speedo calibration links
5 replies to this topic
#1 _XU1-043_
_XU1-043_
Posted 17 September 2010 - 08:47 PM
here are some websites i came accross while i was trying to workout my speedo calibration, hope it helps people.
T5:
http://www.hanlonmot...om/t5speedo.asp
other boxes eg aussie 4 speed, powerglide ect:
http://codes.oldholden.com/Speedo/
Craig
Edited by XU1-043, 17 September 2010 - 08:58 PM.
#2 Antman
Antman
  • 26 posts
  • Name:Anton Mann
  • Car:Torana Hatchback
Posted 31 January 2020 - 06:38 PM
So If my speedo is reading low I need to swap my gear drive on my speedo cable for one with more teeth?
#3 claysummers
Posted 01 February 2020 - 06:33 AM
More teeth means the cable turns slower, so no. That will make your speedo read lower. Average number of teeth around 20, so for each increment of one tooth you change the reading by 5%. Simples.
#4 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 02 February 2020 - 11:57 AM
Those links don't work for me but heres one that has the calculator on the left on the Rare Spares site.
https://www.rarespar...edo gear&page=1
I'm changing to a 3.55 diff on my LJ with M20 gearbox.
The Rare Spares site mentions "Drive Gear" and "Driven Gear". Which one is the gearbox end and which is the dashboard end?
Does that mean I need to change gears at the gearbox and dashboard end of the speedo cable?
Edited by Gatti, 02 February 2020 - 11:59 AM.
#5 claysummers
Posted 02 February 2020 - 07:39 PM
You a re changing ratio by 15% therefore you require a driven gear with three more teeth than the one you are currently running. This assumes your current setup is reading correctly. You don't need to replace the internal driven gear, only the driven gear which sits on the gearbox end of the cable.
#6 Gatti
Gatti
  • 348 posts
  • Car:LJ 2 Door
Posted 03 February 2020 - 08:28 AM
Thanks mate
