oils
gearbox diff
3 replies to this topic
#1 _blair_
_blair_
Posted 10 July 2013 - 03:21 PM
hi, i have a 1973 lj torana with a 5 seed manual borg warner gear box in it what sort of oil should i be putting in it? the gearbox is quite noisey also what diff oil should i be putting in it? i beleive it has the stock diff in it cheers
#2 dattoman
  • 16,493 posts
Posted 10 July 2013 - 08:48 PM
BW T5 uses dextron trans fluid usually
But might pay to check
If its noisy its probablt due a rebuild
75-80 or 80-90 Castrol gear oil for the diff assuming its not LSD
#3 _LS1 Hatch_
_LS1 Hatch_
Posted 11 July 2013 - 07:47 AM
Yep, when I put a T5 into my old Charger it said to use ATF right on the trans from memory.... (My T56 uses it as well..)
#4 hrpremier6667
hrpremier6667
  • 10 posts
  • Name:Wayne
  • Car:UC
Posted 11 July 2013 - 05:52 PM
Is it a T5 or earlier B.W. out of earlier commodore.
Also tagged with one or more of these keywords: gearbox, diff
