[Torviki] Lh/lx To Uc Interchange Guide.
12 replies to this topic
#1 Joshua
Joshua
  • 2,539 posts
  • Name:Joshua
Posted 24 July 2008 - 10:41 PM
Article title: Uc - Lh/lx Interchange Guide
Article description: The real use for a UC...
Category: General LH-LX-UC
Date added: Jul 24 2008, 10:11 PM
Article starter: Joshua
The List!
UC Parts that can be used on LH and LX Toranas
Front Bumper - no
Nosecone - no
Grill - no
Bonnet - no
Guards - no
Kframe - Yes
Engine - sure why not
Radiator - Yes
Polution stuff - don't see why not
Wiper bottle - Yes
Brake booster - Yes
Steering column - Yes
Air/heating - Yes (Except dash parts)
Dash - no
Wiring - could do if you wanted...
Pedals - Yes
Steering wheel - Yes
Wheels - Yes
Gearbox & crossmember - Yes
Tailshaft - Yes
Rear axle (Diff) assembly - No, requires modification to the control arms as rear floor pan is different (Will fit in an A9X though)
Seats - Yes
Carpet - Yes
Glass (All) - Yes
Hand Brake - no
Headlining - Yes
Grab handle thingos - Yes
Sunvisors - Yes
Mirrors - Yes
Doors - Yes
Door Trims/cards etc. - Yes
Boot lid - Yes
Petrol Tank - No
Rear Bumper - Yes
Taillights - No
Headlights - No
Indicators - No
VIEW ARTICLE
#2 MRLXSS
  • 12,422 posts
Posted 25 July 2008 - 08:27 AM
Tailshaft, i think is Yes! I have used a LX tail shaft on a UC, so cant see why the reverse wouldnt work!
(I think i edited it)
Good Wiki though
#3 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 25 July 2008 - 09:44 AM
Very handy. Nice work.
Do all of the above also apply to a UC hatch?
#4 yel327
  • 13,939 posts
Posted 25 July 2008 - 01:49 PM
Handbrake from bench seat and poverty pack UC will fit an LH/LX.
UC 6cyl Aircon is the same as LH/LX V8 - Even the vacuum control switch fits - it's just on it's side in the UC.
#5 MRLXSS
  • 12,422 posts
Posted 25 July 2008 - 02:06 PM
Elaborated a bit more on the diff
Edited by MRLXSS, 25 July 2008 - 02:08 PM.
#6 _AGGRO_
_AGGRO_
Posted 25 July 2008 - 02:23 PM
is the column in the UC any different at all to LH/LX or are they the same? Just wondering if there is any improvement in swapping them over.
#7 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 25 July 2008 - 06:03 PM
Steering columns have a fair few subtle differences - if you try to swap bits between the 2 columns you will notice as some things wont change over.
The only real advantage I can think of with the UC column is the wiper switch which comes with +'s and -'s.
Pedals and brake booster - yes provided you use the correct pedal with the correct booster as there are straight and bent rod versions of LX booster where as the UC used bent rod only.
#8 _torbirdie_
_torbirdie_
Posted 29 July 2008 - 01:42 PM
ac condensor has different attachment points for the refrigerant.
#9 _NOI53Y_
_NOI53Y_
Posted 04 August 2008 - 09:56 PM
Will the drum brake setup (complete) from a UC fit onto a LH/LX diff.
#10 _RhubarbDude_
_RhubarbDude_
Posted 21 December 2009 - 03:02 PM
Seatbelts probably....
#11 _Matvex_
_Matvex_
Posted 16 September 2013 - 03:00 PM
Is a UC 6cyl Exhaust bent up the same as LH/X?
#12 old-jim
old-jim
  • 89 posts
  • Name:Jim
Posted 16 September 2013 - 08:28 PM
6 cyl exhaust is mostly the same.
The engine pipes have different manifold jointing methods.
The UC exhaust manifold has a Hot Box connection to the inlet manifold.
Jim
#13 _Matvex_
_Matvex_
Posted 16 September 2013 - 08:35 PM
Cheers jim
