sway bar for rear lh lx with nine inch
suspension
7 replies to this topic
#1 _torriemick_
_torriemick_
Posted 16 January 2019 - 06:42 PM
does anyone know where or who would be able to supply me with a sway bar to suit a lh lx with a nine inch rear end my original was mounted to the insides of the trailing arms (bolts horizontal) 2 bolts either side it was a standard diff but not sure if this sway bar will fit around the centre of the much larger housing will i have to get a custom one made has anyone had these issues before
#2 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 16 January 2019 - 07:39 PM
Depending on what you do with exhaust you could,
Weld up the holes in the trailing arms and make new holes further aft
#3 Cook
Cook
  • 1,535 posts
Posted 16 January 2019 - 09:21 PM
Hi Mick. I can't advise on whether or not you can adapt your original swaybar around the 9". I replaced mine with a Whiteline swaybar and have fitted it up.  The mounting rods bolt up under the upper trailing arm brackets.  I can get you a pic if you wish. No apparent issues, but haven't driven with it yet.  Check out the thread "rear sway bar" (sorry I don't know how to attach it here) and you can get some info from there. Cheers Ron
#4 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 16 January 2019 - 10:51 PM
Mine is bolted to the lower arms, i drilled fresh holes and moved it backward and tilted it down at the rear a lil to clear the large center housing mine has.My arms were also plated at he same time.
#5 Statler
Posted 17 January 2019 - 07:00 AM
Perfect opportunity to swap for a RTS2 type bar.
Pics on my build thread.
#6 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 19 January 2019 - 09:10 AM
I bought a Whiteline swaybar ( BHR37) years ago for my LX to suit 9 inch diff.
Think the only difference from standard LX was that it was supplied with larger U bolts to mount to axle tubes on diff housing.
It's very snug, but it fits.
Sent from my Moto G (5) using Tapatalk
#7 S pack
Posted 19 January 2019 - 01:07 PM
Speaking of sway bars, did the A9X have an upgraded front anti roll bar or was it just the std SL/R 5000 & SS bar?
Edited by S pack, 19 January 2019 - 01:09 PM.
#8 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 01 February 2019 - 09:33 PM
A9x bar is on the front side Dave, a different bar. Gary.
Also tagged with one or more of these keywords: suspension
