Wish List
164 replies to this topic
#1 dattoman
Posted 02 May 2006 - 09:50 PM
Rare Spares website has a "wish list" section for parts people want made
If there is enough interest Les can look into possible production
Lets add to it here for us Torana peoples
Fire away boys and girls
#2 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 02 May 2006 - 10:21 PM
Still think the battery sheet metal in the LH/LX range would be popular.
Also these battery retainers are hard to come by and suit most models. I eventually tracked one down but could do with two more.
#3 _trav_
_trav_
Posted 02 May 2006 - 10:35 PM
V8 alternator brackets for aircons..hard to come by...maybe im just not looking in the right spot
trav
#4 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 03 May 2006 - 07:03 AM
I too would like to see battery sheet metal for LH/LX
#5 Heath
Posted 03 May 2006 - 07:58 AM
Battery tray for LH/LX
#6 _kangur_
_kangur_
Posted 03 May 2006 - 02:37 PM
I'll second that LH/LX battery tray motion ,its one of the first places they rust and most of them have it.
#7 _les_
_les_
Posted 03 May 2006 - 03:37 PM
Ok I got the message I have put an RFQ (request for quote) on the LH LX battery repair section, which starts the ball rolling towards manufacture as long as the figures add up. As for the clip for the battery clamp we hope to make the complete battery hold down and the clip will be apart of them.
Les
#8 _les_
_les_
Posted 03 May 2006 - 03:42 PM
trav
Trav
We do have an alternator bracket to suit LH LX V8 I do not know if they fit air con vehicles maybe someone here can tell us if they fit
Les
#9 Dangerous
Dangerous
  • 948 posts
Posted 03 May 2006 - 04:19 PM
LH/LX Toranas are prone to rusting the bottom front inner corners (open the door and look in the bottom corner, under the bottom hinge - the section from where the outer door skin folds over, right up to the first door trim locating hole behind the corner of the door trim). Also, the bottom horizontal section of the doors.
The bottom front corner would be a little difficult to reproduce due to its 3 D shape, but the bottom of the door (the flattish sectioned panel which the door seal runs along) wouldn't be too hard to make. It would be nice if the locating holes for the door seal would be included as well. The parts are the same for the hatch and sedan door, with the hatch door bottom section only needing to be longer.
For LC/LJs, the lower inner front guard panel that sits right behind the front wheels. They have a bad habit of rusting out, and they need to be made accurately to stop dirt and water getting past them and collecting inside the guard.
#10 _the gts_
_the gts_
Posted 04 May 2006 - 11:44 AM
The grommet that goes between the steering column and firewall on LH-LX. They always turn to S**t from the hot exhaust. nothing worse than letting the heat in the car on a hot day
Edited by the gts, 04 May 2006 - 11:46 AM.
#11 _lx5008_
_lx5008_
Posted 04 May 2006 - 12:35 PM
DEAR LES.
can you see if you can remake a complete A9X im sure you will sell a few lol.
#12 _les_
_les_
Posted 04 May 2006 - 06:09 PM
We make these for HQ Doors, I will put them on the wish list as well as the inner panels for LC LJ
#13 _les_
_les_
Posted 04 May 2006 - 06:12 PM
I have put them on the wish list
#14 _les_
_les_
Posted 04 May 2006 - 06:14 PM
DEAR LES.
I will try and have some by Monday
#15 Toranavista
Toranavista
  • 2,862 posts
Posted 04 May 2006 - 07:23 PM
Ok my last wish! How about a base for the stove pipe on the Holden V8 motor. Most folk are now running extractors. I know you can weld a piece of water pipe onto the top of the extractor but seems a bit dodgy. I am suggesting a base that can be bolted using the extractor bolt. Would need the piece of pipe connected to a thin strip of metal and then a Y shaped prong. Not sure on demand.
#16 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 04 May 2006 - 09:22 PM
How about the 6 x rubber cup/grommet thingy's that go under the windscreen cowl stubs on LH (hope that all makes sense), are these avail?
#17 Heath
Posted 04 May 2006 - 09:31 PM
I think you're saying something in relation to rusting out in the plenum chamber/upper firewalls but I can't picture what you're referring to.
#18 _sstorana_
_sstorana_
Posted 04 May 2006 - 10:03 PM
racean69
I believe that you are referring to the ...
Seal Grille, GP 10.307 Pt No: 2823932
and I agree.. these would be a nice addition to the list
Mick
#19 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 05 May 2006 - 12:22 AM
Hi Les
I really think LJ/LC 2 door door skins and or entire door shell would be bloody great, its hard to find good doors for a 2 door and if you find them theyre boged to the shit house and rusted most of the time :cry:
Anyway see what you can do mate.
Another thing, did you know in the USA they are doing reproduction 1968 Camaro entire body shells and fender/quarters?? :D wink wink hehehe just thought i would say that
Edited by Bart, 05 May 2006 - 12:22 AM.
#20 _les_
_les_
Posted 05 May 2006 - 07:04 PM
I will add it to the list but I am a bit doubtful it will go ahead.
#21 _les_
_les_
Posted 05 May 2006 - 07:15 PM
Mick is correct they are part number 2823932 and I am sure I have seen them somewhere or at least something that looks very close. Are they made of rubber or plastic and does anyone have a sample
Les
#22 _les_
_les_
Posted 05 May 2006 - 07:19 PM
Hi Les
If we had the population of the US those door skins would not be a problem maybe even door shells, I will add them to the list and we will see what happens.
Les
#23 Heath
Posted 05 May 2006 - 07:43 PM
That's what its all about ey. The size of the market here just isn't comparable...
think of it another way; if we did have a huge population then there would be more demand for everything we want.... and the prices would skyrocket :rolleyes:
#24 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 05 May 2006 - 07:48 PM
If there were more of them around (hence, more demand) then they wouldn't be so special.
Edited by smeer, 05 May 2006 - 07:49 PM.
#25 _les_
_les_
Posted 05 May 2006 - 07:58 PM
Actually the more demand means that the tooling can be amortised over a greater number the therefore the price would be cheaper. If the tooling cost $10,000.00 for a part and you expect to sell 1000 then before you start the part has cost $10.00, but if you expect to sell 10,000 then the initial cost is $1.00
