#1
Posted 10 June 2012 - 05:24 PM
Not too happy with the fit of it all.
Firstly the hub that they supplied doesnt fit correctly, the bearing races inside are 2mm closer together than the standard hubs (48mm UPC, 50mm holden) and just to check that my hubs arent different i pulled apart a holden trailer hub and that measured the same as the standard ones.
This means that the outer (smaller) bearing bottoms out on the stub axle, not allowing me to tighten the nut up enough. I tried using an extra washer on the outside, hoping to space up the gap, thinking that the nut was running out of thread, but this didnt help, as the bearing was bottoming out.
Secondly the calliper mounts needed a reasonable amount of grinding to both it and the stub to get it to fit properly. The sellers firstly claimed that this didnt need to be done at all, and then in later emails said of course it needed to be done. This wasnt so much of a problem as it was just annoying.
The people selling the kit havent been very helpful with it simply asking me to check everything even after stating to them that everything else is in order and the same as original. Even after giving them measurements of everything they wont accept that their hub is wrong, as they "have sold thousands and never had any problems" and that they fit perfectly on his 3 toranas.
Has anyone got any ideas of how to get around this problem? My next step i think will be having to machine the shaft the outer bearing sits on a couple of mm inwards.
#2
Posted 10 June 2012 - 05:38 PM
You may be able to press the bearing shells out and fit shims behind the bearings. I think your best option would be to return the hubs. If they won't play ball then get consumer affairs and eBay involved.
The bearings are around 53 mm apart on the Hoppers VT hubs.
Edited by ls2lxhatch, 10 June 2012 - 05:47 PM.
#3
Posted 10 June 2012 - 06:06 PM
#4
_LXSS350_
#5
Posted 10 June 2012 - 06:16 PM
#6
Posted 10 June 2012 - 06:31 PM
That's how most diff pinion bearings are set up, as long as the shim is square that should be perfectly safe and give a suitable result. Doesn't change the fact that it shouldn't be a problem, but I'm sure you could resolve it this way if it comes to it.You may be able to press the bearing shells out and fit shims behind the bearings.
#7
Posted 11 June 2012 - 08:19 PM
#8
Posted 11 June 2012 - 10:30 PM
To dattoman i figured i could save 500 bucks over the hoppers kits and most of the later posts seemed to agree that the problems had been overcome.
Cheers ls2lxhatch for the measurements of the vt ones.
Ill try to get some photos of the measurements of the stubs and hubs when i get some time but am working a fair few hours so it could be a couple of days at least.
When i bring up that the hub might be machined wrong the only reply i get is that it cant be because hes sold heaps of kits.
#9
Posted 12 June 2012 - 12:44 AM
#10
_robslxhatch_
Posted 12 June 2012 - 07:28 AM
Also tagged with one or more of these keywords: brake, UPC, big, disc, hub, conversion, upgrade
Holden Tech →
Brakes, Wheels and Tyres →
LJ Brake booster optionsStarted by salamiman , 26 Sep 2025 |
Holden Tech →
General HB-LC-TA-LJ →
Disc brake conversionStarted by VerdoroLC , 18 Jun 2024 |
Holden Tech →
LJ Standard disc Brake ImprovementsStarted by salamiman , 05 Dec 2023 |
Holden Tech →
brake boosterStarted by dacastle , 02 Aug 2022 |
Holden Tech →
General LH-LX-UC →
ls1 againStarted by jonty , 16 Nov 2021 |
