colour change to seats
5 replies to this topic
#1 _steve253_
_steve253_
Posted 16 October 2014 - 03:02 PM
Gday all. Ive been offered a pair of recaro bucket seats at a very good price and as my front seats are completely stuffed im considering grabing the recaro's. Unfortunately the recaro's are a light brown in colour and the interior in the car is black. Is there any way I can change the colour of the seats to black, eg using a dye or a vinyl type paint. They are covered in a material and not vinyl. Cheers Steve.
#2 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 October 2014 - 04:07 PM
You can. I've had good results with vinyl, not sure how fabric comes out.
http://www.superchea...ric.aspx?id=120
Fabric must be absolutely clean and dry, any stains will dye to a different colour, spray a couple of light coats then brush it in, let it dry, repeat the process; brushing each time until you reach the colour depth desired. Work on one area at a time, i.e. seat bottom or seat back so you can brush it in before it dries.
Keep in mind dying will not make old fabric look new, only a different colour; old fabric will always look like old fabric.
s
#3 _steve253_
_steve253_
Posted 16 October 2014 - 04:42 PM
thanks steve for the link. the seats are in quite good condition with only a couple of light marks on them. I guess a good clean and dry then see what happens with the paint. I can allways put some seat covers over them. Cheers
#4 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 16 October 2014 - 04:47 PM
I can always put some seat covers over them. Cheers
Yep, you don't want to ruin a good set of Recaros.
You may want to do a test run on a section out of sight to see if it comes up okay.
s
Edited by StephenSLR, 16 October 2014 - 04:48 PM.
#5 76lxhatch
  • 7,227 posts
Posted 16 October 2014 - 06:17 PM
Works fine for most fabrics too, unless its a plastic/nylon in which case it will wear off after a bit (including on your clothes but once its dry no big deal).
I changed the grey inserts to red with spray dye on mine:
edit: depending on the fabric working the dye in with a brush can be useful
Edited by 76lxhatch, 16 October 2014 - 06:17 PM.
#6 _uca78t_
_uca78t_
Posted 16 October 2014 - 09:28 PM
I a trimmer & I use vinyl sprays sometimes & I did the dash & consol in my UC it works well on most plastics . But you have to primer prep 1st it's works like a glue & it gives the dye something to bond to.
Cheers Shane
