STROKER 6 CRANK
#1
_hypo hb_
Posted 18 February 2010 - 10:57 AM
IF SO - WHO AND HOW MUCH
#2
Posted 18 February 2010 - 12:20 PM
Grant..
#3
_beergut_
Posted 18 February 2010 - 12:43 PM
he did have a so called stroker for sale
or maybe pro stroke
#4
Posted 18 February 2010 - 12:52 PM
i am yet to see a record breaking holden 6 with a stroker crank.
prostroke weld them, theres another mob that do it.
#5
_beergut_
Posted 18 February 2010 - 12:59 PM
#6
Posted 18 February 2010 - 03:56 PM
Holden 202 Knifedged stroker crank
Says: CRACKTESTED AND BALANCED HOLDEN KNIFEDGED 12 COUNTERWEIGHT STROKER CRANK ,3.375" STROKE
THE BEST STROKER AVAILABLE FOR YOUR HOLDEN 6.NEW 5.73"LONGER H BEAM CONRODS COMBINED WITH A KNIFEDGED STROKER CRANK PROVIDE A HIGH TORQUE AND FREE REVING ENGINE.ONE OF THESE STROKERS PUSHES OUR STREET REGISTERED FJ UTE TO A 13.40sec 1/4 MILE @100mph ON PUMP FUEL USING ONLY 6300RPM
Also: SAVE $200 IF YOU EXCHANGE YOUR BLUE/ BLACK 3.3 CRANK IN GOOD CONDITION(must be less than.010 "undersize)
Doesn't say anything about supplying a ford crank for the job, so it sounds like an off-ground holden crank. Could be worth giving them a call.
Edited by Steve TPF, 18 February 2010 - 04:08 PM.
#7
Posted 18 February 2010 - 06:48 PM
Found this on Ebay:
[/quote]
you cant grind em .350 mate.
[quote name='greens nice' date='18 February 2010 - 06:48 PM' timestamp='1266482907' post='482906']
[quote name='Steve TPF' date='18 February 2010 - 03:56 PM' timestamp='1266472607' post='482841']
Found this on Ebay:
nvm
#8
_Drag lc_
Posted 18 February 2010 - 07:07 PM
or maybe just the records around the bar ...........
#9
Posted 18 February 2010 - 07:24 PM
Found this on Ebay:
nvm
Where did you get .350 from???
By my calculations thats .125", so thats only offsetting the journal .0625"
Could be totally wrong?
Posted 18 February 2010 - 07:44 PM
0.125 is the difference in stroke: 3.375 - 3.25 = 0.125. So yes, the journal would be offset by .0625. Doesn't sound unreasonable.
You would need to bore out 120 thou to get the 222 ci though. 60 though would get you 215.
Edited by Steve TPF, 18 February 2010 - 07:50 PM.
#11
_oldjohnno_
Posted 18 February 2010 - 07:58 PM
Why do you want the longer stroke? If it's a turbo engine then even a 3" engine can be made to produce much more power than the engine can contain. And if it's N/A with a Holden head then the head is going to be the limiting factor regardless of capacity - a stroker will just slide the peaks down the rpm scale a bit. For a mild street motor I guess you'd have a nice fat bottom end but for anything else I frankly can't see any compelling reason to go much more than 3-1/4".
Edited by oldjohnno, 18 February 2010 - 07:58 PM.
#12
Posted 18 February 2010 - 08:06 PM
my bad
#13
_oldjohnno_
Posted 18 February 2010 - 08:17 PM
#14
Posted 18 February 2010 - 09:01 PM
RE: caps....must have been a sale on capitals.
#15
Posted 18 February 2010 - 09:15 PM
yer sorry i didnt read the whole lot, .350 would be to get the 3.6 inch stroke? i think? that a falcon crank has.
my bad
To easy mate, yeah not it doesnt actually say what you end up with..
Steve TPF's numbers sound about right.
Posted 19 February 2010 - 05:34 AM
IIRC the ford 221 cranks can take a 186 to 235 or thereabouts - except he doesn't want a welded crank.
#17
_clubspClubsportr8ortr8_
Posted 19 February 2010 - 07:58 AM
Jeff
#18
Posted 19 February 2010 - 12:53 PM
#19
Posted 19 February 2010 - 04:08 PM
#20
Posted 19 February 2010 - 04:33 PM
Jeff
#21
Posted 19 February 2010 - 06:36 PM
#22
Posted 19 February 2010 - 09:12 PM
Well Kit Cullen cranks are $2000 and he isn't doing anymore or hasn't for a few years now but i know who has the moulds for Kit's crank but he isn't doing anything as yet because there isn't much difference in price to the custom 4340 cranks from PPM. Where does he find one maybe check the speedway guys around Brisbane.
Jeff
So when did they go up to $2000.
I paid $1360 which included machining to 186 mains, rebalancing and postage. I would never have bothered if they'd been $2000.
Crank is now in NZ.
Grant..
#23
Posted 19 February 2010 - 09:34 PM
Jeff
#24
Posted 20 February 2010 - 12:31 AM
Think oldjohnno would back me up on this one....
Edited by Bomber Watson, 20 February 2010 - 12:32 AM.
#25
_beergut_
Posted 20 February 2010 - 02:24 AM
answer cubes and low down torque
