The list as requested
90 replies to this topic
#1 _les_
_les_
Posted 02 May 2006 - 07:36 PM
m38109 RIM HEADLAMP LC RIGHT HAND
m38110 RIM HEADLAMP LC leftHAND
m38113 RIM HEADLAMP LJ 6 CYLINDER
m38114 RIM HEADLAMP LJ 6 CYLINDER LEFT
m38115 RIM TAILAMP LJ L/H
m38116 RIM TAILAMP LJ R/H
The above rim are on hold until we can find a suitable supplier and get the aluminium made at the moment we have to buy several tonne.
2805205- 2823775 lamp base front indicator lc lj
We will be releasing complete front indicator assemblies in approx 8 weeks
rust rust panels lx coupe C pillar l & r
We have failed 3 times on this project , but it is still not dead we may have another method of making them unfortunately it is at the bottom of the list late 2006 early 2007
2822470 Cap wheel centre LJ GTR Torana Black
Both the red and black have been given the go ahead about 3 – 4 months
9946440 TORANA STEERING COUPLING
On hold at the moment not enough demand and very costly to make
2818020 SUPPORT MIRROR RIGHT HAND SIDE HQ - WB LJ - UC
2818021 SUPPORT MIRROR LEFT HAND SIDE HQ - WB Ll - UC
We have given the go ahead for HQ LJ is on hold not enough demand
2822886 CONSOLE LJ 4 SPEED
On hold
2816161 FUEL CAP XU-1 BLACK
Should be available 6 weeks
SP2162 AIRCLEANER WING NUT LC LJ TORANA
Available about 6 weeks , we are also making the complete LJ air cleaner for XU-1
WRK1002 WINDOW REGULATOR REPAIR KIT LC LJ COUPE L/R
Available about 2 – 4 weeks
7426917 SUPPORT MIRROR EXTERIOR HD - HR LC LEFT HAND
7426916 Support Mirror Exterior HD-HR,LC RH
Put on hold unable to make economically
2811517 CAP FUEL LOCKING LC LJ
Have not received a sample as yet from manufacturer this may not go ahead
2820652 LENS TAIL LAMP LJ RIGHT HAND
2820651 LENS TAIL LAMP LJ L/H
First sample rejected last week only minor problem expect to be available end October
7437712BA LC LJ BLACK ARMREST
Expect sample next week
7414744 Mirror Head LC HD-HG M37742 also refers
Available around end October
7418908 WIPER MOUNTING GROMMET
Available in about 8 weeks
RP2049 REPAIR PANEL HATCH CHANNEL CORNER L/H UPPER LX
RP2049A REPAIR PANEL HATCH CHANNEL CORNOR R/H UPPER LX
RP2049B REPAIR PANEL HATCH CHANNEL CORNOR L/H LOWER LX
RP2049C REPAIR PANEL HATCH CHANNEL CORNOR R/H LOWER LX
Expected to be available late 2006
MSC2104 DECAL METRIC SPEEDO CONVERSION LC LJ TORANA GTR XU-1
MSC2103 DECAL METRIC SPEEDO CONVERSION HB LC LJ TORANA
Available
2822614 SCREW CONTACT HORN HQ - WB LH LX
Available 4 weeks
dash1 Decal set lx dash and glovebox silver
This is a decal to suit the silver dashboards and glove box lid available 5 – 6 weeks
2817737 gear knob gtr
Available 6 – 8 weeks
2825668 PEDAL PAD LH PARKBRAKE PEDAL
Available 3 – 4 months
#2 _sstorana_
_sstorana_
Posted 02 May 2006 - 08:31 PM
Thanks Les
your are legend...
mate question on this...
are these for LH/LX??
Mick
#3 _73LJWhiteSL_
_73LJWhiteSL_
Posted 02 May 2006 - 09:19 PM
Gday Les,
Any idea on when these will be avalible? I assume from above you are still organising matterial.
Also any idea of cost?
Steve
#4 dattoman
Posted 02 May 2006 - 09:46 PM
Exactly what are these ?
#5 _les_
_les_
Posted 02 May 2006 - 10:35 PM
Thanks Les
your are legend...
Mick
Mick
Yes they are they fit many other models as well
Les
#6 _les_
_les_
Posted 02 May 2006 - 10:39 PM
Gday Les,
Steve
Steve
We need a manufacturer capable of producing these rims as well as a lesser amount of aluminium, no cost until we solve these problems
Les
#7 _les_
_les_
Posted 02 May 2006 - 10:41 PM
These are the 4 corners in the hatch opening where the rubber seal goes
Les
#8 dattoman
Posted 03 May 2006 - 12:17 AM
Les
added to my shopping list
I have the lower corners via a forum member......... uppers I'm interested in
#9 _73LJWhiteSL_
_73LJWhiteSL_
Posted 04 May 2006 - 08:27 PM
Gday Les,
Steve
Steve
Les
Thanks for the reply Les.
I can wait... i have no money at the moment :cry:
Steve
#10 _les_
_les_
Posted 05 June 2006 - 06:12 PM
Sample of 7414744 Mirror Head LC HD-HG M37742 received it looks fantastic the only problem was it had Philips head screws on the back instead of straight slotted ones
#11 _lurkin308_
_lurkin308_
Posted 09 July 2006 - 07:34 PM
do you have a idea on when the lc headlight rims will be in stores
#12 _ChiaLX_
_ChiaLX_
Posted 09 July 2006 - 10:14 PM
Hi Les how are you going with these?
