Mig Welders
33 replies to this topic
#1 _cool72_
_cool72_
Posted 23 February 2015 - 05:44 PM
Hi Guy's, I have a very basic / cheap mig welder and I am struggling to get any sort of consistency with my welds.
My question is , are better migs easier to use or is it my inability.
What machines do you guy's use.
I am using 0.6 wire and mig gas
Glen
#2 sibhs
Posted 23 February 2015 - 05:48 PM
Hi Glen, can you put some pics up of your welder, the settings you use and some welds.
Then the advice will flow.
#3 Rockoz
Posted 23 February 2015 - 06:24 PM
What gas are you using?
I found the disposable bottles didnt work well and ran out very quickly.
I went to a normal bottle and weld quality improved dramatically.
Better machines will give better results easier but the cheapies arent too bad
#4 _76lxJAS_
_76lxJAS_
Posted 23 February 2015 - 07:08 PM
Make sure you mig gun lead is not all twisted up. You need to keep it strait as possible. Also check the tension on your wire feed. Not enough tension will make it slip. To much tension will make it bird nest up in the mig.
Adjust you amps to where you think. Then adjust you wire speed to suit.
Not enough wire speed will cause you wire to burn back to quick.
To much wire speed will cause it to pop and fart.
Some basic for you to start with mate.
#5 FordPrefect
FordPrefect
  • 38 posts
  • Name:Alex
  • Car:Ford Prefect
Posted 23 February 2015 - 09:10 PM
Hi Glen,
Is it a duel purpose gas / gasless as the polarity org the terminals may need swapping?
#6 TerrA LX
Posted 24 February 2015 - 07:26 AM
Glen
Is the wire clean?
Is the liner clean and fitted correctly?
Are you getting a good earth?
#7 _cool72_
_cool72_
Posted 24 February 2015 - 06:03 PM
Hi Guy's, thanks for all the reply's.
The polarity is set for gas welding. I have replaced the liner and am pretty sure it is correct.
I am using BOC Argosheild, which is standard.
I will check the earth and pay particular attention to it.
I have included a pic of the welder.  The wire feed drive is pretty cheap and nasty and I think that this is where half my trouble is.
I have almost decided to invest in a far better welder but there is a lot to choose from.
Glen
#8 Rockoz
Posted 24 February 2015 - 06:20 PM
Similar to the one I use.
The wire feeder can be a problem and the gears in it do strip easily.
The wire tension adjuster can be a problem as well.
I use a G clamp to get decent pressure on the wire to drive it.
The earth clamps are pretty crappy as well.
Apart from that make sure the material you are welding is meticulously clean.
#9 _76lxJAS_
_76lxJAS_
Posted 24 February 2015 - 07:09 PM
Set up right and everything as it should be you should have a pretty descent mig there.
if you know someone in the know take it to them and get a run through how it all works.
you may only need a few simple adjustment etc to have it working well.
How is the wire tension assembly on it?
Sometime u just need to bend a lever that holds the pressure on the wire.
What notches are in the guide wheel?
If your using the wrong one it will be slipping also.
#10 N/A-PWR
Posted 24 February 2015 - 07:21 PM
put the wire through a fluro/normal earplug, and then through the wire feeder.
That way the earplug keeps the wire clean all-round.  B)
#11 TerrA LX
Posted 25 February 2015 - 07:38 AM
FWIW better mig welders are easier to use.
Be careful how big you go if you only have 10amp power points.
Also, if you are a very low volume user I suggest removing the wire roll from the machine and storing it in an air tight container as it will start to rust.
Using rusty wire will result in poor welds and contaminating your liner etc etc.
#12 wot179
Posted 25 February 2015 - 07:52 AM
Pics of a weld would be good.
#13 _cool72_
_cool72_
Posted 25 February 2015 - 06:21 PM
Thanks for the input guy's.
wot179, I don't really have any welds that aren't dressed at the moment. I will do some sample welds this weekend.
TerrA LX, what exactly do you mean  by FWIW.
