Torana LH door scuff plates-what finish
43 replies to this topic
#1 tsn007
tsn007
  • 1,022 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 01 January 2021 - 09:56 PM
hi all
Happy New Year
what was the finish on the scuffs plates on LH Torana's
galvanised
zinc
painted
chrome
#2 Statler
  • 6,341 posts
Posted 02 January 2021 - 10:50 AM
Depends on the spec .
If it's a S (VB) poverty pack they are usually gal .
Upspec (VC / VD) are zinc . i.e shiny .
I don't think there is any rhyme or reason . Whatever they had in the parts bin on the day.
#3 yel327
  • 13,939 posts
Posted 02 January 2021 - 12:20 PM
Holden and Belmont were a zinc/gal look and possibly just painted in some cases. Kingswood, Monaro, Kingswood SL, HX-HZ Sandman, GTS, Monaro LE and LS, Premier, Statesman, Statesman SL/E and Statesman Caprice were all chrome (bright). I would have thought Torana would be the same, ie the low spec car (S) would be zinc and SL, SL/R, SS and SL/E chrome. I'd have all the finish specs somewhere.
#4 S pack
  • 15,795 posts
Posted 02 January 2021 - 02:14 PM
Scuff plates are bright zinc for all LH & LX 69 models.
#5 yel327
  • 13,939 posts
Posted 02 January 2021 - 02:32 PM
That explains why there were no chrome Torana ones in my shed when I got rid of all Torana stuff! The last Torana ones I had were zinc hatchback ones, not sure what they were off.
#6 S pack
  • 15,795 posts
Posted 02 January 2021 - 03:02 PM
All LH/LX 77 models have the same scuff plate part numbers. I didn't mention 77 models in my previous post as I did not know if they all had bright zinc or chrome.
Looks like they were all bright zinc like the 69 models.
#7 yel327
  • 13,939 posts
Posted 02 January 2021 - 03:17 PM
These must have been off my LX SL hatchback as I put chrome ones in it. Not bright zinc though, just a dull grey look same as a Belmont.
#8 S pack
  • 15,795 posts
Posted 02 January 2021 - 05:49 PM
They would have been nice & shiny when they were brand new.
#9 hanra
  • 11,050 posts
Posted 02 January 2021 - 06:28 PM
Yeah I had mine zinc plated.
#10 Shiney005
  • 9,970 posts
Posted 03 January 2021 - 08:55 AM
That maybe the case, but there might have been a couple of different suppliers. From what I have seen over the years, I reckon there were both cad plated and zinc plated ones. The zinc ones in my car are still quite shiney.
#11 S pack
  • 15,795 posts
Posted 03 January 2021 - 10:15 AM
Got me stuffed why I said all LH/LX 77 models. There were no LH 77 models. Oh the joys of growing older.
#12 S pack
  • 15,795 posts
Posted 03 January 2021 - 10:18 AM
Yes, quite possible many parts that we might think were zinc plated were actually cadmium plated. Point is that no LH/LX Torana was fitted with chrome scuff plates.
Edited by S pack, 03 January 2021 - 10:20 AM.
#13 Ice
  • 15,227 posts
Posted 03 January 2021 - 10:20 AM
They still rust doesn’t matter what you coat them with
#14 hanra
  • 11,050 posts
Posted 03 January 2021 - 10:48 AM
I originally had my scuff plates cad plated and they turned black within a few months in storage whilst I was building the car. Had to send them away to get zinc’d.
#15 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
  • Car:SLR5000 LH Torana
Posted 03 June 2021 - 10:30 AM
Hi all  I have just removed mine and my guess is they are steel and painted with a zinc like paint, I started to clean up with a wire brush, paint comes off easy enough, I was going to just clean right back and undercoat and spray with a zinc finish, but after seeing Hanra's I might get zinc plated.
Howie
#16 hanra
  • 11,050 posts
Posted 03 June 2021 - 11:26 AM
Mine have dulled somewhat over the years.
#17 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 03 June 2021 - 11:50 AM
If you were doing again would you still zinc plate, just rang one place over phone estimate $240 for the four plates with a 7week turnaround.
Might go back to original idea of prime and paint.
Howie
#18 hanra
  • 11,050 posts
Posted 03 June 2021 - 12:09 PM
If your restoring your car to original. Then yes I would re-zinc them. Will the car be finished within 7 weeks? If not, send them away now.
#19 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 03 June 2021 - 12:18 PM
#20 claysummers
  • 3,748 posts
Posted 03 June 2021 - 02:19 PM
Howdy Howie,
I replied in the new thread you started, Maybe datto could copy the other thread here and delete (or cbf?).
Clay
#21 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 04 June 2021 - 11:24 AM
So is that what they were like new
Howdy Howie,
Clay
Sorry Clay I don't like starting new threads, but I cant work out how to add pics to old threads
Howie
Hi Hanra your zinc plated scuff plates was that back to what was original or just a finish you decided on.
Howie
#22 hanra
  • 11,050 posts
Posted 04 June 2021 - 11:53 AM
Get em Zinc'd. Youl'll be right. Dont get them Cad plated.
#23 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 08 June 2021 - 02:13 PM
All of the scuff plates where bright zinc, or cadmimum based. Technically the should both give the same colour, but the brightner would have alterted the reflection. I can't plate anything that long, so i to will be chasing a shop in qld preferably to produce a finnish like brad had pictured. To me that's how they should look. You probably won't find anyone using cadmium now, because of how toxic it is.
#24 Shiney005
  • 9,970 posts
Posted 09 June 2021 - 02:12 PM
I have over a hundred photos of brand new Toranas, and not one shows the scuff plates.
This one is unrestored, and it is hard to believe that it was ever bright.
Attached File  Burns and Co auction july 2019 d.jpg   128K   14 downloads
#25 hanra
  • 11,050 posts
Posted 09 June 2021 - 03:30 PM
You should see what mine look like now.
