Caliper brackets to be made, any volunteers?
LH ap racing
24 replies to this topic
#1 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 13 January 2017 - 08:03 PM
Anyone looking for some milling work?
Needs to be made from 6061 alloy, prob a 30 mm x 65 mm x 178 mm billet or larger.  More details / drawing on request.
Attached File  prototype1.JPG   41.22K   7 downloads
Attached File  prototype2.JPG   58.36K   6 downloads
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 13 January 2017 - 09:26 PM
Why bother when a similar thing is available off the shelf?
#3 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 13 January 2017 - 09:58 PM
& it WOULD be engineered too, ask your insurance company there opinion. Front of hsv does similar thing to that c5 style.
#4 dattoman
  • 16,491 posts
Posted 13 January 2017 - 10:17 PM
A commodore bracket is available off the shelf
Assuming your thinking CP5200 AP style calipers
But not a HQ/Torana style bracket
#5 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 13 January 2017 - 10:45 PM
If there is an off the shelf bracket to suit a LH torana with cp5200, I would like to know where ...
#6 dattoman
  • 16,491 posts
Posted 13 January 2017 - 11:17 PM
Nope
Never made one or come across one
To suit 330mm disc ?
Theres a few kits around people have made for themselves... but they all use different stubs
Torana, HQ, CRS dropped
#7 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 13 January 2017 - 11:35 PM
Yes to suit a DBA 046, stock LH stubs and steering arms.
Would make it myself if I had the mill, the stock (and the time!)
#8 dattoman
  • 16,491 posts
Posted 14 January 2017 - 12:59 AM
I usually make them out of wood
Trim and trial fit alot till they are right
Then take the sample to an engineer and price it up
Haven't had to do that for 10 yrs though... so not sure who could help locally.
#9 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 14 January 2017 - 10:45 AM
Yes I roughed it out with a wood sample, with the caliper clamped around a 2.5mm shim and the stub fixed in place.  I'm told I can get a prototype 3D printed in Asia for about the same price, delivered, as the router bit and the wood stock!
Attached File  20170113_154236.jpg   91.54K   7 downloads
I'm going to try and mount leading side, too high up and perhaps hits UCA, too low and hits the steering tie rod.  On LH (at least my stubs) the caliper mounting holes are not level with each other, perhaps because one has to mount the dust shield.  Will need to include that in the bracket design rather than sit a washer in there.
#10 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 January 2017 - 03:36 PM
Neil I was meaning the slightly tilted bracket, r8 vt - vz use c5 corvette style caliper standard fitment, then harrop, then ap racing was the top option around vz hsv. Gary
#11 dattoman
  • 16,491 posts
Posted 14 January 2017 - 05:57 PM
Yep HSV used a few setups
All lug mount not radial
C4
Attached File  c4b.jpg   20.01K   4 downloads
Attached File  c4b1.jpg   19.25K   4 downloads
Attached File  c41.jpg   24.92K   3 downloads
C5
Attached File  c5b.jpg   20.84K   3 downloads
Attached File  c5b1.jpg   19.71K   3 downloads
Attached File  c52.jpg   17.84K   5 downloads
Then the AP.. but the AP bolted straight to the stub as it was a lug mounted caliper not a radial also
#12 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 14 January 2017 - 07:26 PM
Just to clarify. If you want an adapter to mount AP or Brembo calipers that are radially mounted AND with a 152mm between the centres to bolt up to a stub axle that has 3.5" mount (just like HQ and Torana), then they are available off the shelf. Have been for years.
#13 dattoman
  • 16,491 posts
Posted 14 January 2017 - 08:47 PM
And who has such brackets available ?
#14 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 14 January 2017 - 10:55 PM
I've been told UPC quoted "from $3500" for a kit to suit LH Torana
Hahaha no way you could trust that to fit first time given the reviews out there
#15 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 15 January 2017 - 02:29 PM
Details of the bracket:
Attached File  Untitled.png   303.57K   6 downloads
Available here from Summit:
https://www.summitra...-6309/overview/
#16 dattoman
  • 16,491 posts
Posted 15 January 2017 - 02:57 PM
ewww...wilwood
#17 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 15 January 2017 - 03:51 PM
Thanks for the suggestion although I think that particular bracket is too short radially for a 330 mm disc (instead of 28.9 mm should be around 45 mm), and the axial offset is out by like 5 mm (instead of 6.6 mm should less than 2 mm).
#18 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 15 January 2017 - 07:26 PM
ewww...wilwood
Have you used them?
#19 dattoman
  • 16,491 posts
Posted 15 January 2017 - 09:37 PM
Not those actual brackets
But I have in a past life used wilwood products
Or better yet... removed and thrown in the bin wilwood products and fitted better stuff
For budget gear and visual wank they are ok for some applications
But I personally wouldn't use their products
#20 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 16 January 2017 - 01:19 AM
But those brackets may be fine and if nothing else could be used for a test fitment to get a "proper" bracket made? I think it would be better to get a bracket made using that as a sample, as you would then know what fine tuning would be needed. It wood be more expensive than your block of wood method, but a lot quicker.
#21 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 16 January 2017 - 04:20 PM
Out of curiosity Neil, what is your preferred metal for making caliper adapters with?
#22 dattoman
  • 16,491 posts
Posted 16 January 2017 - 08:04 PM
Just stick with the light weight balsa :)
6061 or 7075 if the guys got lots of money
#23 Bigfella237
Posted 17 January 2017 - 02:10 AM
Damn, why don't they make a 3D Printer that squirts molten alloy?
#24 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 17 January 2017 - 08:28 PM
You can do something akin to Powdered Titanium from a 3D printer...
#25 _datpsi_
_datpsi_
Posted 21 January 2017 - 09:51 AM
Jump on facebook and search'team cusco racing'.
Brad and his dad have built, and had some serious design and fabrication input to some of the rocket ships in WA.
Top blokes and their workmanship is top notch!
Also tagged with one or more of these keywords: LH, ap racing
