Diff widths
11 replies to this topic
#1 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
Posted 17 November 2009 - 05:11 PM
G'day Guy's & Gal's, would anyone now the the difference in widths between an lc/lj and an lh/lx diffs. Possibly distances between upper/lower control arms etc. Any info appreciated. :)
Paul
#2 _danny_
_danny_
Posted 01 December 2009 - 10:41 PM
would anyone now the the difference in widths between an lc/lj and an lh/lx diffs. Possibly distances between upper/lower control arms etc. Any info appreciated. Posted Image
X2 [;ease :)
#3 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 05 December 2009 - 05:05 PM
do a search on oldholden.com im pretty sure someone has compiled a list of old holden diff widths on there. not sure if u will find exactly what you need but its worth a shot
#4 _HQ SS_
_HQ SS_
Posted 05 December 2009 - 05:24 PM
I am the one that has been compiling a list but would like confirmation on some sizes.
As I have several sizes for the same diffs.
Axle Flange to Axle flange measurements.
EK 55.90" 1420 mm
HR 57.08" 1450 mm
HK 60.47" 1536 mm ?
HT/G 61.02" 1550 mm ?
HK/G 60.25" (with drums fitted) HP engines
HQ/Z 61.33" 1558 mm sdn and ute
LJ 53.93" 1370 mm
LH 56.69" 1440 mm
VB/K 58.85" 1495 mm large sals
VB-VK sedan (GM-H diff) 1506 mm with discs & 1500 mm with drums
VB-VK wagon (GM-H diff) 1530 mm with discs & 1524 mm with drums
VK-VL (BW diff) 1521 mm with discs & 1515 with drums (sedan & wagon same)
VN/VG/VP all live axle 1564 mm with discs
VN 1550 mm or 1560 mm ??
VR/VS sedan live axle 1576 mm with discs
VR/VR wagon & ute 1564 mm with discs (same width as VN/VG/VP)
VY cross 8 4wd 12 03 1706MM 1720MM with 7mm thick rotors attached.
XR-XY Falcon 59.05" 1500 mm
XA-EL 61.02" 1550 mm
XG van 11/93 1543 mm
EB 61.22" 1555 mm
BF 2004 falcon ute 1630 MM
I have been trying to get flange to flange measurements so if anyone can add to this list
or do any known corrections please do.
Cheers Paul.
#5 _kiwi conversion_
_kiwi conversion_
Posted 14 June 2015 - 09:14 PM
Hi mate bit new to my torana knowlege but an building a lh and wanting to run a 9" diff will obviously need shortend do you know what width people run them at with flare kit 0n and say 14x8s or 10s, thanks
#6 N/A-PWR
Posted 24 May 2016 - 12:44 PM
Here is a disc brake 9 inch for a mini tubbed LC/LJ at 1140mm flange to flange for sale:-
Attached File  9 inch disc brake 1140mm.jpg   151.76K   23 downloads
http://www.gumtree.c...drag/1112613377
and the standard LC/LJ diff drum to drum width of 1370mm:-
Attached File  Drum to Drum Measurement 1370.jpg   78.97K   36 downloads
Attached File  Drum to Drum Measurement 1370.jpg   95.93K   27 downloads
Attached File  Drum to Drum Measurement 1370.jpg   71.5K   22 downloads
#7 Ice
Posted 24 May 2016 - 06:46 PM
Lol oh mcgoo you done it again
#8 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 21 July 2017 - 08:20 PM
If you all are looking for a diff to cut down i strongly suggest that you look at the cross 6 or cross 8 crewman diffs. Being longer you don't have to buy new axles as the factory ones are 39mm thick and can be re splined at correct length for lc lj lh lx and uc. Also they are an 078 borgwarner diff so lsd 4 pin center is easy to find and the biggest bonus is the axle tubes are 6mm thick. Also come with 286mm x 16mm disk. Only draw back is you have to fit shock mounts on the back of lower diff brackets for lower trailing arms. 3.45 ratio too.
#9 Ando
Ando
  • 527 posts
Posted 13 March 2022 - 06:40 PM
Wanting confirmation of overall width (disc hub mount face to mount face) of a UC small Salisbury with rear disc brakes. Cheers
#10 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 14 March 2022 - 07:56 PM
should be the same as LH/LX  1440mm ? , have a disc brake set here but its not on the car.
the UC disc axles are shorter but with the disc on the diff width ends up about the same
Edited by UCSLE, 14 March 2022 - 08:01 PM.
#11 Ando
Ando
  • 527 posts
Posted 15 March 2022 - 05:25 AM
I found theses photos somewhere on the web.
The measurement indicates it's 1430mm wide but the next pic of the same diff shows the disc is off on the other end.
The photos are a bit confusing to conclude the UC disc diff is shorter than the standard 1440mm.
Hence wanting a second confirmation.
Attached File  121056408_10223089604966946_1583850748274630559_n.jpg   49.65K   13 downloads
Attached File  121228881_10223089604726940_261482952902862499_n.jpg   65.43K   11 downloads
#12 Ando
Ando
  • 527 posts
Posted 17 March 2022 - 12:46 PM
Eventually was given the correct measurement.
Attached File  275940386_3042297532753073_8490737856764312104_n.jpg   143.68K   11 downloads
