#1
_greg2240_
Posted 05 August 2012 - 02:08 PM
#2
Posted 05 August 2012 - 03:52 PM
#3
_greg2240_
Posted 05 August 2012 - 07:46 PM
#4
_hqlden_
Posted 05 August 2012 - 08:02 PM
#5
Posted 05 August 2012 - 08:08 PM
#6
Posted 05 August 2012 - 08:32 PM
the inspectors more around a lot so what may pass there one week won't the nextI've heard Kelmscott is a good place to go for licensing
depends who you get on the week/month
contact dpi they have a list of guidelines and engineers
#7
_niterida_
Posted 05 August 2012 - 08:54 PM
go see Dan Pitic - he did my 4WD Starwagon with V6 Commodore motor and it couldn't have been easier
#8
_hqlden_
Posted 05 August 2012 - 08:58 PM
#9
_alchemist_
Posted 06 August 2012 - 12:52 AM
I'd highly recommend Sam Rossi from Rossi Mechanical Engineering on 0411 133 588, his work is tops and has done various Torana's over the years.
#10
_greg2240_
Posted 06 August 2012 - 11:44 AM
#11
Posted 06 August 2012 - 05:20 PM
You will find all the rules here.
http://www.infrastru...n/vsb_ncop.aspx
The standard procedure is to fill in an application to modify a light vehicle and get approval in principal for the modifications. The approval in principal will list what items require engineer certification.
http://www.transport...nsing/20500.asp
#12
Posted 12 August 2012 - 04:15 PM
The forms will come back outling details they want to see and a list of engineers certified by the transport dept. there scattered all over perth.
Then you can ring up one of those engineers and discuss what he wants to see eg. strength of components, and at what stages of the build he wants to inspect it. when engineer is happy, he signs off.
you then send engineers paper work to the transport dept. then you can get it inspected at pits.
a few friends and myself have been through the process.
I`ve heard dan pittic is good to use, he is on the list. I have used jack apgar a few times, he has been quite helpful also, to myself and some friends.
hope this helps you.
#13
Posted 12 August 2012 - 04:27 PM
Edited by Quagmire, 12 August 2012 - 04:28 PM.
#14
_greg2240_
Posted 12 August 2012 - 05:36 PM
Also tagged with one or more of these keywords: uc
Holden Tech →
Interior →
UC dash removalStarted by ellsie28 , 22 May 2020 |
General →
General Discussion →
What suspension set up is this.Started by _Daryl34_ , 20 Jun 2019 |
Holden Tech →
Brakes, Wheels and Tyres →
UC rear brake drumsStarted by _Markxvt_ , 14 Nov 2018 |
Holden Tech →
Suspension & Steering →
Removing Upper Control Arms LH Torana - Installed UC onesStarted by _spacechumper_ , 30 Dec 2017 |
Holden Tech →
Steering ArmsStarted by _HDT05_ , 31 Jul 2017 |
