engine prefix
13 replies to this topic
#1 _stkilda.1_
_stkilda.1_
Posted 27 November 2014 - 11:27 AM
I have just noticed on my LJ the engine number starts with the letter JL can some one please tell me what this stands for thanks
#2 darway43
darway43
  • 215 posts
  • Name:David
  • Car:LJ 2 door
Posted 27 November 2014 - 12:22 PM
http://www.gmh-toran...ce-or-standard/
#3 Bigfella237
Posted 27 November 2014 - 12:23 PM
It's a red 202ci high compression (9.4:1) six cylinder from the LJ Torana series.
Just out of interest, what are the cast date and first few engine numbers?
#4 _stkilda.1_
_stkilda.1_
Posted 27 November 2014 - 12:33 PM
341
#5 _stkilda.1_
_stkilda.1_
Posted 27 November 2014 - 12:45 PM
It is a SL LJ
#6 Bigfella237
Posted 27 November 2014 - 12:54 PM
So it's JL341x (4 digits) or JL341xx (5 digits)?
And down on the driver's side of the engine block at the back there should be a date code (cast not stamped) that should have one or two numbers (for the day) followed by a letter (the month) concluded with another number (the year), it looks something like "15B3" which would be the 15th of Feb '73.
Comparing the cast date with the engine number can often tell you whether something might have been messed with, not likely in your case but I'm just curious.
EDIT: Sorry I forgot to mention there will also be a clock face after it with a pointer pointing to the time of day when the casting was made.
Edited by Bigfella237, 27 November 2014 - 12:55 PM.
#7 S pack
  • 15,772 posts
Posted 27 November 2014 - 12:57 PM
The engine number will be JL341XXX (6 digits).
#8 Bigfella237
Posted 27 November 2014 - 01:01 PM
Thanks Dave, I assumed the JL series would have started at JL1001 like the others?
#9 S pack
  • 15,772 posts
Posted 27 November 2014 - 01:10 PM
By the time the LJ Torana series was released and the LJ GTR & XU1 started receiving 202 JL & JP blocks the HQ engine number sequence would have been approaching 6digits.
The OP's Torana is an SL, so if JL341XXX is its original engine then this SL Torana has to be a 1973 build and would have been produced somewhere around May 1973.
Edited by S pack, 27 November 2014 - 01:14 PM.
#10 _stkilda.1_
_stkilda.1_
Posted 27 November 2014 - 02:30 PM
JL 341157 can't see the cast Number to much oil
Well done 73 LJ
#11 jd lj
jd lj
  • 2,121 posts
  • Name:James D
Posted 27 November 2014 - 03:54 PM
JL 363xxx is late June 73, so may 73 sounds about right for this engine.
(is there a cast date behind the alternator?)
#12 _threeblindmice_
_threeblindmice_
Posted 27 November 2014 - 08:21 PM
They must have made a few by the 14h3 they were into the 4017xx range , anyone know how many of these JL's were made .
#13 S pack
  • 15,772 posts
Posted 27 November 2014 - 09:09 PM
Got no idea how many JL 202's were produced but I'll take a stab at eight thousand units.
#14 _threeblindmice_
_threeblindmice_
Posted 28 November 2014 - 08:11 AM
Thanks Dave .
