Removing dents from and straightening stainless trim
#1
_judgelj_
Posted 24 September 2012 - 04:24 PM
I tried using a punch (bad idea), pinched the drip tray trim which has a curved profile. This may work on the square profile trims below the windows on the door but i have not tried. I'm thinking there are dollys for the job but i'm not sure and can't trial and error my only set. Suggestions on tooling and work surfaces would be good too!
Cheers in advance
#2
Posted 24 September 2012 - 05:38 PM
I have used small hardwood blocks in the past to use as a drift from behind.
This is a highly skilled task,good luck with it.
#3
Posted 24 September 2012 - 05:39 PM
#4
_judgelj_
Posted 24 September 2012 - 06:45 PM
I was told about nylon hammers of some sort but then again these are very delicate pieces and would not need a big hit to get them straight. The bloke who restored my grille got the dents out without a sign of them every being there i cannot believe it. I always thought there is a crease left by any panel beating no matter what as the metal stretches and does no contract.
#5
_Pete_
Posted 24 September 2012 - 07:51 PM
#6
Posted 24 September 2012 - 07:53 PM
Edited by Ruts, 24 September 2012 - 07:54 PM.
#7
Posted 24 September 2012 - 08:15 PM
#8
_judgelj_
Posted 24 September 2012 - 09:53 PM
Will give them a watch but im already starting to form some ideas in my head. I think one of the blokes here made a tool to do it but i dont think i have the patience.
#9
Posted 25 September 2012 - 09:34 AM
Check out this tool.
www.youtube.com/watch?v=AhlG44GxVzg
s
Edited by StephenSLR, 25 September 2012 - 09:39 AM.
#10
_judgelj_
Posted 25 September 2012 - 03:32 PM
#11
Posted 25 September 2012 - 04:52 PM
#12
Posted 25 September 2012 - 05:23 PM
#13
Posted 25 September 2012 - 05:27 PM
he looks to be pushing pretty hard, i don't know how this doesn't stretch the metal?
I think he means in comparison to other methods where you have to beat a much larger area.
Not sure why the vid didn't work in my link.
s
#14
Posted 25 September 2012 - 05:34 PM
Strange thing to say to begin with isn't it, its not much good if you can't stretch the metal with it (when desired). There are heaps of things like this out there but you can get the same results by hand with a hammer and some sort of tooling that doesn't cost you each time you need a different shape - scrap steel is free and its not hard to make almost anything you need.i don't know how this doesn't stretch the metal?
#15
_judgelj_
Posted 25 September 2012 - 09:29 PM
#16
Posted 26 September 2012 - 06:52 AM
Obviously its a nicety that would be useful in a situation where its difficult to control the force applied and this allows a bit more control and finesse. I don't think its necessary though as it can still be done with a hammer and punch (or suitable custom shaped "tool").
#17
Posted 26 September 2012 - 09:00 AM
My guess is there'd be one or two shapes that you'd use the most and having another shaped piece at the ready would be more convenient than spending time to make up something custom.
s
#18
Posted 26 September 2012 - 11:28 AM
#19
Posted 26 September 2012 - 01:14 PM
we're happy to spend 10-15 minutes making something so that the end result is as close to perfect as possible
That's what it's all about.
s
