Plastic that cover headlights on race cars
brock race torana headlights a9x slr5000 race car
29 replies to this topic
#1 _Dazza_crabb_
_Dazza_crabb_
Posted 21 January 2013 - 11:17 AM
Hi I was wondering if anyone knew where to get the plastic covers for headlights that you can see on the A9X race cars from Brocky's era. If so how are they mounted. I have attached a picture with them on it. Cheers
#2 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,675 posts
  • Car:LJ GTR
Posted 21 January 2013 - 05:36 PM
Those look like the Aunger covers that had steel clips, Doubt they would still be available, But easy enough to make your own and use small pieces of velcro to hold em on......
#3 _Waldorf_
_Waldorf_
Posted 21 January 2013 - 06:51 PM
its 3mm perspex with white vinyl stripes applied....from the look of the pic its attached with long screws that would also hold the head light surround in place.
Probably cost around $50 to make......easy as.
#4 _Yella Fella_
_Yella Fella_
Posted 21 January 2013 - 08:07 PM
They had metal clips that you first mounted through the mounting holes for your headlight surrounds. You then applied two screws in the top and one in the bottom to the steel (chrome) strips. Race wreck they are just screwed into the surround in four places, but the car was like that when I got it, less the lenses.
The transparent acrylic for Yella tinge cost a whopping......... $17.
Alternatively, drop into Autopro, and pick up some 7" acrylic dome headlight protectors. Yella has them, just fit over the headlight, and cheap as chips. Most people can't even tell they are on there. Much nicer solution. Just have a look at the pair before you buy them, as some have a horrible glob of plastic in the middle from casting.
From memory those one pictured were made by Aunger. I always wanted a pair for my Torrie as a young bloke!!!
Edited by Yella Fella, 21 January 2013 - 08:10 PM.
#5 rodomo
Posted 21 January 2013 - 08:09 PM
Glad wrap?
#6 A9X
Posted 22 January 2013 - 12:33 AM
I have an unused set for lh lights if anyone is chasing a set
#7 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 22 January 2013 - 10:13 PM
Is there a difference? The surround outer shape and mounting is the same isn't it?
Grant..
#8 A9X
Posted 22 January 2013 - 10:25 PM
Rectangle LH, square LX grant
#9 dattoman
Posted 22 January 2013 - 11:58 PM
Aunger used to list different part numbers for them
But I guess LH 4 cyl and L34 would be the same as LX being round
And LH square lights would be different
#10 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 23 January 2013 - 05:57 PM
Last set of LH surrounds I had were within a hair of the same outer dimensions.........
Did they change their pressing at any time?
There is also a non-Aunger brand that you screwed into the outer rim of the surround.
#11 Dr Terry
Dr Terry
  • 3,359 posts
Posted 23 January 2013 - 06:22 PM
I agree, there wouldn't be much difference in the outer rim size of the 2, if any.
Also the 2 other brands that made headlight covers back then were Metrix & Cyplas.
There were many variations, black stripes, white stripes, no stripes & many types of fixings.
Dr Terry
#12 _Bomber Watson_
Posted 23 January 2013 - 06:24 PM
The plastic mounting clips are in different spots.
#13 A9X
Posted 23 January 2013 - 08:32 PM
These are aunger in the original box.
I'll dig it out for some pics
#14 _rob350hatch_
_rob350hatch_
Posted 23 January 2013 - 09:39 PM
forget it.but you never know your luck i guess.i even rang heaps of old country servos with spare parts but none to be found .i just used perspex got it cut to size and then carefully drilled 2mm or 2.5 mm holes thru both the perspex and the surround and gently screwed them on with phillips head self tappers.it worked a treat.i only used 3 screws which you can just make out.you should be able to get a film to stick over the perpex to replicate the lines and aunger sticker.as for clips these appear to be similar to the ones that hold front door windsheilds on so if you see one at the wreckers grab it for the clips.
any sign writer should be able to do these for you.
Attached File  055.JPG   93.41K   14 downloads
Edited by rob350hatch, 23 January 2013 - 09:48 PM.
#15 _Matvex_
_Matvex_
Posted 23 January 2013 - 09:48 PM
Hi Welby, would you mind PM ing your asking price for the set?
#16 _Yella Fella_
_Yella Fella_
Posted 29 January 2013 - 05:40 AM
These were in progress in the last thread. Just coloured acrylic, the surrounds already had four self tapper holes in them, so I just reused them. Grand total of acrylic.....$17. Was the last bit, so I had to be a bit economical with the size.
I used some tiny little self tappers, which I presume came of the UC we stripped. Dunno, but there were ten of them, I only needed 8!!!! Winner.
Looked at Yella yesterday, and meant to take a pic of the plastic domes. They are ace too. I have a couple of spares in the shed that I can take pics of, as I got two sets to get perfect lenses.
LH-LX, absolutely no difference in the surrounds. I have a square set for Yella if I feel original one day in the future. The only difference is that the plastic screw in block at the bottom is longer, other than that, not a mm of difference in the outside profile.
Edited by Yella Fella, 29 January 2013 - 05:46 AM.
#17 _rob350hatch_
_rob350hatch_
Posted 29 January 2013 - 07:02 AM
i was trying to save weight i only used 6.
#18 _Yella Fella_
_Yella Fella_
Posted 29 January 2013 - 08:15 PM
Damn it, you are going to be 0.0000001s faster than me now!!!!
#19 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
Posted 30 January 2013 - 12:38 PM
Thought so.
Thanks Pat.
#20 _sstorana_
_sstorana_
Posted 30 January 2013 - 01:06 PM
As I have original Aunger ones here, there were two types.
LH: P/N H102, and
LX: PN H130
there is approx a 10mm height difference between the two. Width is the same.
Attachments wise, the differences were;
LH: 3 holes per cover. Screws were installed directly into the headlight surround, and
LX: 4 Holes per cover. Screw and brackets used that would attach to the outer edge or the headlight surround.
It was something that we were looking at redoing, just not sure what the demand wouild be like though.
Mick
#21 A9X
Posted 30 January 2013 - 04:04 PM
knew mine where different :)
#22 ReplicarSLR
ReplicarSLR
  • 518 posts
Posted 30 January 2013 - 05:24 PM
Just out of curiosity, why did they put the white lines on them though? So you could see that they were there?
Edited by ReplicarSLR, 30 January 2013 - 05:24 PM.
#23 _sstorana_
_sstorana_
Posted 30 January 2013 - 07:17 PM
:dontknow: :dontknow:
Who knows... they also have the part no and teh aunger logo on them as well.
#24 A9X
Posted 17 March 2013 - 01:38 PM
aunger LH covers as promised http://www.gmh-toran...lh-parts/page-4
#25 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 18 March 2013 - 01:18 PM
You could also get perspex number plate covers and for some reason the trend was to put black horizontal lines on them.  No. plate covers are illegal these days right?
s
Also tagged with one or more of these keywords: brock, race torana, headlights, a9x, slr5000, race car
