Hey all,
Finally i've had enough time to hit the keys again to show you what's been happening behind the scenes.
Picked up a cheap 1989 BMW E30 318i that was destined for a life less boring & decided to get busy.
The plan was always to drop my 202 from the EH into it, so while i was using that engine, I got to work on the rest of the car. So far it's copped a complete stripping of trim, a 5 stud rear conversion, new rear shocks, springs & mounts, discs, pads & caliper rebuilds. The front end can wait for now until I know how it will sit with the engine in place.
Diff ratio will be the shortest I can possibly go with the small case E30 diffs, 4.45.
Picked up a couple of 15 x 7 beemer rims that will have some ET Street 235's fitted shortly & the fronts will stay as the 14 x 6 for now too.
Got an RCI racing seat & 5 point harness to bang in, aswell as a line locker.
The idea is to keep things to a minimum, so even the spare wheel tub was cut out, which i will plate with some thin alloy. Also the brake booster has been ditched & the master cylinder will now be mounted on the drivers side on the firewall.
I began to dummy up another engine to check the fit & its pretty good, i think...
With an EH sump fitted, it actually sits on the crossmember at the middle step of the sump and with good clearance to the firewall for the pipes, trans & head etc...
My question is, should i recess it back into the cabin while i have the chance now??
I'm thinking like 6 - 8 inches into the cabin, but then getting to the carbs may be an issue, aswell as everything else that is...
Here's a few shots for you anyway, more to come.
040.JPG 226.74K
16 downloads
041.JPG 246.02K
10 downloads
030.JPG 277.92K
8 downloads
033.JPG 216.17K
7 downloads
