XU1 header engine pipe flange plates
#1
Posted 21 September 2019 - 12:45 PM
The stud spacing appears to be 2 3/4”, and engine pipe 1 3/4”, which seems close to factory 186. I have tried searching on here. Can anyone advise please?
#2
_LC870_
Posted 21 September 2019 - 01:22 PM
Hi there .
I can help you out with a good pair of original flanges .
Regards LC870
#3
Posted 21 September 2019 - 02:38 PM
#4
Posted 21 September 2019 - 07:08 PM
The XU1 flanges are the same as single exhaust EH/HD 149/179, which is smaller than stock 186. Obviously they are also the same as 179/186 X2, 161S, 173S & 186S.
Dr Terry
#5
Posted 21 September 2019 - 07:41 PM
Interesting the guy at the exhaust shop didn’t know this as he had a Holden wrecking yard for ten years.
Clay
#6
Posted 21 September 2019 - 11:37 PM
As far as the exhaust industry is concerned... pressed metal flange plates are a thing of the past
Now its 10mm laser cut flat flanges
Still some pressed ones about though... just takes some looking
#7
Posted 22 September 2019 - 01:37 AM
#8
Posted 22 September 2019 - 07:56 PM
#9
Posted 08 October 2019 - 11:54 PM
Looking at the FX to HR MPC part numbers for FX to HD and HR X2 and S exhaust packing gasket are the same, indicating same 1 3/4” engine pipe. There is no listing for HR X2 and S flange, but the listing for EH HD indicates 1 or two pieces. I take this to mean two flanges for the HD X2.
This confirms Dr Terry’s information, not that I doubted it. Just that my exhaust shop contact did.
I also see Brad Merrick has enlarged the pipe hole from stock on his repro XU1 systems. He doesn’t seem to have a listing just for the flanges though.
This information may help others I hope. Meanwhile I’m still hunting.
Clay
It’s only for a smelly old FB of course......
Edited by claysummers, 08 October 2019 - 11:55 PM.
#10
Posted 09 October 2019 - 07:27 AM
The reason that they don't list the flanges separately for the HR X2 & 186S engines is that the engine pipe is a 'Y' pipe & the flanges can't be removed. The same goes for the later GTR & XU1 engines.
The HD X2 had 2 separate engine pipes going to a muffler with 2 inlets.
Dr Terry
#11
Posted 09 October 2019 - 08:14 AM
#12
Posted 09 October 2019 - 09:00 AM
Just find some old Holden exhausts and cut the pressed flanges off
Or better yet... get your sizes and Mr China will make you 100 and you can sell some off for a profit
https://www.liangfei...e/56439360.html
If I was still working at the exhaust place I'd grab you a few... but I don't have access to that warehouse anymore... and no-one there I know who's bright enough to find them
#13
Posted 09 October 2019 - 11:07 AM
Clay
#14
Posted 15 October 2019 - 12:21 PM
#15
Posted 09 November 2019 - 09:23 AM
https://sonicinjecti...der-plates-xu1/
Sonic injection flanges to suit red six cast headers $40 a pair
Cut from sheet as per current process rather than pressed like original
Should work better as the originals bend
#16
Posted 09 November 2019 - 09:25 AM
#17
Posted 09 November 2019 - 10:12 AM
There's a waterjetting cutter in Melbourne that does flanges etc, MRC Waterjetting. Maybe someone in SA can do it, just need to give them the dimensions. Cheers Ron
#18
Posted 09 November 2019 - 11:41 AM
#19
Posted 09 November 2019 - 09:02 PM
#20
Posted 10 November 2019 - 08:44 AM
Thanks for the offer.
10mm holes on 71.5mm centres.
Centre hole 49mm.
I have added 1mm to the standard hole size (48mm) per Brad Merrick’s suggestion for improved sealing and pipe life.
Brad states the stud centres are 72.5mm +/-0.5mm, but the two sets I have are 71.0mm.
Clay
#21
Posted 16 May 2020 - 12:47 PM
Luke from sonic injection is making another run of flanges and should have them done by 22/5/2020
0412207547
#22
Posted 16 May 2020 - 01:00 PM
#23
Posted 23 May 2020 - 03:47 PM
Then I visited my mate with 5000 cars in the back yard and scrounged two from EH engine pipes. He socked me $5 for the pair. Mates rates I suppose.
#24
Posted 04 June 2020 - 08:55 PM
#25
Posted 05 June 2020 - 09:34 AM
yep i got mine a few days ago,exhaust guys like them so cars about to get another tow truck ride
