which gear box?
lj torana gearbox borg warner celica
13 replies to this topic
#1 _blair_
_blair_
Posted 13 October 2013 - 05:52 PM
hey, I broke my 5 speed borg warner gear box today stripped the gears its running in my 1973lj torana with a worked 202
what gear box should I replace this with so it doesn't happen again? im also thinking of changing the diff so I can get better top end the current diff gets very loud at about 140km and vibrates quite a bit. what gear box/diff combination should I get? the gear box must be manual. the car is owned by a 19yr boy so it does get thrashed so need strong parts
cheers blair
#2 _blair_
_blair_
Posted 13 October 2013 - 05:57 PM
not the best photo but this is the gear box I took off the car
#3 Ice
  • 15,222 posts
Posted 13 October 2013 - 06:14 PM
All depends on budget
#4 _blair_
_blair_
Posted 14 October 2013 - 03:49 PM
1000 bucks nz would be the most id wanna spend but if im dreaming then I could go more. would rather do it once and do it right than take the cheap option
#5 Ice
  • 15,222 posts
Posted 14 October 2013 - 08:15 PM
$1000 aint gunna get you far might cover a diff
if you change gearbox you will need to change everything to suit the new gearbox get another $2000 depends on what gearbox you get
#6 kiwi-lilj
kiwi-lilj
  • 1,429 posts
  • Name:Blair
  • Car:LIL J
Posted 14 October 2013 - 08:55 PM
Try and find a Toyota 4 speed. They are not very popular so can be cheapish. I had one when I was your age and used to hell toe it all over town and it loved the torture.
#7 _blair_
_blair_
Posted 15 October 2013 - 03:46 PM
ive found a celica 5 spd box
#8 Ice
  • 15,222 posts
Posted 16 October 2013 - 11:15 PM
Now you will need a bell housing to suit 202 there goes $ 500
and all the rest of the parts for this conversion
#9 kiwi-lilj
kiwi-lilj
  • 1,429 posts
  • Name:Blair
  • Car:LIL J
Posted 16 October 2013 - 11:26 PM
Rubbish, you can pick them up 2nd hand for a lot cheaper than that.
#10 Ice
  • 15,222 posts
Posted 16 October 2013 - 11:51 PM
I was talking new thanks
#11 _blair_
_blair_
Posted 17 October 2013 - 02:56 PM
I got 2 boxes 2 bell housings and a drive shaft for $500 one of the bell housings is off a holden motor aswell so that should bolt straight on. just need to work out what needs to be done to my drive shaft, how to get the clutch working (whats the best to go for cable, hydrolick or rod) and then get the speedo working
and alter my cross member to suit new gear box
#12 Kirk
Kirk
  • 843 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 17 October 2013 - 07:50 PM
Blair would you like a photo of the cross member
#13 _blair_
_blair_
Posted 18 October 2013 - 12:36 PM
yes that would great thanks kirk. would you be able to get some measurements aswell? how have you found the gear box in your car? was it a good upgrade?
#14 Kirk
Kirk
  • 843 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 19 October 2013 - 02:43 PM
Blair hope this helps
Its 70 mil from the bottom of the plate to the rule in pic 3 and its made of half inch plate.It was custom made
Also tagged with one or more of these keywords: lj torana, gearbox, borg warner, celica
