Ve Commodore Exhaust Sensors
Electrical
11 replies to this topic
#1 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 20 January 2020 - 12:38 PM
Hello to all,
My brother purchased my VE SV6 (2006 or 2007).
Hey stuffed the motor and had an engine swap. From what I can gather, they were both LY7 motors.
I think the two back sensors have a different plug. Computer saying take it to a GMH dealer.
Anyone have some advice .
Rainman
#2 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 20 January 2020 - 01:41 PM
Take it to a gmh dealer? swap the sensors with the ones off the old motor?
Probably need more info - what sensors are we talking about? What exactly did the scan tool say ie. codes etc. Did he use his original ecu or the one that came with the new motor, as that will need to be reprogrammed to match the bcm & key reader etc...
#3 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 20 January 2020 - 02:06 PM
Hey Garth, thanks for your reply. Its as I thought after having a read on google search. His mate at work had a damaged VE, so his mate done all the work. I don't think they used a scan tool. I feel bad, as I sold him the car around a year ago. He has no idea about cars. Not saying I do. I will advise him to see if there donar car is still available for required parts , then off to a dealer. Cheers Garth
#4 Rockoz
Posted 21 January 2020 - 10:21 AM
Was the exhaust modified at all on either car?
Altering the exhaust can have some issues with the rear set of O2 sensors not getting the info they need.
It will then throw a code at you.
But it doesnt actually hurt anything.
Had a similar thing in my 06 VE SS.
Eventually the computer seems to think it has been telling you something is wrong for long enough, then it starts to throw more codes at you to get your attention.
A simple reset with a scan tool fixes it for another period of time.
If you can get it programmed to ignore the rear sensors, then it wont be any issue. But that costs coin, and a dealer wont do it.
The simple scan tools that you can buy for sub $100 that can reset codes will likely do the job.
Just plug it in and reset and away you go again.
Hope that helps a little.
#5 Dr Terry
Dr Terry
  • 3,359 posts
Posted 21 January 2020 - 11:55 AM
Just use the old sensors which have the correct plug.
Also you must use the old ECU, as this is the one programmed to your car's VIN etc.
They might both be LY7 engines, but make sure the replacement unit came from a VE. If it came from a VZ, you will need to swap several other sensors as well, they won't be compatible.
Dr Terry
#6 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 09 March 2020 - 05:19 PM
Thank you Dr Terry, unfortunately the ecu was not purchased. My brother is a Ford person, let's say no more. The car starts and drives but after a month it cuts out. I have a Pic of the old sensors and the new wiring loom sensor connector. Going to try a new connector from the loom to the old sensor if possible. First is old sensor connection. Second Grey color, new connector I need to match is the square black one.
#7 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 09 March 2020 - 05:24 PM
Anyone know what loom pce I need? Rainman
#8 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 09 March 2020 - 07:09 PM
if they are both ly7 engines is ok
but you need to use the sensors that fit the plugs ofyour car
that would not cause the car to cut out
is the management light on !
does it run smooth at idle or under load
to fit a vz engine in a ve you need to change the cam drive cogs
the engine woundn't anyway
cheers  bat
#9 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 09 March 2020 - 07:49 PM
Thanks bat, both same engine. The black one at the top is the one on the exchange motor. The bottom Pic is the old sensor loom, still connected to the sensor that ran the removed motor. I hope to get a replacement into the top Pic to the old or new sensors as well? Rainman
#10 Dr Terry
Dr Terry
  • 3,359 posts
Posted 10 March 2020 - 07:03 AM
There are several different sensors for VE V6 Commodores, that model series ran for nearly 7 years.
Don't muck around with patch harnesses, just buy the correct sensors for the job, they won't be that much more expensive. Besides, one of those sensors is a 5-wire & the other a 4-wire, so they are incompatible.
I stock all of these sensors & the worst case scenario is $130-$140 including GST per sensor.
Phone me on (02) 9644-2888 & I will explain further.
Dr Terry
#11 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 10 March 2020 - 09:14 AM
if i understand correctly you didn't use the old engine harness
that could be the problem
i work for just commoder wreckers
we found that if there is any difference in the harness's we always use the original
got caught a couple of times
had many customers come in with engine light, running after market sensors
put second hand originals in fixes the problem
cheers  bat
Edited by bat 53, 10 March 2020 - 09:15 AM.
#12 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 07 June 2020 - 01:32 PM
Hey Dr Terry, I will give you a call on Tuesday. Ray
Also tagged with one or more of these keywords: Electrical
