Electric vacuum pumps for brakes
47 replies to this topic
#1 rexy
  • 3,834 posts
Posted 20 August 2015 - 12:22 AM
Has anyone had experience with using an electric vacuum pump for their brakes?
It's for the HQ. Finally got around to checking how much vacuum it has and the answer is 7 inches at idle and 10 at 2000 rpm. No wonder the brakes are hard work.
Brands? Fitting tips?
#2 wot179
Posted 20 August 2015 - 12:24 AM
How bout an alternator off a diesel with a built in vacume pump?
#3 Bigfella237
Posted 20 August 2015 - 12:35 AM
They need a pressurised engine oil supply and return as well though don't they?
At least all the Toyota ones I've seen do.
#4 rodomo
Posted 20 August 2015 - 12:49 AM
Yes, to lubricate and to push the vanes out.
Option 2 is a bigger vacuum reservoir.
Edited by rodomo, 20 August 2015 - 12:54 AM.
#5 _LS1 Hatch_
_LS1 Hatch_
Posted 20 August 2015 - 01:04 AM
Know somehow who runs one on a Plymouth Roadrunner...one of the electric ones. Works fine for him. (You can get them as an aftermarket kit, or there were some OE GM's that used them from memory too..)
Known a few people who run a vacuum reservoir setup too...ok for once or twice but if you use the brakes a few times in a row it will run out still.
I think his was a Comp one from memory?
http://www.summitrac...vacuum pump kit
Here is one version of an OE one as well..
http://www.amazon.co...ric vacuum pump
(Amazon has the various kits Summit does too)
#6 gtrboyy
Posted 20 August 2015 - 01:23 AM
ve v6 vacuum pump is one to use..works well,compact & fairly quiet compared to comp cans product.
Kinda like idea of using vacuum reservoir as well as back up,not really needed though.
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 20 August 2015 - 01:31 AM
http://www.abspowerbrake.com/ehpm.html
Edited by madtoranajzedded, 20 August 2015 - 01:35 AM.
#8 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 20 August 2015 - 01:53 AM
Damn tried to do a linky but couldnt do it..
#9 V-SLR5000-P
V-SLR5000-P
  • 1,325 posts
  • Car:L34 x 2
Posted 20 August 2015 - 06:28 AM
I have a SSBC electric vacuum pump hooked up to an HK booster and it works well. The pump is reasonably compact and is mounted under the car. The noise is probably unacceptable to most, although if your engine is lumpy enough to make no vacuum its not so noticeable once the car is running. Unsuspecting passengers certainly have a WTF moment when the ignition is first switched on!
#10 dattoman
Posted 20 August 2015 - 08:56 AM
Hydraboost it
#11 hatchssv8
hatchssv8
  • 358 posts
Posted 20 August 2015 - 10:13 AM
The VE V6 pump with its mounting bracket mounted to the engine works a treat and there is negligble noise and zero vibration
#12 _dno_
_dno_
Posted 20 August 2015 - 05:05 PM
This one's a popular choice from my reading.
http://www.summitrac...parts/cvs-vs-25
#13 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 20 August 2015 - 07:12 PM
I've got a Hella UP28? pump on mine with an adjustable vacume switch to set the amount of vacume that can be pumped, works a treat, wish I had have does this years ago.
Mine is mounted on a custom bracket underneath the master cylinder, and using an inline Japanese car style check valve. You can hear it easily when the ignition is switched on but not once the engine is running.
I never got the reasoning behind a vac tank if the manifold vacume is very low, I mean why would you want to store lots more of not enough vacume, will just mean the rubbish power assist with work for another application of the brakes, but never be any good.
I'll see if I can get a pic soon.
#14 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 20 August 2015 - 08:17 PM
Pics as mentioned.
#15 rexy
  • 3,834 posts
Posted 21 August 2015 - 04:34 PM
That looks like a fantastic set up Mick.
Thanks everyone, I have much food for thought now.
#16 76lxhatch
Posted 21 August 2015 - 04:49 PM
Hydraboost it
That would be the way, but all these drag racers throw the power steering away!
#17 rexy
  • 3,834 posts
Posted 21 August 2015 - 11:59 PM
Out of interest, what did you use for a vacuum control switch in this install?
#18 Bigfella237
Posted 22 August 2015 - 12:23 AM
Just for interest, I found this picture on the Commodore Forums of a Comp Cams vacuum pump on the left, VE Commodore V6 pump on the right...
Attached File  Comp Cams Vacuum Pump (left) - VE Commodore V6 Pump (right).jpg   193.21K   31 downloads
Anyone happen to have a part number?
#19 ls2lxhatch
Posted 22 August 2015 - 01:11 AM
Looks like the pump LS1Hatch posted a link to.
ACDelco 20804130
Switch and Canister from the Amazon frequently bought together list.
http://www.amazon.co...7HSQKDHY2J27ZZ3
http://www.amazon.co...bxgy_263_text_z
Edited by ls2lxhatch, 22 August 2015 - 01:14 AM.
#20 rexy
  • 3,834 posts
Posted 22 August 2015 - 08:13 AM
92227002 is the Holden part number. Hold your breath though cause the pricing is $444 trade.
It seems to be likely the same hella pump that Mick has used.
Attached File  image.jpg   104.51K   33 downloads
Attached File  image.jpg   259.5K   29 downloads
#21 _LS1 Hatch_
_LS1 Hatch_
Posted 22 August 2015 - 08:43 AM
The 4130 part number one at Amazon is probably very similar to that.. it fits the late model Camaro (which is pretty much a Commodore underneath, along with the Cadillac CTS too.
(especially since it is made in mexico where GM makes a bit of stuff for here as well)
#22 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 22 August 2015 - 08:22 PM
That's pretty much my pump. The same/similar pump is used on lots of vehicles, there are a few versions of it, one that is rated for less duty as its more an assist pump than a supply all your vacume rated pump.
I got mine from summit, and think it was under $200 landed here.
The VE pump is the same and I've seen suggestions of getting one from the wreckers for next to nothing.
#23 gtrboyy
Posted 23 August 2015 - 03:25 AM
Yeah wreckers is good bought one off a near new ve  for $80 I think ages ago...cousin flogged it to put on his big block valiant 'cos I haven't even touched gtr in ages.
Thought they only need one way check valve?
#24 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 23 August 2015 - 07:23 AM
The Hella data sheet shows mine used with a vac switch, and a one way valve. It will only manage a bit over 20" vac anyways, but no point in running it 100% of the time and wearing it out.
#25 rexy
  • 3,834 posts
Posted 23 August 2015 - 09:57 AM
They have a vacuum sense switch as part of the plastic bung that goes into the booster. I am going to see if this can be made to work as a retrofit.
My Melbourne ring around showed not too many available. Most were asking $100 -110.
