Fitting Rare Spares LX Stabiliser/Sway Bar Bush Kit
sway bar stabiliser bar rare spares
7 replies to this topic
#1 a9x4dr
a9x4dr
  • 130 posts
Posted 10 January 2019 - 07:23 PM
Hi All, just wondering if anyone has used one of these rare spares front stabiliser/sway bar bush kits? Have a few questions as follows:
1) Do these really fit the Torana 22mm sway bar? Looks like a very tight fit, the old D clamp rubber has a bigger hole but then again they are worn out.
2) The old rubber for the D clamp had a split in it on the flat part so you can fit it over the bar. The new ones don’t have a split so how do you fit them onto the bar? Doesn’t really look like the sway bar ends will fit through as they are wider than the round part of the bar.
3) Will it matter that the new out rigger bar/pin is slightly shorter than the original (the red one in the picture).
Cheers for any and all replies!
Mick
Attached File  181A8884-1DF4-4EA2-893B-A17740896AFF.jpeg   93.01K   6 downloads
#2 claysummers
  • 3,737 posts
Posted 10 January 2019 - 11:31 PM
Mick
The hole should be exact same diameter no smaller than the bar. If it measures up I would just cut the rubbers with a razor blade per the originals.
The pins will be okay but what’s wrong with the originals? Shorter is better if you are lowering front springs generally speaking.
Clay
#3 Cook
Cook
  • 1,534 posts
Posted 11 January 2019 - 02:05 PM
Clay, just on the D clamp bushes I bought a set for my WB and thought the same thing about the "non" split, until I took it out of the packing.  They just seem to sit tight and not easy to see.  I'd be surprised if they weren't split. Cheers Ron
#4 a9x4dr
a9x4dr
  • 130 posts
Posted 11 January 2019 - 03:09 PM
Just had a close look again, definitely not split.
Nothing wrong with the original pins that I can see, didn’t realise the bushes themselves come in a set that’s all.
#5 a9x4dr
a9x4dr
  • 130 posts
Posted 11 January 2019 - 03:18 PM
Just spoke to rare spares, guy I spoke to wasn’t completely sure with the Torana bushes but he did say with other rubber ones he has used, you cut them yourself. So they don’t come split.
#6 ReplicarSLR
ReplicarSLR
  • 518 posts
Posted 11 January 2019 - 05:43 PM
The only issue I have seen with the rares ones is they dont seem to have the two bits of rubber that extends from bush that go into the actual swaybar ends and isolate the hole in the actual sway bar ends from the actual post like the original ones did and some of the other ‘nolathane’ ones do
#7 UCSLE
UCSLE
  • 736 posts
  • Name:troy
  • Car:Goggomobil
Posted 11 January 2019 - 11:14 PM
just bought and fitted that rare spares kit and had no problems with it .
no need to split the bar mounts just lube them up with soapy water and slide them on over the bar ends
#8 claysummers
  • 3,737 posts
Posted 12 January 2019 - 12:02 AM
Also tagged with one or more of these keywords: sway bar, stabiliser bar, rare spares
