Banjo gears
18 replies to this topic
#1 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 12 October 2019 - 11:10 AM
Hi all,
Someone here would know. Can you get lower gears than 2.78 for the Banjo housing?
I've asked a couple of diff rebuilders and they haven't heard of any - does anyone know if you can aftermarket gears from overseas like the US?
Cheers TrickyD
#2 S pack
Posted 12 October 2019 - 01:06 PM
If you actually mean ratios that are taller than 2.78:1 then I believe the answer is no.
#3 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 12 October 2019 - 06:22 PM
Thanks S pack
#4 rodomo
Posted 12 October 2019 - 10:32 PM
2.6?
#5 claysummers
Posted 12 October 2019 - 11:38 PM
2.60 only in Salisbury. Not sure if the UC WB VB 8 bolt Salisbury came in that ratio. If so it might be possible to build a 2:60 banjo. You’re going to need an M22 from a Tonner to launch. Or 13” rims with 40 series tyres, or muchos torque at the flywheel.
#6 yel327
Posted 13 October 2019 - 06:18 AM
Small Salisbury is a banjo just built differently so gears/ratios are the same, as are axles, hemisphere, yoke etc. I’d be checking what ratios were in Toyotas with a banjo or maybe Gemini but from memory they are all very low ratios like Sunbird. Borg Warner built the HK/HT V8 banjo for GMH and they were only ever 2.78 and 3.08. GMH made the 6cyl ones in 3.36 to 3.9. Not sure which made them for Toyota.
#7 S pack
Posted 13 October 2019 - 07:32 AM
Better off upgrading to a transmission with overdrive.
#8 RallyRed
Posted 13 October 2019 - 08:17 AM
just guessing here...but isn't there a physical size limit to what ill fit inside? ( i.e. crown wheel)...cant remember if its 2.55 or 2.78., but I thought one of them was close to touching the housing?
Edited by RallyRed, 13 October 2019 - 08:17 AM.
#9 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 13 October 2019 - 08:30 AM
2.78 is tallest bango.
#10 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 13 October 2019 - 08:39 AM
2.6?
Hey Rodomo that's Salisbury - not sure you could fit that in a Banjo housing
#11 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 13 October 2019 - 09:01 AM
Not sure, physically I don't think the sizes are hugely different between 3.55 and 2.78 - not to the point where you'll be touching the housing.
#12 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 13 October 2019 - 09:21 AM
Good points there, probably too much work for the sake bringing back 200 rpm at 100 clicks - that's all I want to do really.
Yeah I could run a larger rim / tyre circumference (currently 205/15/55 - volvo rims) but I want to keep the look original because the car come with an XU1 dash and M21 box optioned from factory as is displayed on the plate.
Was just checkin if someone somewhere - even if overseas, fabricated different ratios for the housing.
Might have to accept 2200 rpm @ 100 clicks.
#13 yel327
Posted 13 October 2019 - 09:45 AM
What car is it?
#14 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 13 October 2019 - 02:00 PM
What car is it?
LJ Torana 4 door behind 202 and M21
#15 yel327
Posted 13 October 2019 - 02:58 PM
M21 box? Typo?
#16 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 13 October 2019 - 03:35 PM
Just out of curiosity, how often do NOS  Banjo crown wheel and pinion set in say 3:36 come up for sale as would be keen if it did irrespective of price (within reason)
#17 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 13 October 2019 - 05:37 PM
https://www.ebay.com...ekAAOSwjvRa8nP~
#18 TrickyD
TrickyD
  • 60 posts
  • Name:Mick Dehn
  • Car:LJ Torana SL
Posted 16 October 2019 - 09:18 AM
M21 box? Typo?
M21 4 speed box, no typo.
#19 yel327
Posted 16 October 2019 - 09:42 AM
So a V8 box in an LJ 6cyl 4 door? Awesome ID plate mistake! They don’t often get them that badly wrong!
Or is it some sort of internal GMH car?
