LX repo GTS mirror broken/ repair option
4 replies to this topic
#1 Claude
Claude
  • 36 posts
  • Name:Claude
  • Car:LX hatch 76
Posted 06 March 2022 - 04:30 PM
Hi guys for anyone interested, I recently had the glass fall out of my drivers side door mirror housing and lost the little pivot washer. Also the glass broke.
Now you can buy a replacement glass cost $30. But it doesn’t come with the washer or a new fitting male socket. I think you’re supposed to remove the old one off the broken glass glue it to the new one then use the old washer and pop it back in. The other alternative is to buy the whole unit around $180.
and get it painted, mean while you have this housing you can’t really use.
issues I had were, once the glass comes out the first time, it’s prone to doing it again as the socket is worn also if you loose the pivot washer like me you have to do something that doesn’t really do the job.
So for the cost of a new mirror a Bunnings part a bit of stuffing around I came up with the following modifications that enable you to use the old housing and also should be able to re-do it, if the glass breaks again with ease. Attached File  5805E049-EC10-426D-A2B7-E7369B260DE6.jpeg   135.42K   4 downloads
the old mirror housing female socket is moulded and screwed in from the other side
you have to grind these down and drill them out.
Attached File  8D93F6EE-D2E5-4D7A-9C29-E561C8DC5F64.jpeg   123.59K   3 downloads
the Bunnings part cost $7-10.
Attached File  ECB3405A-C09B-465B-BC98-1E455B7EB29F.jpeg   223.19K   3 downloads
old broken mirror with male part
Attached File  4874514E-AFCC-4B02-8D80-A258241A09CA.jpeg   92.53K   3 downloads
housing with bit removed
Attached File  939BF033-4359-46D6-960A-9D9F28227ED7.jpeg   81.89K   2 downloads
the part removed and modified cut around 1cm off the shaft.
Attached File  CD5354A6-146D-4B34-BC69-127150DBBB00.jpeg   59.86K   3 downloads
modified Bunnings part
Attached File  CC3E8942-A174-49C9-813F-1A8B8D6818EB.jpeg   75.23K   2 downloads
both parts bolted together
Attached File  53EFC8A2-CCE4-42D7-ACBF-E9D59D6778AC.jpeg   82.77K   3 downloads
Then screwed upside down back into housing with new screws accessible from top
notice there is only 3 screws it’s because I couldn’t get 1 out.
Attached File  58025596-C058-4B4B-BADB-940C77C750EE.jpeg   129.56K   5 downloads
Just glued new mirror onto the new ball joint face. It pivots well possibly needed a couple of stoppers glued on to stop excessive movement. Just have to reattach to car.
Hope this helps someone with another option cheers
#2 Ice
Posted 06 March 2022 - 04:54 PM
Wow thats great info i got a box of these all in a state of a disrepair
#3 RallyRed
Posted 06 March 2022 - 05:41 PM
Luv your work...those Bunnings thingos are useful. I used thesame thing for a clutch pedal stop in a track car.
Adjustable to be just right, and the black bit pivots to match the floor angle vs. pedal bracket angle.
Nice mirror fix.
#4 Heath
Posted 07 March 2022 - 09:38 AM
Very nice!
#5 Statler
Posted 07 March 2022 - 01:37 PM
Cool.
Any glass place can cut a new mirror. I think mine were $10 ea,
