LH Gpak Build
163 replies to this topic
#1 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 28 October 2022 - 09:56 PM
Hi Guys,
Recently my Dad bought an LH Gpak locally of a guy that drove it around on his P plates when I was driving my old UC around.
It sat outside rarely driven for the last 10 years which took its toll on the car.
On the plus side it came with both full rear quarter cuts which will come in handy. it's a complete still drive able car thay hasn't been cut up at all or bastardised too badly.
At this stage the plans are for rust repairs, a home paint job and get it on the road with the 202 and 4 speed. It won't be retaining the Gpak scheme as Dad doesn't like it.
Car as purchased
Attached File  Screenshot_20221020-161315_Messenger.jpg   103.34K   32 downloads
Attached File  20221021_191314.jpg   625.05K   30 downloads
Started stripping the car down to assess the worst areas.
Attached File  20221023_110502.jpg   165.08K   17 downloads
Attached File  20221021_122810.jpg   114.92K   17 downloads
radiator support panel won't need any rust repairs.
Attached File  20221021_191308.jpg   621.62K   17 downloads
#2 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 28 October 2022 - 10:00 PM
Rear floors are pretty solid considering with a couple of small holes.
Attached File  20221021_191423.jpg   120.59K   17 downloads
Lower guards are both good.
Attached File  20221021_191346.jpg   124.22K   17 downloads
Drivers floor is good.
Attached File  20221021_191407.jpg   129.61K   16 downloads
Boot floor is actually pretty solid although will need a few patches. Hoping to get away with not replacing the whole floor.
Attached File  20221021_191523.jpg   103.22K   16 downloads
Roof/ Gutter above the passengers rear door is buggered.
Attached File  20221021_191508.jpg   423.66K   16 downloads
#3 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 28 October 2022 - 10:06 PM
With the parcel shelf as bad as it is, a replacement has been sourced and should be getting picked up next weekend.
Attached File  20221023_141714.jpg   185.75K   15 downloads
Attached File  20221023_141733.jpg   629.73K   15 downloads
Attached File  20221021_191220.jpg   510.25K   15 downloads
Started unpicking the parcel shelf on the car to see what we're working with underneath.
Attached File  20221028_142520.jpg   142.62K   13 downloads
Attached File  20221028_140043.jpg   161.25K   14 downloads
#4 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 28 October 2022 - 10:13 PM
Under the rear windows section is pretty buggered. still deciding on whether to go all the way to the seam with the new parcel shelf or cut and weld.
The inner section will need repairs either way.
I drilled through in most Ares as the majority of the parcel shelf is getting replaced as is the whole lower rear windows channel.
Attached File  20221028_135938.jpg   149.7K   11 downloads
Attached File  20221028_140050.jpg   148.39K   14 downloads
Attached File  20221028_135517.jpg   148.5K   17 downloads
While unpicking the section of parcel shelf, Dad worked on stripping and priming the spare rust free bootlid.
Attached File  20221028_142856.jpg   171.19K   16 downloads
#5 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 31 October 2022 - 08:04 PM
Looks like a lot of work but well worth it.
Keep them coming.
#6 Shiney005
Posted 01 November 2022 - 03:46 PM
That roof section will be a pain in the butt to repair.  More photos of the work as it happens please.
#7 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 03 November 2022 - 02:16 PM
Will do as there is more progress. Currently waiting for the parcel shelf cut to arrive before I cut anything else out.
There's a few repairs on this car that won't be fun, I'll try document as much as I can. I'm no expert and neither is Dad so a bit will be learning along the way.
#8 Statler
Posted 03 November 2022 - 02:25 PM
Now is a good time to be thinking of putting retractable seatbelt in the rear. :)
What are your plans Hawk?
#9 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 06 November 2022 - 06:22 PM
If it was mine, it would be going factory Gpak scheme. Dads plan is aquamarine at this stage, no flares. Keep it 202 aussie 4 speed.
Waiting to get the parcel shelf before cutting too much up on the rear of the car. The lower area on both shelves have issues so I made up a patch panel ready to go. It will be trimmed based on how much of the parcel shelf we replace.