#13 _les_
_les_
Posted 10 July 2006 - 01:39 PM
We still do not have a manufacturer for these very doubtful the will be available this year
#14 _les_
_les_
Posted 10 July 2006 - 01:41 PM
We will have to star again with these parts, which means we will have to get another hatch to take the mould off so probably 4 months
#15 _les_
_les_
Posted 25 July 2006 - 04:04 PM
New update
LC LJ indicator assemblies or bodies about 2 -3 weeks
Back on the list
to be made about 6mths
late September
On hold
awaiting acceptable sample
Available
Delayed about 2 – 4 weeks delayed
sample rejected last week only minor problem expect to be available end November
Available this week
Available
Available
GK1007 gear knob gtr
Available
7214419 CLIP CHOKE LC LJ HEATER HK HT HG
Available 1-2 weeks
AC1000 AIRCLEANER ASSEMBLY LJ XU-1
Available 3-6 weeks
RUST REPAIR SECTION FOR BATERY TRAY SECTION LH LX
Available 4-6 weeks
LJ tail lamp gaskets
Available about 2-4 weeks
2806438 CABLE BONNET HK HT HG HOLDEN LC LJ TORANA
Available mid September
2822886T Trim surround Torana Console LC LJ
About 5 mths
L1000 LENS LC LJ DASH LARGE
About 5 mths
L1000B LENS LC LJ DASH HANDBRAKE
About 5 mths
L1000G LENS LC LJ DASH GREEN
About 5 mths
SBC1000 SEAT BELT TOP COVER LARGE
About 5 mths
SBC1001 SEAT BELT TOP COVER SMALL
About 5 mths
DSL1000 DASH LENS LH LX
About 5 mths
2806064 BOOT MASTER CYLINDER PUSH ROD DISC/POWER LC LJ
About 5 mths
2805852 GROMMET FUEL UNDERBODY LC LJ
About 5 mths
SP1982 GROMMET LC LJ INDICATOR LEAD LC LJ
About 5 mths
7427353 BUMPER FUEL FILLER DOOR LH-UC NUMBER PLATE LC LJ
About 5 mths
#16 _ChiaLX_
_ChiaLX_
Posted 25 July 2006 - 04:54 PM
You have been a busy boy! Well done. :clap: cant wait for quite a few of those parts.
#17 _les_
_les_
Posted 14 September 2006 - 07:22 PM
Here is a new up todate list of parts being made
2805205 LC LJ indicator lamp bases available
LFT1020A LC LJ indicator assembly rh amber available
LFT1021A LC LJ indicator assembly lh amber available
LFT1022A LC LJ indicator assembly rh clear available
LFT1023A LC LJ indicator assembly lh clear available
9941172 LX front seat rear panel available
724419 Clip Choke LC LJ available
7437712BA LC LJ Black armrest available
RP3005 Metal battery tray lh lx uc sample approved available two weeks
2822470 Cap wheel centre LJ GTR Torana Black awaiting first sample
Hatchback cornors tooling started avail 8 weeks
C pillar repair section to be remade avail 3 mths
LC mirror arm tooling started L & R
WRK1002 Window regulator repair kit available 6 weeks
2820652 lens LJ tail lamp tooling under way
2820651 lens LJ tail lamp tooling under way
Tail lamp gasket kits underway
2806438 Bonnet cable LC LJ awaiting first sample avail 8 weeks
Console trim LC LJ tooling being made
LC LJ dash lenses tooling being made
Seat belt covers tooling being made
LH LX dash lenses tooling being made
2805852 under body grommet tooling being made
SP1982 Grommet indicator lead tooling being made
#18 _sstorana_
_sstorana_
Posted 14 September 2006 - 09:51 PM
Les
whats the latest with these??
Mick
#19 _les_
_les_
Posted 14 September 2006 - 11:43 PM
Les
Mick
They where due this29/09/06 but we have not had shipment advice , they cannot be far away. I will try and find a delivery date but at least another 6 weeks
#20 _les_
_les_
Posted 12 October 2006 - 06:49 PM
Les
Mick
These are now in stock kit part number WM1000 set of 3 (cheaper in kit)
#21 _les_
_les_
Posted 12 October 2006 - 07:01 PM
GTL1016 Tail lamp gasket kits LJ Available
RP3005 Metal battery tray lh lx uc available
2822470 Cap wheel centre LJ GTR Torana Black First sample approved 8 weeks away
WRK1002 Window regulator repair kit available 3 weeks
2820652 lens LJ tail lamp Sample approved 6 weeks away
2820651 lens LJ tail lamp Sample approved 6 weeks away
2806438 Bonnet cable LC LJ awaiting first sample avail 5 weeks
Console trim LC LJ First sample arrived to day being tested avail 6 weeks if sample is ok
LC LJ dash lenses Sample approved available 8 weeks
Seat belt covers sample being tested
SP1982 Grommet indicator lead sample arrived to day
#22 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 13 October 2006 - 02:18 PM
I cant wait for these to be done! :D
#23 Racehatch
Racehatch
  • 1,028 posts
Posted 16 January 2007 - 10:24 PM
Hi Les,
Any news on these?
also c pillar rust repair section for LX/UC hatch
cheers,
Sam
#24 _les_
_les_
Posted 18 January 2007 - 12:33 PM
Hi Les,
Any news on these?
cheers,
Sam
Sam
Finally got an answer LX coupe corners lower about 3 weeks upper about 6 weeks pillars about 9 weeks
Les
#25 _ChiaLX_
_ChiaLX_
Posted 18 January 2007 - 01:50 PM
Jeez its a bloody long process Les. glad you are making em though. :spoton:
