4 speed opel gearbox
gearbox
20 replies to this topic
#1 _riccardo_
_riccardo_
Posted 08 June 2018 - 04:57 PM
hey guys could you please help me with this gear box i believe is a 4 speed opel gearbox any help would be great
thanks
#2 limo
limo
  • 2,673 posts
  • Car:most Torana models, Jag, Vauxhall, Triton, Staesman
Posted 08 June 2018 - 06:55 PM
I think it would be easier and quicker to see a pic of the actual gearbox / bell housing and shifter.
#3 _riccardo_
_riccardo_
Posted 29 June 2018 - 11:23 AM
hi guys happy friday to everyone i have a question for you.
i have an lc gtr 01/71 with a missing engine and gearbox now im chasing both items. i find an opel gearbox any help if this will be the right one for my gtr im planning to bring her back to factory stander.
thanks a lot guys
#4 _riccardo_
_riccardo_
Posted 29 June 2018 - 11:26 AM
i added more pict of it from another gear box that im trying to buy
#5 Bigfella237
Posted 29 June 2018 - 04:10 PM
According to the LC parts cattledog, 7211158 is a "CASE - Transmission" for "VEHICLES EQUIPPED WITH 1600 4 CYLINDER ENGINES"
#6 limo
limo
  • 2,673 posts
Posted 29 June 2018 - 08:09 PM
Vauxhall not Opel
#7 limo
limo
  • 2,673 posts
Posted 29 June 2018 - 08:12 PM
that's an Opel for six
#8 _riccardo_
_riccardo_
Posted 01 July 2018 - 11:19 PM
i have a lc gtr with a 161s as u said this box is for a 4 cylinder?
do you think it will be good for my 161 s gtr?
#9 Ice
  • 15,227 posts
Posted 01 July 2018 - 11:52 PM
Yes
#10 _riccardo_
_riccardo_
Posted 02 July 2018 - 09:24 AM
Yes
are you 100% sure this will fit mt lc gtr with the 161 s engine? just checking
#11 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 02 July 2018 - 12:20 PM
Does it have a cast pan or pressed tin?
#12 limo
limo
  • 2,673 posts
Posted 02 July 2018 - 05:11 PM
that's what I have in my GTR
was standard for GTR and XU1 until 7/71
bottom plate looks thick so probably cast
#13 _LONA-CK_
_LONA-CK_
Posted 03 July 2018 - 07:25 AM
It an original Opel 4 speed to suit a LC GTR or XU1 cast bottom plate and date coded 7-9-70
Items that are with it
Original bell housing
Reversing switch
Gear stick
Clutch folk
Original Speedo drive
I have 3 other complete Opel gearboxes as well and one of them is to suit a hk with the tin plate date coded 1967
I give this gentleman all the info about the box but he needed to hear it from others, as you can see by the first lot of pics he as already been burnt once
Anyways good luck with it give it a freshen up and away you go
Cheers gong
#14 bat 53
bat 53
  • 525 posts
  • Name:albert
  • Car:lc gtr
Posted 09 July 2018 - 11:21 AM
my lc gtr is a 6/71 has aussie 4 speed
#15 _riccardo_
_riccardo_
Posted 09 July 2018 - 01:54 PM
 probably your one have a 173s  engine and a 4 speed Aussie
#16 _Four_Cylinder_Fan_
_Four_Cylinder_Fan_
Posted 13 December 2020 - 10:28 PM
I am eplying to this older post.
Am I right, the Opel 4 speed manual gearbox was only used in the LC 6 cylinder Torana?
An Australian built gearbox replaced the Opel gearbox in the LJ 6 cylinder Torana?
The Opel gearbox was a stop gap unit used until the Austalian designed unit came along?
#17 S pack
  • 15,795 posts
Posted 14 December 2020 - 05:43 AM
The Opel 4spd was initially offered in the HR Holden, followed by HK, T & G 6cyl passenger vehicles and subsequently the LC Torana 6cyl models.
Around the start of July 1971 the Opel 4spd (option code M20) was replaced by the the Australian built M20 4spd transmission in LC Torana 6cyl right hand drive models. Production of HG passenger vehicles had ceased by this time.
The Opel 4spd continued to be used in Australian assembled LC and LJ left hand drive 6cyl models.
Edited by S pack, 14 December 2020 - 05:45 AM.
#18 _Four_Cylinder_Fan_
_Four_Cylinder_Fan_
Posted 14 December 2020 - 08:27 AM
it seems that this was a result of parts sharing between Holden, Vauxhall & Opel that began in the late 1960s. In July 1971, according to your information, GMH replaced the Opel gearbox in the 6 cylinder Torana but then added the Vauxhall 1600 OHC engine in the 4 cylinder Torana!
#19 yel327
  • 13,939 posts
Posted 14 December 2020 - 08:37 AM
I don’t think it is even an “Opel” box. Maybe Opel design is a better term. AFAIK they were built in the Phillipines for Asian vehicle use. Probably saved GMH a few $ per box over the US built Saginaw which was what was used standard in 6cyl HK and HT commercials. If the Saginaw had been comparable cost that probably would have been used in LC XU1 and 6yl HK-HG.
#20 S pack
  • 15,795 posts
Posted 14 December 2020 - 11:16 AM
GMH refer to it as an OPEL 4 spd transmission in the August 1971 dealer service letter.
I remember another dealer service letter about a production change to the bellhousing for HR Holden fitted with the OPEL 4 spd transmission.
I have a vague memory of reading somewhere that the OPEL 4spd was assembled in the GM Philippines facility where they assembled Chevrolet, Opel and Holden (Torana)
Reading between the lines I'd reckon most of the gearbox components were produced by OPEL and CKD to GM Philippines.
#21 yel327
  • 13,939 posts
Posted 14 December 2020 - 11:47 AM
Or it’s like GM South Africa. They built Chevrolet design engines, transmissions and rear axles to increase the local content, for installation in Holden vehicles they assembled as Holden or Chevrolet vehicles. In reality not that much different to TH180 boxes built here as Trimatic or Buick design engines built here for Holdens. I reckon it’s Opel design, produced in the Phillipines. Might be some imported content.
Also tagged with one or more of these keywords: gearbox