Made it out of 1.2mm cold rolled steel. Shaped with a hammer and chisle.
The tabs on the boot Chanel side are to replace the rusty sections, while leaving the good metal there.
Paper Template:
Attached File  20221106_121401.jpg   164.66K   13 downloads
Bent to shape:Attached File  20221106_140821.jpg   121.36K   13 downloads
Test fits pretty well for my first ever patch made from scratch.
Attached File  20221106_133423.jpg   179.11K   13 downloads
In the meantime Dad stripped and rust converted the spare bonnet.
Attached File  20221106_133542.jpg   312.67K   13 downloads
#10 skap
skap
  • 1,161 posts
  • Name:Skap
  • Car:Mighty VN
Posted 06 November 2022 - 06:48 PM
Far out, lots of hard work ahead ;)
#11 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 12 November 2022 - 08:38 PM
Well the parcel shelf cut was finally ready for pickup today. So made a start assessing what is usable and prepping it for fitment.
As supplied
Attached File  20221112_134312.jpg   299.55K   17 downloads
top panel removed, we are going to need to make one good one out of the two, then patch a couple of sections that are bad on both.
Attached File  20221112_144131.jpg   292.98K   17 downloads
Lower section of the new one was rougher than I was hoping for so we will need to use the one on the car and patch it.
Attached File  20221112_144137.jpg   299.97K   16 downloads
Prepped on all sides, might get it blasted before installing to save a bit of time.
Attached File  20221112_155532.jpg   171.1K   12 downloads
Got this section off the same car the parcel shelf came from
Attached File  20221112_160511.jpg   228.9K   12 downloads
Also a massive Thankyou to forum member Cook for helping out by giving me a floorpan he didn't need.
Attached File  20221112_160537.jpg   167.71K   10 downloads
Hopefully tomorrow I'll start cutting the parcel shelf out of the car now we know what we're working with.
In the meantime Dad repaired a hole in the underside of the bonnet and primed it.
Attached File  received_2304419853067369.jpeg   99.13K   10 downloads
Attached File  received_5658290524252158.jpeg   163.64K   11 downloads
Attached File  received_693994795472028.jpeg   153.14K   11 downloads
#12 Statler
Posted 13 November 2022 - 03:19 PM
Me too. :)
#13 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 13 November 2022 - 05:47 PM
Cut out the existing parcel shelf today and cleaned up the old spot welds.
So far it appears to fit well.
I'm hoping that by documenting the repairs thoroughly it can help anyone else who has similar repairs to complete.
One interesting thing to note is that the UC repair panel didn't appear to have the support brackets from the wheel tub to the parcel shelf while the LH does. This has changed the plan of attack in thay area for us, now opting to patch the existing corner rather than use the UC section due to the sheer number of spot welds to drill out.
Attached File  20221113_132139.jpg   203.71K   11 downloads
Attached File  20221113_152414.jpg   224.65K   10 downloads
Attached File  20221113_152425.jpg   193.25K   10 downloads
Attached File  20221113_152709.jpg   229.62K   9 downloads
Attached File  20221113_152703.jpg   194.81K   10 downloads
#14 Heath
Posted 14 November 2022 - 08:45 AM
Well done! Hopefully you can maintain this pace. Looks like you're giving it a properly concerted effort.
The braces you're talking about... as in wheel tub to parcel shelf?
Present on the LH, but not present on the UC, correct?
I guess similar to the LX Torana hatchback always having the tubs tied into the sides of the car, but only some UC's having it.
#15 RIM-010
Posted 20 November 2022 - 06:42 PM
Nice work! Keep it moving
#16 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 20 November 2022 - 07:53 PM
Well I've been out of action for the last week getting my Galbladder removed.
Dad spent the week stripping and repairing the nosecone. it was in pretty bad shape but not rusty. He was going to source a better one but I convinced him to use the one we have.
drivers side headlight surround on the nosecone had previous filler work so that was left alone and the passengers side top section above the grill was dented pretty bad.
first up was filling the holes in the lower nosecone.
