202 very rough idle at lights while in D
engine stall
12 replies to this topic
#1 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 19 January 2022 - 10:56 AM
Hi All,
A bit of a long shot but hoping that I could gain some insight into an issue that has just appeared.
Just replaced both unis, and replaced the bearing/seal/locking ring on one axle in my banjo. They all seem to be doing great. However car seems to stumble and surge while in D waiting at the lights, if the lights are long enough the car actually will stall. It will also hesitate/misfire when taking off too.
One thing I've noticed is that when If I pull up to the light and pull the choke out a cm or 2 it doesn't have this issue. Also it doesn't have any of these issue when driving.
I've spent the last few days racking my brain trying to figure this one out, but haven't had any luck!
Edited by avoidev, 19 January 2022 - 10:56 AM.
#2 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 19 January 2022 - 12:10 PM
Pulling the choke on is raising the idle speed for you?
Should also be richening up the idle mixture too.
(Assuming the choke flap and all the bits are there)
Is it idling ok in park?
Maybe the mixture screw needs richening up a tweak
#3 rodomo
Posted 19 January 2022 - 12:19 PM
Sounds like a vacuum leak
#4 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 19 January 2022 - 01:06 PM
Hey Bruiser,
It has the exact same problem in park, and reverse with the foot brake on. It'll idle fine for 15-20 seconds and then begin to falter/surge and gets progressively worse up until it stalls.
It also seems to be completely fine at lights for the first 20 minutes of my drive, then it'll begin playing up.
I should also add that it has the bog stock standard stom carby on in, it was rebuilt by a shop 12 -16 months ago.
Hi Rodomo,
From what I can see the carby has a single vacuum hose that runs off it to the dizzy, I done the ol' suck test and seems to hold vacuum fine. The other I could see is one that goes from the intake manifold to the auto tranny. This too seems to hold up to the suck test.
Thanks Gents!
Edited by avoidev, 19 January 2022 - 01:09 PM.
#5 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 19 January 2022 - 01:22 PM
Theres more places a vacuum leak could be.
Anywhere there is a joint, fitting or hose in the carby, or manifold
could be one.
If the brakes being on has an effect, it could be the brake booster itself.
But pulling the choke fixes it - every time?
#6 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 19 January 2022 - 01:30 PM
could be one.
It doesn't necessarily fix it, but prevents it. If that makes sense.
Like if I pull up to the lights, and pull the choke on a tiny bit the idle doesn't get worse and worse. However if it is already running like shit then pulling up the idle doesn't return it back to normal.
Thanks,
#7 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 19 January 2022 - 06:52 PM
could be a float problem
#8 caterham2
caterham2
  • 349 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 19 January 2022 - 07:14 PM
PCV Valve?
#9 rodomo
Posted 19 January 2022 - 08:40 PM
Standard 202? Check the 2 big screws that hold the float body onto the throttle body.
#10 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 20 January 2022 - 09:24 AM
Thanks for the suggestion UCSLE, I'll give it a geez this arvo.
PCV Valve?
Thanks Caterham, I'll have a look.
It's pretty standard 202, the only mod is a blue HEI dizzy.
#11 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 30 January 2022 - 09:40 PM
Well gents, just for the record it appears to have a been the coil on its way out. Replaced it with another 12v coil I had kicking about and it seems to run a dream. Thanks for all the help and suggestions!
#12 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 30 January 2022 - 11:23 PM
Ahaha
Good news
At least we sorted all your carby problems out for you
Hehehee
#13 caterham2
caterham2
  • 349 posts
Posted 31 January 2022 - 07:44 AM
Ahaha
Good news
Hehehee
And the PCV valve :D
Also tagged with one or more of these keywords: engine, stall
