300mm floating disc UPC hub BA calipers
brakes upgrage lx hatch
7 replies to this topic
#1 _2Much_
_2Much_
Posted 12 May 2014 - 09:33 PM
My hatch has been off the road for 10yrs its time to bring her back..
Need some help with the front brakes, I've read every post on brakes back to front inside out
cant find the right info
What i've got
300mm VT discs 85mm offset
BA ford calipers
UPC hubs ( i know i know wish i read the UPC posts earlier)
HQ stub axles
LX steering arms ( I know about the bump steer )
Has anyone fitted this setup before ??
Dan
Attached File  PSC0002.jpg   286.52K   6 downloads
#2 _2Much_
_2Much_
Posted 14 May 2014 - 08:46 PM
I've answered my own question on this one...
YES YOU CAN
After removing about 10-15mm off the top bump stop everything fits, turn the rubber bump on the lower arm a few degrees inward and re drill the dowel hole
Happy Days
#3 _sbc57lx_
_sbc57lx_
Posted 15 May 2014 - 01:17 PM
Nothing wrong with UPC hubs ,,  A9X steering arm should help with the bump steer.   ( should be still available at Harrop Engineering ).
  Is it possible to see photo of that set up,?   curious about the fitment of BA calipers
#4 _2Much_
_2Much_
Posted 15 May 2014 - 07:16 PM
Yeah the hubs are Killer, steering was perfect never had any issues with bump..
Still have to relieve the Top and front edge of the caliper same as UPC does
#5 _Bomber Watson_
Posted 15 May 2014 - 07:18 PM
Funny looking floating disk.
#6 _2Much_
_2Much_
Posted 18 May 2014 - 12:37 PM
Yeah Ford funny, bought them from DBA 130 a pair Re-Drilled done
#7 ls2lxhatch
Posted 18 May 2014 - 01:57 PM
Bomber was pointing out that you do not have floating discs, your disc and rotor carrier are one piece.
A floating disc has a separate rotor carrier or hat. A floating disc is able to move independently of the rotor carrier once assembled.
Edited by ls2lxhatch, 18 May 2014 - 02:00 PM.
#8 _2Much_
_2Much_
Posted 19 May 2014 - 12:52 AM
My bad... i'll get the terminology rite eventually
Hub with a separate disc assembly  "the round thing"
The first disc's i got had the wrong offset, followed by the BA calipers
Neil said they wouldn't fit,..Perfect more good news
Anyway the brakes worked out fine no drama... finished    :spoton:
and....... it all fits  :bliss:
Also tagged with one or more of these keywords: brakes, upgrage, lx, hatch
