Whats the best CAM for the street you've had, 186-202
32 replies to this topic
#1 blake
blake
  • 267 posts
  • Name:Blake
Posted 14 July 2010 - 08:23 PM
whats the best cam people have used on the street with there 186 / 202, im lookin for a big lumpy cam for my 186, but dont want it too big for the street as i want to be able to drive comfortably. something like an 'xu1'spec cam from the lc, but there fairly basic, and i want it to be loud and have heeps of lump. so please share what you have, or have had from experience.
Cheers Blake
#2 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 14 July 2010 - 08:43 PM
http://www.tighecams.com.au/cars.htm
the 150A and 392C are both magic camshafts, nice lump, good power but the 150A isnt that much of a pig.
#3 blake
blake
  • 267 posts
  • Name:Blake
Posted 14 July 2010 - 09:01 PM
Cheers for that.
Blake
#4 _Bad Blood_
_Bad Blood_
Posted 14 July 2010 - 10:04 PM
For good street driving try a 186S cam and when you want it to sound lumpy just pull the choke out abit.Posted Image
#5 _gmlj6_
_gmlj6_
Posted 14 July 2010 - 10:24 PM
i have a camtec hydraulic 248/248 336 336 i love it. needs a 3500 converter to idle in gear though
#6 _Brad1979UC_
_Brad1979UC_
Posted 15 July 2010 - 12:08 AM
A wade 1147CB cam is what I had in my 202...warm street application, it was driven daily, great street cam IMO, great idle and note, and drivability aint bad too.
INT 224 Dur@0.050" 0.4545" Valve lift
EX 232 Dur@0.050" 0.474" Valve lift
sounds like this....
really most red 6's with a big cam sound horn :D....happy I still get to hear mine sing in Briana's LJ though
#7 _Eedman_
_Eedman_
Posted 15 July 2010 - 01:22 AM
hey mate, thought i'd chime in here too.
i bought one of these for my 202.
http://cgi.ebay.com....#ht_1126wt_1137
went for a stage 2 and also got straight cut gears too.
#8 blake
blake
  • 267 posts
  • Name:Blake
Posted 15 July 2010 - 06:48 PM
thanks to people who shared there thoughts. im thinking of going with a camtech, they seem to have there act together with there technology, and customer support. who else has had experience with camtech cams, or the cheap cams from ebay?
cheers Blake
#9 _wjr2980_
_wjr2980_
Posted 15 July 2010 - 08:49 PM
I have a custom mechanical cam in my 202.
Lobe sep 107
@ 0.050 Duration Int 246 Exh 254
Valve lift Int 506 Exh 497
Very lumpy!!!
I have to run a 3800 stall. Revs to 7000rpm all day.
#10 _Squarepants_
_Squarepants_
Posted 15 July 2010 - 09:52 PM
I run a Crow 33/73 (part no. 667 I think) in my street driven 202 LH.
It's ok, idles well with a bit of a lump in it, performance is notably better than stock, you can tell when it "comes on cam" and drivability is fine with a 5 speed box.
In all honesty, I'd prefer a bigger one. I reckon a 40/80 would be a good thing, if not slightly bigger again.
Just make sure your bottom end will handle at least 7000rpm.
#11 _why-psi_
_why-psi_
Posted 16 July 2010 - 04:04 AM
Stage 5 Heatseeker :) biggest hydraulic one they made for holden 6. solid went to stage 6
was a bit of a pig to drive
#12 _clubspClubsportr8ortr8_
Posted 16 July 2010 - 11:08 AM
Stage 5 Heatseeker Posted Image biggest hydraulic one they made for holden 6. solid went to stage 6
Incorrect as Heatseeker do the HS60 hydraulic still and it is a stage 6 plus Peter still grinds custom cams to suit what ever info you give him.
#13 _tim_lxhatch_
_tim_lxhatch_
Posted 18 July 2010 - 08:22 PM
can someone tell me how the crow cams go as well. pm me if needed?
