Front Suspension Problem LC GTR
#51
_CraigA_
Posted 04 October 2011 - 09:57 PM
I'd be setting up an equi distant string line down each side of the car and take some measurements with the wheels off. I reckon you'll find it much quicker and certainly easier than pulling parts on and off.
Such a good looking build, keep at it, solve the problem and all this will be a distant memory once you start driving it.
#52
_Macka_
Posted 04 October 2011 - 10:01 PM
<br /><br /><br /><br />What you say makes sense S Pack. <br /><br />I'd be setting up an equi distant string line down each side of the car and take some measurements with the wheels off. I reckon you'll find it much quicker and certainly easier than pulling parts on and off. <br /><br />Such a good looking build, keep at it, solve the problem and all this will be a distant memory once you start driving it.<br />
Craig so you mean like a plum bob thingy From the top of the guard and then measure the distance between the line and the stub axle?
#53
I noticed it appears the disc rotor on the passenger side sits closer to the caliper mounting pad than the rotor on the drivers side.
Maybe just a camera angle thing
Another thing you could try if your keen to pull it all apart again is fit the original stubs back on and see what you get.
Taking measurements as Craig has said will be easier though.
Edited by S pack, 04 October 2011 - 10:10 PM.
#54
_Macka_
Posted 04 October 2011 - 10:09 PM
<br /><br /><br /><br />Just looking back at the close up pics of the left and right lower control arms. <br />I noticed it appears the disc rotor on the passenger side sits closer to the caliper mounting pad than the rotor on the drivers side.<br /><br />Maybe just a camera angle thing <img src='http://www.gmh-toran...lt/dontknow.gif' class='bbc_emoticon' alt='
' /><br />
Thanks I haven't looked at that so will measure tomorrow.
#55
Posted 04 October 2011 - 10:28 PM
thatll eliminate one variable
#56
_robslxhatch_
Posted 05 October 2011 - 06:13 AM
you may be able to just fit one original stub to the right hand side and see if it moves the wheel back inside the guard.
#57
_CraigA_
Posted 05 October 2011 - 05:44 PM
Now just pick some suspension reference points. Upper control arms should measure even to each side. The distance to the end of each stub should be identical
Check other points until you find your problem.
#58
_Macka_
Posted 08 October 2011 - 07:23 PM
_CraigA_
Posted 08 October 2011 - 07:28 PM
What a top looking GTR. Very rarely do later wheels suit older cars but to me that's perfect.
#60
Posted 08 October 2011 - 10:30 PM
Goods news. At least you did correct some other issues along the way to finding the solution.
+1
Hey Macka, you shouldn't need to apply heat to roll the front guard lips.
Did mine, with no damage to the paint, with a rag, some masking tape, a block of wood and a urethane headed mallet.
Just have to work the lip over slowly and keep moving along with each bump.
#61
Posted 08 October 2011 - 10:53 PM
390mm on the passenger side and 384/385mm on the drivers side (measured directly above the centre line of the stub axle)?
Dave.
#62
_Macka_
Posted 09 October 2011 - 09:13 AM
<br /><br /><br /><br />Just out of interest what measurements did you get when you first measured from the chassis rail to the face of the guard wheel arch?<br />390mm on the passenger side and 384/385mm on the drivers side (measured directly above the centre line of the stub axle)?<br /><br />Cheers<br />Dave.<br />
Um I think so?? Was more caught up in the difference however I am fairly sure that was it. I tightened the radius rods, shimmed it up more and evened up the toe in/out. Then we applied some force. I pulled on the wheel arch while someone else pushed the bottom of the panel in. Did it gently but we certainly got 5mm or so. So now they are close. So with new brake set up that will bring track in 14mm each wheel and then maybe a light roll of the inner guard lip if we need more. So l am confident we are home, fingers crossed.