Attached File  1000000456.jpg   160.83K   10 downloads
Dent knocked out as good as possible and filled.
Attached File  received_542600453914907.jpeg   127.5K   8 downloads
In hifill primer ready for shadow coats.
Attached File  20221120_145346.jpg   161.14K   8 downloads
I did a little today, against the doctors orders. Couldn't help myself.
Removed the last of the rusty section on the drivers side. Decided to patch here rather than replace the whole section Just for ease of access.
The other reason is the UC parcel shelf didn't have this brace from factory.
Attached File  20221120_193844.jpg   197.52K   8 downloads
Attached File  20221120_192541.jpg   194.04K   9 downloads
Tomorrow's plan is to weld up the small hole on the C pillar you can see, make up the patch panel and possibly start welding it in.
#17 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 21 November 2022 - 08:12 AM
Wow it's coming along great Steve well done.
Not even an operation can slow you blokes down.
What would Doctors know anyway:)
#18 Shiney005
Posted 21 November 2022 - 08:35 AM
Don't forget to treat all inner panels while you have access to them.
#19 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 November 2022 - 10:43 AM
Thanks, thats the plan. we are planning to rust convert then use some kind of cavity spray. What would you recommend to treat it? Just a rust converter sealer?
#20 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 November 2022 - 08:20 PM
Ended buying rust converter sealer and sprayed that inside the brace. I'll apply cavity wax at some point as well.
Filled the hole in the C pillar
Attached File  20221121_114645.jpg   174.1K   6 downloads
filled a few small holes on the passengers side
Attached File  20221121_120716.jpg   199.74K   7 downloads
Made up the patch panel. Used weld through primer underneath and left the top raw steel.
Attached File  20221121_162244.jpg   139.48K   7 downloads
welded in
Attached File  20221121_174150.jpg   183.52K   6 downloads
After cleaning up the welds.
Attached File  received_2199741240196003.jpeg   60K   5 downloads
Attached File  received_1302511190549077.jpeg   47.86K   5 downloads
#21 Heath
Posted 22 November 2022 - 08:49 AM
Well done.
#22 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 24 November 2022 - 07:54 PM
A bit more progress over the last couple of days.
First up I had the new parcel shelf blasted and we primed it.
cut out a section on the passengers side of the parcel shelf
Attached File  20221124_123602.jpg   185.71K   12 downloads
patch made up and tacked in
Attached File  20221124_132243.jpg   192.35K   11 downloads
Finished
Attached File  20221124_151029.jpg   195.84K   8 downloads
Top side with the parcel shelf clamped in position for fitment checks
Attached File  20221124_152930.jpg   179.13K   5 downloads
Tomorrow the plan is to tackle the drivers side in the same spot. Then hopefully the parcel shelf can be welding in on the weekend.
Attached File  20221124_153349.jpg   200.75K   7 downloads
This is the upper panel after blasting. I cleaned up the lip and cut the required sections from the old one.
Attached File  20221124_135740.jpg   281.29K   6 downloads
On another note, I'm currently looking at an LX for myself which if I purchase will mean my UC will be for sale. Currently have it listed as EOI, to gauge any interest as I'd want to sell fairly quick if I get the LX.
#23 Shiney005
Posted 25 November 2022 - 08:53 AM
Any pics of the UC Steve?
#24 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 25 November 2022 - 10:30 PM
Got most of the other side done today. Ran out of wire and Gas so off to get more tomorrow.
Chop chop
Attached File  20221125_121543.jpg   216.62K   6 downloads
Attached File  20221125_125959.jpg   218.04K   6 downloads
Patch mostly in place.
Welds aren't the prettiest on the inside but have good penetration. just a prick to clean up being in the corner.
Attached File  20221125_151600.jpg   123.63K   8 downloads
As for the quarter being chopped up, it's getting a full drivers side quarter due to the wheel arch rust and damage around the tail light bucket. the quarter will come in past the boot hinge so that cut section is covered.
Attached File  20221029_163809.jpg   225.85K   8 downloads
#25 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 25 November 2022 - 11:13 PM
