4 Barrel Holley on 202 - Rotating 90 deg
4bbl holley rotate
2 replies to this topic
#1 _COSH_
_COSH_
Posted 25 August 2014 - 10:40 AM
Hi,
I've got a 202 with a 4 bbl Holley and was interested in improving the fuel distribution by rotating it 90 degrees on the manifold.  This was mentioned by Old Johnno in his awesome articles as a potential way to improve the setup, but I've never actually seen it implemented.
For those of you that have done it, is there much involved?
Is it simply a case of rotating the carb, or does the manifold need to be modified?
Which way should it be rotated?
I was thinking counter-clockwise, so that the primaries are on the outside of the engine, to even up the flow lengths and to make primary jet changes easier.
Will it cause other problems such as fuel starvation on hard acceleration or cornering?
#2 _Bomber Watson_
Posted 25 August 2014 - 01:31 PM
Ausiespeed sells adaptors to spin them
Or you can get an inch alloy spacer and weld it on.
Primarys to the outside seems to be the goods.
#3 N/A-PWR
Posted 25 August 2014 - 01:40 PM
Hello Adam,
Stinga got the adapter plate too:-
D842B36C-7FEB-48EC-A6D4-3BBA242898E7_zps
http://www.gmh-toran...e-5#entry832938
and here is the adapter in action:-
4E1F0AA9-B5AC-4786-8BEA-8F17369135F7_zps
Top Job Stinga
Also tagged with one or more of these keywords: 4bbl, holley, rotate