#14 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 18 July 2010 - 08:46 PM
i'd stay away for a performance application. ive seen them drop lobes and lifters not rotating
#15 _hydengineering_
_hydengineering_
Posted 22 July 2010 - 05:33 PM
I had a cam from Redlands Engine reconditioners years ago ( now closed), dunno the lobe sizes or separation, but it was a R 94, a modified copy of a Crow. It was developed for limited six sprint speedway. Torque range was 3200-7800, although I only maxed it at 6800 occasionally. 9 port benched to 320hp, triple 175's, 7/16 studs, rollers, 221 crank, zero deck height. It idled at 550 & sounded awesome through open pipes. It was a manual & had great power from idle...wish I had never parted with it
#16 Rockoz
  • 4,074 posts
Posted 22 July 2010 - 07:26 PM
Look up Waggot Cams or engineering.
Thinking they are somewhere on the NSW north coast now.
There old 30/70 cam was the ducks guts for daily drivers.
Reckon they forgotten more about red 6s than most these days know.
#17 _iwanacoupe_
_iwanacoupe_
Posted 22 July 2010 - 07:33 PM
sorry to jack the thread but while where on the subject anyone no the best cam for 186/stroker 221 crank, As far as i kno there not good for high revs so anything revn over 6 is no good. Place i spoke to about puttin motor back together recommended crow xu1 cam but ive heard a few bad things about them plus wots the point of having a cam in there thats needs to rev more than me motor can handle??
#18 TerrA LX
Posted 22 July 2010 - 09:00 PM
I will second waggots for street cams.
#19 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 22 July 2010 - 09:08 PM
you could put a boat cam in it that would pull hard as down low for the 221 stroker the cam would prob run out at 5000 tho but should still go good
#20 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 22 July 2010 - 09:35 PM
more cubes will put the rev range lower on the stroker than it would on a 202 or 186.
so the rpm range will be lower than all the listings for cams that are for a 202.
Edited by greens nice, 22 July 2010 - 09:37 PM.
#21 warrenm
  • 2,130 posts
Posted 23 July 2010 - 08:04 AM
Which ever cam manufacturer that you decide on, talk to them explain what you want from the vehicle(be honest)& what the engine specs are. Don't get a particular cam because someone else say's it was ok for them, because they may have eg. 12:1 compression & you may have 9.5, so the engine may be a dog to drive. Personally I never had much luck with Crow(they seem to pick the cam from the book, not from my info)Bert Jones,Watson cams, COME & Camtech(talk to Malcolm) I've had great success with.
#22 _iwanacoupe_
_iwanacoupe_
Posted 23 July 2010 - 11:03 PM
Hi Trevor
My experience with Strokers is limited But I do know a bit about the 235 version. It is true they don’t like big revs. 5800 would the limit. But what they lack in high rpm HP they make up with in the way of torque. Crow aren’t that bad. A bad batch of cores can haunt any cam manufacturer. I would pick a cam with 6000rpm limit in mind. You also want a fairly wide lobe separation. This spreads the power band wide to make use of the torque offered by the extra cubes. I’d use a crow 35667 cam. We have installed this cam in a 186 daily driver with one of our new SIM002 EFI Intakes. It idles well and makes power between 2500-6000. The 100 lobe separation and the high lift both help improve the cylinder filling. Cylinder filling in emphasised with the extra cubes you have. A 72 XU1 cam only has a rev range of 2500-5800, but because it relies on duration rather than lift to fill the cylinders I feel the 35667 will offer better performance in your application. I hope this info helps
this is info i got from a fella who makes main stud girdles, anyone no of a really really good holden 6 engine builder in adelaide?
#23 _2ELCS_
_2ELCS_
Posted 23 July 2010 - 11:23 PM
If you would like to change the colour of you post please we may be able to read it???
Wayne
#24 _iwanacoupe_
_iwanacoupe_
Posted 23 July 2010 - 11:30 PM
sorry fella not sure why that happened mate
#25 _2ELCS_
_2ELCS_
Posted 23 July 2010 - 11:45 PM
^^^^gremlins???
