Hey guys,
We are a Melbourne based business that specialize in brake kit upgrades for many different makes and models.
Here is an example of a kit we do for LH, LX and UC Torana's. We also do kits for LJ's etc.
This 330mm TWIN PISTON kit is to suit LH LX UC Torana or Sunbird or any car with Torana stub axles, like hot rod or early Holdens with Torana stub. A 1" master cylinder can be fitted with this kit but 15/16 will do the job. All Commodores from VN that had twin piston and 4 piston HSV kits used the original 15/16 master.
Your wheel offset is moved out 8mm each side.
Far better stopping power than the original brakes, a must if you need an engineers report for a larger engine.
17 inch rims or larger are needed for this kit. [If you have any queries re wheel fitment ie if you have SIMMONS WHEELS please call prior to bidding].
The rotors are off the shelf 328 mm x 28 mm units....not like other suppliers that machine the rotors down and then you have to buy from them when due for replacement.
Please note : Rotors are electroplated for corrosion protection and overall aesthetic longevity.
It is normal for plating to wear on contact areas; this does not affect their performance.
All parts are ADR compliant and will meet any engineers report.
We are the manufacturers of these kit so we can do them in any stud pattern, let us know what you need. That means we can do the kit in original Torana pattern, Commodore stud pattern, HQ stud pattern, or Ford if you wish [at extra cost].
Please provide stud pattern required at end of auction.
We can also do a 343 mm kit as well as up to 383 mm 4 and 6 piston kits.
280 mm and 315 mm rear kits also available.
The kit looks great under any wheel and works a treat.
Easy to fit yourself and comes complete with all you need to do the job including rubber hoses to adapt to the original fittings on the car.
Fitting service available in Melbourne, email for details about this kit and any other questions about my parts.
KIT INCLUDES
2 x Twin Piston PBR Calipers with pads
2 x 046 straight slotted rotors [also available standard] or cross drilled and slotted, curved slotted or drilled and curved slotted at extra cost.
Rubber brake lines that fit straight to the original imperial fittings on the car
2 x Adaptor Hubs complete with bearings and seals
CNC machined brackets with bolts
The kit is complete with all you need
All parts are new, studs are M12 metric or 1/2" imperial
We do kits for different size wheels aswell.
You can inbox me here or call our factory on 03 9720 2266.
Email address is info@upc-online.com.au
We are located in Boronia VIC 3155.
Cheers guys
Edited by dattoman, 05 November 2015 - 08:11 PM.
