yellaterra or not
70 replies to this topic
#1 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 31 October 2013 - 08:58 PM
these are the numbers, first set A291,  then 2815843, h5Attached File  ljzedded 036.jpg   561.62K   6 downloads
#2 _Skapinad_
Posted 31 October 2013 - 09:03 PM
Xu1 head, even better !
#3 _Bomber Watson_
There the factory castings, its a high comp...
Shot of the ports, valves, and the back of the cylinder head will help....
#4 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:13 PM
hi bomber,gonad gobbler,ports are std,and valves no markings,me mate reckon its yellaterra, my old one had a pipe through the gut of the inlet,i will put another pic up
#5 _Bomber Watson_
Posted 31 October 2013 - 09:19 PM
Just because its Yellow doesnt make it Yellaterra, smack your mate upside the head.
Adam appears to be right, pretty sure thats the xu-1 number.
#6 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:21 PM
Attached File  ljzedded 037.jpg   584.94K   4 downloads
Attached File  ljzedded 039.jpg   581.68K   3 downloads
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:24 PM
yep done it didnt like it,hes sayin whats the xu-1 number,will i smack him again,he just went out the door
#8 _Bomber Watson_
Posted 31 October 2013 - 09:28 PM
LOL.
#9 kiwi-lilj
kiwi-lilj
  • 1,430 posts
  • Name:Blair
  • Car:LIL J
Posted 31 October 2013 - 09:31 PM
Is a yellow terrible head a holden head modified by yella terra or did they cast their own ?
#10 _Bomber Watson_
Posted 31 October 2013 - 09:38 PM
Mostly holden heads modified, but they did cast some.
#11 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:41 PM
they cast tere own didnt they
wernt the first ones with nothin on the valves and the guts missin out of the inlet with the head bolt in there
#12 Kirk
Kirk
  • 843 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 31 October 2013 - 09:44 PM
Didnt the XU1's come out with 12 port heads?
#13 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:45 PM
what will i do with it toss it
12 ports are 80s arnt they
#14 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:49 PM
far as i know xu1 would of been 9 port?
#15 dattoman
Posted 31 October 2013 - 09:51 PM
12 port came out for Commodores
All reds are 9 I think
Most YT heads are just old castings... not new fresh stuff
#16 _Bomber Watson_
Posted 31 October 2013 - 09:53 PM
Datto is correct.
THere was never a red motor with a 12 port.
There are a few butchered bastardized 9 ports with port dividers, but was never factory.
YT had various stages, Stage 2 which looks similar to what you have there, Stage 3 which was the inlet divider removed and a steel pipe pressed in instead, these were both factory GMH castings.
Afaik YT never supplied heads with the inlet divider totally removed and the bolt in the bottom of the port. Keep in mind YT isnt the only company to ever have a play with these.
YT did cast several heads, in both cast iron and aluminium, but these are easy to pick from an origional one, what you have there sir is not one.
If your going to toss it, i will pay freight and chip in $100 for packaging and your time if you feel like sending it to me.
Personally if i was you i would sell it....
Edited by Bomber Watson, 31 October 2013 - 09:56 PM.
#17 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:54 PM
how did gonad come up with xu1 head,is it the first no i said or the second set
#18 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 09:57 PM
tell me what it is first,and dont make it up lol
#19 dattoman
Posted 31 October 2013 - 09:59 PM
http://www.gmh-toran...ead-cast-dates/
#20 _Bomber Watson_
Posted 31 October 2013 - 10:01 PM
TMK A291 is the date code and 2815843 is the product code for a XU-1 head. Which year im not sure, not that into them.
THe fact that the valves are obviously oversized but the ports look relatively untouched somewhat confirms this.
I would be removing the rocker cover and having a good look if i were you, then cleaning it up and putting it on ebay/gumtree/whatever.
Or post it to me and i will do it :P
#21 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
its not a willow head is it,fake
#22 rodomo
Some discussion here, same topic. http://www.gmh-toran...lla-terra-head/
#23 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 31 October 2013 - 10:03 PM
lol ,me mate is jumping up and down again should i smack him harder
#24 _Bomber Watson_
Posted 31 October 2013 - 10:05 PM
So long as he doesnt take the head off you then yeah, sure.
And start prepping your ebay add :D
And check the engine number of the block while your going....
#25 Ice
As much as i hate to say it the gobbler is correct
