Hinge Repair Sections
8 replies to this topic
#1 Cook
Cook
  • 1,535 posts
Posted 16 March 2016 - 05:02 PM
Hi, I see that Rares (RS 1072) are now making the repair section for behind the hinge, together with the backing plate and nuts welded on.  Cheers Ron
#2 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 16 March 2016 - 05:57 PM
Might be useful, need someone to try them.
#3 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 16 March 2016 - 06:20 PM
That's good ' n ' all.......But to remanufacture a problem rust area exactly the same as Holden's $hit design is just stupid - with the knowledge of the reinforce plate collecting road grime and eventually rusting out the engine bay skin you'd think a redesign would of been a far better option.
Just my 2c's
Az
#4 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 16 March 2016 - 07:07 PM
I agree, I redesigned mine when I fixed them.
#5 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 16 March 2016 - 07:44 PM
Then all the concourse guys will cry about non-originality...
#6 dattoman
Posted 16 March 2016 - 08:24 PM
Did they say they were for LC-J ?
Cause we larger gentlemen don't seem to care as much
Realistically... our car aren't used the same now as they were years ago
Alot less miles and weather... so is a redesign actually necessary ?
#7 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 16 March 2016 - 09:09 PM
Mine took 35 years to rust through, if these last that long I'm fine with them...
#8 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 17 March 2016 - 01:28 AM
Run a bead of seam sealer around the edge of the backing plate, should keep the dirt and moisture out
#9 Cook
Cook
  • 1,535 posts
Posted 17 March 2016 - 06:43 AM
Sorry I should have mentioned they are listed for LH/LX.  If I decide to use them I will do as Brett suggests, just run some sealer around them. I did contemplate replacing the backing plate with flat metal but panel shop suggests using the bent section for better strength. Cheers Ron
