camshaft enginerring
17 replies to this topic
#1 _ljxu1torana_
_ljxu1torana_
Posted 20 May 2016 - 01:56 PM
hi,does anyone have the phone number of camshaft enginerring in queensland.i have phoned the number that was on the web but its been disconected,
#2 _COSH_
_COSH_
Posted 20 May 2016 - 03:35 PM
A quick search on google shows that you asked this question in 2010 http://www.gmh-toran...ft-engineering/
#3 _mervx_
_mervx_
Posted 20 May 2016 - 10:52 PM
wow, so they are still out of bussines. hey Jason , try Wade camshafts,they have done heaps of turbo 186 lj xu1 torana camshafts. thanks. wink wink bomber. anyway, their phone number is 073394 1788 thanks
Edited by mervx, 20 May 2016 - 10:55 PM.
#4 S pack
  • 15,772 posts
Posted 21 May 2016 - 07:46 AM
Wade closed their doors back in 2014 or was it 2015? Anyway, doesn't really matter when just  they are no more.
#5 _datpsi_
_datpsi_
Posted 21 May 2016 - 08:57 AM
Clive cams has most of the wade grinds still.
#6 N/A-PWR
  • 9,654 posts
Posted 21 May 2016 - 10:02 AM
did it end up in WA?
http://www.southside...ft-engineering/
#7 _mervx_
_mervx_
Posted 21 May 2016 - 01:25 PM
it does not matter where they ended up, he won't buy one anyway.....and yes ,I knew about wades.haha
#8 _ljxu1torana_
_ljxu1torana_
Posted 21 May 2016 - 02:44 PM
i rang up southside engines in wa,they told me that the camshaft enginerring numbers they have are in 4 numbers in the cam grind.queensland uses 2 numbers in the cam grind.
#9 _Bomber Watson_
Posted 21 May 2016 - 02:54 PM
Four number cams are much higher performance. Thanks. Jason. Thanks.
#10 _ljxu1torana_
_ljxu1torana_
Posted 21 May 2016 - 04:52 PM
really
#11 N/A-PWR
  • 9,654 posts
Posted 21 May 2016 - 05:02 PM
good read here - http://www.mmsonline...rinding-process
part of camshaft engineering
#12 _mervx_
_mervx_
Posted 24 May 2016 - 08:38 PM
So did you actually buy a cam???? thanks, Bomber ,thanks ,ballboys linesman, thanks
#13 I'm a Red Motor fiend
  • 770 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 25 May 2016 - 04:51 AM
Too good! Lmfao. Its five and a half years and counting and he hasnt even found the contact details. On that time frame I reckon give it another 10 years before purchasing a cam is even contemplated. thanks. yes really, 4 number cams. thanks.
#14 N/A-PWR
  • 9,654 posts
Posted 25 May 2016 - 01:57 PM
Hello Jason,
 what grind of camshaft do you want from a specialist manufacturer?
 you'll also need to know the associated parts to go with it. :)
#15 _ljxu1torana_
_ljxu1torana_
Posted 25 May 2016 - 05:52 PM
hi dave,you are the only person here with brains not like some others.my cam is a ce 92 which is stamp on the end of the cam.just trying to find the cam profile.we know that mervx or gary or what ever his name is.he is not the sharpest tool in the shed.
#16 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 25 May 2016 - 06:21 PM
If you can't find out what the number means in terms of profile then send the cam to Tighe cams in Bris. and they can put it on a machine and "cam doctor" a profile for you,give or take a bit if the cam has been used.
#17 _mervx_
_mervx_
Posted 25 May 2016 - 10:55 PM
That's a blunt reply Jasin, thanks
#18 N/A-PWR
  • 9,654 posts
Posted 26 May 2016 - 01:39 PM
Found this Jason:-
http://www.noordeman...shaft-grinding/