#14 Ice
Posted 25 February 2015 - 06:24 PM
For What Its Worth got it
#15 SmacT
  • 1,026 posts
Posted 25 February 2015 - 08:30 PM
I have a cheap ($200) Rossi welder off ebay, with the D-size Argon gas and BOC wire. At first it was shite, but I had a good mate who can weld come over, adjsust the settings, re-route the wire, re-attach the earth clamp, and now my welds are consistent, even to the point of being better than I expected.
For me, set up is crucial, as is CLEAN metal, but having said that, I had the use of a really good welder from a panel beater mate, and it was alot easier to work with. Still, the little Rossi has done most of my car reasonably well - and it's all I've got/can afford! Have a good go at setting yours up right I reckon and perhaps a high-quality earth clamp before selling it. If that still doesn't work, chuck her out! :-)
#16 TerrA LX
Posted 26 February 2015 - 07:34 AM
SmacT has pretty much nailed it.
Welding may look as easy to some as laying a bead of silicone down in their bathroom but there are several factors that go into making a good quality weld.
#17 _cool72_
_cool72_
Posted 27 February 2015 - 11:29 AM
Thanks Gene, I got it now.  I was thinking something like
Frequency  W......... Inverter   Welder.   I must of been having a blonde moment ( or seniors )
Anyway as Smac T suggested, I replaced the crap earth clamp with a proper welding clamp.   Low and behold,  a miracle has happened. :clappin:
Thankyou all  for your help.
I will post a pic of my new improved abilities when I get chance. We are of to the beach for the weekend.
Glen
#18 SmacT
  • 1,026 posts
Posted 27 February 2015 - 04:27 PM
Wow - I have actually offered advice to someone on this forum, after years of me just asking for advice, and it worked! I have officially gone up a step! :-)
Glad to hear it and to be fair, I think a few others advised the same thing. Funnily enough, I was welding up a rear door I had cut for flares last night and was having a shocker. So I cleaned the metal better, played with the settings and slowed down my actions and - all better! It's an art, welding is, and guys that are really good at it are magicians. As long as I have flashes of brilliance occasionally, I am happy. Ha ha.
#19 Rockoz
Posted 27 February 2015 - 04:40 PM
Its an art that needs practice.
Once you have got the knack you are pretty right.
Best advice I was given was to get your eyes as close to the job as you can and really watch the weld. Not the arcing. The weld puddle.
#20 N/A-PWR
Posted 27 February 2015 - 04:51 PM
Yes, and the weld puddle can be seen by adjusting the helmet viewing shade to suit your eyes,
I used shade 11
The weld puddle.
#21 TerrA LX
Posted 27 February 2015 - 05:13 PM
Weld POOL...
#22 Rockoz
Posted 27 February 2015 - 05:22 PM
Bloody nit pickers. lol
#23 N/A-PWR
Posted 27 February 2015 - 05:26 PM
TerrA's welding is bigger than ours Rob
Puddle ( small ) vs Pool ( large )
#24 _cool72_
_cool72_
Posted 04 March 2015 - 06:22 PM
Hi Guy's, I have just grabbed a couple of bits of 1mm and done a trial weld ready for your comments.
Thanks to all for your comments.
First pic is top and second is underside. As you can see I did have an oopps in the middle
Settings at minimum with speed at about 25%
Glen
#25 wot179
Posted 04 March 2015 - 07:04 PM
With light gauge butt welds I recommend not welding in long runs.
Just one quick tack after the other.
Aim each tack right into the tail of the last one.
As you watch through your helmet, you will see each tack cooling.
As the red glow disappears, that is the time to pull the trigger.
It prevents all the blow throughs and reduces distortion.
Before you start to weld, make sure you have plenty of tacks to start with. About 25mm apart.
You can gently grind them down before you start your run,(being sure not to grind anywhere but the tack) allowing you to go back over
the top of them easily.
If you do it right, it will look just like a weld bead and not like a series of tacks.
Don't be scared to take your time.
Heat always causes distortion, there is no way to avoid it.
The trick is to minimize the distortion by minimizing the heat.
