I appologise if this has come up many times before.
I'm wondering who has converted a UC to LX? Front panels / rear tail lights.
Without looking closely, would it be possible to remove all front panels, including rad support, and fit LX ones? As for the rear, could you cut and weld around the tail lights / rear panel, to fit LX lights?
I'm thinking about all this on a UC hatch. I'd probably want to do the dash too.
No offence to UC lovers.
#2 rodomo
Posted 07 July 2008 - 07:46 PM
I believe the skirts are different too.
#3 _ChiaLX_
_ChiaLX_
Posted 07 July 2008 - 08:55 PM
^^^ yep basically cut the front off from firewall and replace with lx. lots awork!!
#4 yel327
Posted 07 July 2008 - 09:43 PM
From memory the level of the hatch floor is different too. Can't remember exactly where and how, but I think the UC sits higher ie more room where the spare goes. I remember comparing an 11/77 UC Sunbird Hatch with my 2/76 LX Hatch side by side. This was 20 years ago though.
#5 _ChiaLX_
_ChiaLX_
Posted 07 July 2008 - 10:12 PM
thats also correct as i have also seen this. about 50mm diff I think. not sure if it will affect the tail lights though.
Edited by ChiaLX, 07 July 2008 - 10:13 PM.
#6 notna
notna
  • 706 posts
Posted 07 July 2008 - 10:18 PM
do you mean sills?
Can you retain the front rails in engine bay, and only replace the rad support, or is it totally different where the front guards bolt on along the top?
I don't mind a bit of welding, but i'm not keen on chopping from firewall forward! :o
#7 slx 050
slx 050
  • 115 posts
Posted 07 July 2008 - 10:45 PM
When you get this project underway... Pictures would be good...
When I'm finished the LX SS hatchback (later this year or early next), I think I'll make my UC hatch an LX (I've got 8 sets of LX guards, nosecones and bonnets), but with a roll cage.
I think I'll make a BBQ too... when I get a chance...
#8 TerrA LX
Posted 07 July 2008 - 11:50 PM
do you mean sills?
No he meant inner guards, which are different.
#9 notna
notna
  • 706 posts
Posted 08 July 2008 - 08:51 AM
ahhh ok. I was thinking they may be different. cheers.
#10 _hatcheddan_
_hatcheddan_
Posted 08 July 2008 - 07:46 PM
I found this out when I tried fitting UC rear cargo boards in my LX :D
#11 _lx304hatch_
_lx304hatch_
Posted 18 June 2013 - 07:43 PM
really easy conversion
i have completed 2 hatch's now one is my personal daily driver
any one that may have any questions pls pm me and ill write back
front is simple drill all spot welds out on front inner panels so you have 2 rails and battery and charcole canister plates still on there
1 small bend on batter side corner and 1 small bend on charcole canister panel then line the front up and re weld all the spot welds
rear is cut and shut each side 1 side at a time i found best
#12 _UCL98_
_UCL98_
Posted 23 June 2013 - 07:00 PM
I like this idea, hard to find a good donor car for this tho. Wonder which way is best on bank balance as I see 3 way to attack the UC to LX as I'm doing a UC to LX also.
1 . I read up dirtbags build and I like the idea of using LX rad support panel after cutting back the UC guards and panel working the UC guards to match LX nosecone ( my fav way )
2. Putting LX guards onto the UC inner guards and doing some mods to fill the gap
3. Replacing the whole front end, using LX inner guards and adding the rest.
In having trouble finding fair condition parts I'm looking at either doing number 1 or 2 . I'm swinging towards number 1 as the cost for parts will still out way panel cost I think.
Morro
#13 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 23 June 2013 - 07:27 PM
Have all parts same idea. UC Hatch , LH front cut from behind rails foward and LX Rear. Nead alot or welding practice or get job farmed out by someone
#14 _BLOWN V6HATCH_
_BLOWN V6HATCH_
Posted 23 June 2013 - 09:23 PM
Morro
Option 3 is the only way to do it IMO. That's the way i did mine, because when i lift the bonnet, i want it to look like a factory LX, not a chopped up UC.
#15 _ryan350_
_ryan350_
Posted 25 June 2013 - 01:35 PM
If you need a rad support i could help, I have 2 spare lh/lx ones sitting in a corner.
#16 _petespipes1_
_petespipes1_
Posted 04 May 2021 - 05:13 PM
Yes an old post from 2008
still relevant as 70s rustbuckets [yes our cars] are as popular as ever and harder to find at the right price
So im doing this today,UC to LX, so i recently join forum, search, and this is what i find. I must be doing something wrong? 8 year old post not updated?
I wont go any further. Surely someone will tell me where to look for the up to date info on this subject
everything is bolt on or glue on from ebay now right?
#17 Bigfella237
Posted 04 May 2021 - 06:09 PM
The thread hasn't been updated because nothing has changed.
Not sure what's on ebay but nothing is bolt-on nor glue-on as far as a UC > LX conversion goes (unless you mean the kind of "glue" that CIG sells)!
Post number 12 above pretty much says it all for the front end panels.
#18 Ice
Posted 04 May 2021 - 06:11 PM
Go to Members section and go to Heaths Hatch page 7 and keep reading that should keep you busy for a few hours or so
pretty sure Heaths got it down pat
Happy reading
#19 Heath
Posted 05 May 2021 - 11:37 AM
As per Gene's comment:
http://www.gmh-toran...hatch/?p=874546
This has been covered heaps of times, and done heaps of times. Your most detailed reply won't necessarily come from the first thread you find with a matching description in the title.
Some of the big build threads each cover several hundred good build ideas/executions, but it takes a bit of time to absorb, lol.
#20 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 06 May 2021 - 12:23 PM
Personally I wouldn't touch the Ebay Glue in conversion kits. The tail lights really should be welded in and the front kit you have to cut away a major portion of the radiator support panel and that could cause other issues.
#21 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 11 May 2021 - 04:28 PM
This is probably the most comprehensive UC to LX conversion build. I certainly referred to it a lot for my own build.
Fixing my brothers UC hatch - Members Projects & Plans - GMH-Torana (gmh-torana.com.au)
#22 burty
burty
  • 153 posts
  • Name:BURTY
  • Car:UC torana
Posted 11 May 2021 - 04:31 PM
My build, not as full on as Dirtbags but similar method
Burtys UC To LX Conversion - Members Projects & Plans - GMH-Torana (gmh-torana.com.au)
#23 _petespipes1_
_petespipes1_
Posted 11 May 2021 - 05:04 PM
what a load
if you dont know whats changed since 2008
how about something from someone thats actually used some of the new conversion gear.....
not my first rodeo
I have a good idea of whats available but i thought someone thats actually used it might speak up
#24 _petespipes1_
_petespipes1_
Posted 11 May 2021 - 05:16 PM
Look i appreciate the excellent posts you refer to about the old and trusted method to convert UC to a much better looking Torana. The time it takes to put these posts together takes a lot of effort and a great attitude to sharing which is what keeps forums alive
{not repeating other peoples info}
But times have changed like it or not.
Steel guards and bonnets are virtually unavailable for a start.
I will be using fibreglass guards and bonnet, possibly nosecone as well and yes glue on plastic stuff from ebay or wherever
provided i can check that it fits ok and looks ok.
Masny of these kits have been sold / used.
Perhaps owners of said cars are not up for possible criticism from others ???   personally dont care what the armchair experts think.
#25 claysummers
Posted 11 May 2021 - 05:32 PM
At least if you leave it as a UC it will be an honest sturdy car, which is half the appeal of these old jiggers. My 2c.
