Water pump bosses.
14 replies to this topic
#1 Shiney005
  • 9,970 posts
Posted 28 October 2020 - 11:43 AM
Are the hubs (centre bosses) the same size on six cyl and V8? The bolt pattern? ie Will the water pump pulleys interchange? I believe later XU1's might be the same, but don't know about the rest and don't have one here to check.
Attached File  zz.PNG   197.79K   2 downloads
Edited by Shiney005, 28 October 2020 - 11:44 AM.
#2 claysummers
  • 3,748 posts
Posted 28 October 2020 - 12:00 PM
Two different bolt spacings for six cylinder. Pre HR have a smaller spacing but also a shorter snout so may not help you, but bear in mind belt offset also needs to be considered. V8 I don’t know. It’s a Dr Terry question.
#3 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 28 October 2020 - 12:55 PM
Got a long snout V8 pump delivered just this morning, I can measure the boss when I get home if no-one knows...
#4 Shiney005
  • 9,970 posts
Posted 28 October 2020 - 02:09 PM
I have got plenty of V8 ones. I need a measurement from a six..
#5 _Lazarus_
_Lazarus_
Posted 28 October 2020 - 04:17 PM
Yes I've taken a plastic Nissan fan from a 6 and put it on a 253.The later type of water pump..
Edit.
Ah ok, I answered too quickly. I can easily check too.
Edited by Lazarus, 28 October 2020 - 04:19 PM.
#6 _Lazarus_
_Lazarus_
Posted 28 October 2020 - 04:34 PM
Yep. Fan extension from V8 water pump fits straight on to later style 6 water pump.
#7 Shiney005
  • 9,970 posts
Posted 28 October 2020 - 04:41 PM
Thanks Mark. Champion.
#8 claysummers
  • 3,748 posts
Posted 28 October 2020 - 09:30 PM
But is the groove offset same? Probably........
#9 Shiney005
  • 9,970 posts
Posted 29 October 2020 - 08:39 AM
Do you mean on the pulley Clay?
#10 claysummers
  • 3,748 posts
Posted 29 October 2020 - 12:00 PM
Yes Laurie. I thought you were looking at using v8 pulley on a six. Probably the offsets are the same, probably.......
#11 Shiney005
  • 9,970 posts
Posted 29 October 2020 - 12:29 PM
Sorry Clay, I didn't make myself clear.  I was actually wondering if you could run the V8 fan on a six cyl water pump and vise versa.
#12 yel327
  • 13,939 posts
Posted 29 October 2020 - 12:35 PM
The viscous clutch fans are interchangeable afaik.
#13 arrimar
arrimar
  • 3,134 posts
Posted 29 October 2020 - 01:10 PM
Is the answer in here Laurie...
http://www.gmh-toran...l34-engine-fan/
#14 Shiney005
  • 9,970 posts
Posted 29 October 2020 - 04:02 PM
I have so much trouble finding old threads in this place. But yes thanks Howard.
#15 76lxhatch
  • 7,227 posts
Posted 29 October 2020 - 08:27 PM
The spacers are interchangeable so as long as the fan clears it would be too.
