TH700r4 oil condition
Auto TH700r4 bad oil
6 replies to this topic
#1 Braderunner2
Braderunner2
  • 23 posts
  • Car:UC Sedan
Posted 15 December 2020 - 03:10 PM
Hi Gurus, I just bought an unlicensed UC with 5L, Built TH700, 9” diff. Drove it home from wharf, seemed OK. Just reversed it onto grass and did coolant change. Had to go high revs to reverse car back off grass (was slipping). Checked tranny level, had to drain 1litre of darkish smelly atf. Decided to drop pan. What are the attached photos telling me to do... take it for a rebuild? Any recommendations for Perth/Freo area? Any idea what may need to be replaced (the old piece of string question:) )
Cheers Paul
#2 LXCHEV
  • 3,670 posts
Posted 15 December 2020 - 03:28 PM
Are there pieces of metal in there, or is it just sludge?
Slipping can often be a sign of low fluid level (assuming it's not worn clutches of course). But are you saying it was overfilled by a full litre? (Check fluid level with car running, up to temp and in park).
If it's just sludge, I wouldn't freak out at that personally. May not have been serviced in a long time. I'd try to do a full flush with fresh ATF throughout the whole system + new filter.
Edited by LXCHEV, 15 December 2020 - 03:29 PM.
#3 Braderunner2
Braderunner2
  • 23 posts
  • Car:UC Sedan
Posted 15 December 2020 - 04:04 PM
Thanks LXChev… Yes, once I had started the car, run it through the gears, then checked the tranny level it was at the HOT rather than COLD full level...I removed 1Liter to take it down to COLD full level. There are about 50 or so small "slivers" of Aluminum...but no chunks/pieces of plates etc.
#4 Braderunner2
Braderunner2
  • 23 posts
  • Car:UC Sedan
Posted 15 December 2020 - 04:47 PM
Just cut open the old filter...
#5 arrimar
arrimar
  • 3,134 posts
Posted 15 December 2020 - 06:42 PM
Does "built" mean assembled by a carpenter?
#6 rexy
  • 3,788 posts
Posted 15 December 2020 - 10:27 PM
To clarify, does it drive ok or not?
#7 Braderunner2
Braderunner2
  • 23 posts
  • Car:UC Sedan
Posted 16 December 2020 - 10:47 AM
Hi There Rexy, I have only driven it ~7km (as it is unregistered at the moment). It seemed to drive OK in the forward gears. I will replace the filter and flush with new Dex111 and test out reverse in and out my drive a few times...and hope that nothing catastrophic is going on. Cheers Paul
Also tagged with one or more of these keywords: Auto, TH700r4, bad oil
