Engineering in WA
LX SLR5000 replica
43 replies to this topic
#1 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 03 April 2023 - 04:04 PM
Hey guys a mate of mine has just purchased a really neat LX SLR5000 replica which was fully registered in Victoria
The car is neat and tidy and passed inspection without issue today.the trouble started when the department of transport didn’t recognise VIN and then after accepting VIN they declared car should be 6 cylinder and now have given him a complex vehicle modification form requiring engineering
Can anyone in WA recommend a decent engineer?
Thanks Garth
#2 yel327
Posted 03 April 2023 - 04:45 PM
Don't they use the NCOP in WA? It allows self-Engineering of optional engines in the Series. Section 1.1 of the attached:
https://www.infrastr...1jan2011_v3.pdf
So in theory he can fit a 5.0L as long as it has the V8 brake booster, nodular banjo diff centre with V8 yoke and the correct front springs/shocks etc.
How did they know from the chassis number that it was originally a 6cyl? I think he made a mistake and gave them the VIN instead. Rookie mistake maybe?
#3 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 03 April 2023 - 05:14 PM
Thanks for information mate
The car passed roadworthy and assessor did all of the submissions of paperwork via email to Perth from the country
The Vin number on vic rego papers and car tags/chassis were what was submitted
The department of transport did not recognise number and proceeded to conduct a forensic investigation into car
Not a rookie mistake
At the end of the day he is now in a position where he needs to get an engineer involved .
If anyone can steer us in the right direction I would appreciate it.
#4 yel327
Posted 03 April 2023 - 06:23 PM
Bugger, that is not good. I would never have provided them with the VIN as it means nothing to them, and hence why they didn't recognise it. The only numbers that would ever have been recorded in Victoria would have been the chassis number and engine number and there would be no official record of its VIN anywhere.
Someone here will be able to recommend an Engineer in WA that can help him. I reckon he could still do it himself if WA DOT use the NCOP, just needs the guidance of the Engineer what he needs to do. He's probably in a Catch 22 loop that is hard to get out of.
Nice Avatar car too.
Edited by yel327, 03 April 2023 - 06:24 PM.
#5 dattoman
Posted 03 April 2023 - 08:36 PM
Theres an approved list of engineers
Wheres the car ?
#6 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 03 April 2023 - 09:01 PM
Southwest WA
I know there’s an approved list on website
It’s a bit like getting a realestate agent or a mechanic or a doctor there are good ones and ones which you would rather not see again
Just thought I would reach out and see if anyone could recommend one ?
#7 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 04 April 2023 - 08:43 AM
Bit surprised it isn't covered by this?
Attached File  Screenshot_20230404-064156_Adobe Acrobat.jpg   173.88K   6 downloads
#8 yel327
Posted 04 April 2023 - 08:57 AM
That's exactly what I mentioned in the second sentence of post #2. Unless they have applied the very last line in that screen grab? Or if it has a non-original gearbox or 9", in which case it will need Engineering under the NCOP.
#9 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 04 April 2023 - 11:27 AM
Supra 5 speed and Salisbury will need engineering
#10 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 04 April 2023 - 12:32 PM
I see there's a engineer in Busso. When I did my hatch I just rang the numbers until I spoke to someone who I thought I could get along with. A bit like real estate agents really.
#11 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 05 April 2023 - 10:37 AM
for some reason in wa if you change from a six to an 8
even if the same car had that engine   it has to be engineered
i use SAM ROSSI
but now he is semi retired and chooses his work
Edited by bat 53, 05 April 2023 - 10:40 AM.
#12 dattoman
Posted 05 April 2023 - 10:01 PM
Dan Pittic is good too
#13 Ice
Posted 05 April 2023 - 11:14 PM
i use SAM ROSSI
Never used to be like that
You need a mod plate for a set of extractors these days ffs
#14 dattoman
Posted 05 April 2023 - 11:27 PM
Stan is still trying to push the VSB14 thing
#15 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 06 April 2023 - 09:46 AM
my understanding is that his group would like to get rid of vsb14
and go the easts way , engineers do it all .
at least now they don't use a different calculation for force induction
only use the 180 kw per tonne
#16 yel327
Posted 06 April 2023 - 10:02 AM
WA can’t be using VSB14 if you need Engineering to put a 4.2 into a HJ for example that was originally a 3.3 or something not a 4.2?
#17 dattoman
Posted 06 April 2023 - 07:55 PM
Rego dept are covering their arses
We should be using VSB14
#18 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 07 April 2023 - 10:03 AM
the engineers report , is not for the engine
but for the brake upgrade to suit the v8
I would say that a least 80% of people don't do
#19 yel327
Posted 07 April 2023 - 11:08 AM
Brakes are the same, it is the booster that differs. Plus the suspension and the tailshaft/diff. Still VSB14 doesn't say you need an Engineer's Report (ie Certification) for any of that, it says if you fit an optional engine the associated components must also be fitted as well. So if I was to take a HJ Premier that was standard. If I wanted to put a 5.0L in it, I'd also have to fit:
Salisbury rear axle.
TH400 with associated stronger gearbox crossmember.
Tailshaft.
Front springs.
Plus anything else that came standard with the 5.0L engine for durability purposes.
Where it gets tricky is if I wanted to upgrade a HJ utility, the GVM is different between 6cyl and V8. Not sure how you go about changing that - it'd probably require Certification.
#20 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 08 April 2023 - 09:41 AM
have done a few changes also had a few that have been knocked back
to have the work done . all they did was thow a motor in and expected it all to be good
even told a couple not interested because of dodgy work
i do know a couple of people in the engineering department and the stories they told
would make your blood curl
#21 Ice
Posted 12 April 2023 - 10:54 PM
So whats involved in getting a 9 inch diff engineered in a Holden
as in whats the process ?
Does it have to be installed in the car or not
what are they looking for specifically ?
#22 yel327
Posted 13 April 2023 - 06:47 AM
They'd want to see the welding is done by a qualified welder, and that axles are not cut and shut - basically a receipt for the work undertaken. Same with the tailshaft. They'd want to see it has the Holden brakes on it otherwise you'd be up for brake tests. And they'd be looking for what bearings are used on it to determine what the rear axle loading is and what offset wheels you are allowed to run.
An easy example, when I upgraded my single axle 7x5 box trailer to 1400kg, what the Engineer wanted to keep in the records was:
Reciepts showing welding of steel and hangers under the trailer had been undertaken by a fab shop.
Receipt for the springs and axle showing the load capacity specs.
Load rating on the hitch, and on the Crewman wheels and tyres.
Receipt for the electric drums and the bearings showing the load capacity.
This was all done when it was in its undies, with bare welds. I pulled it apart a week later and got it hot dipped galvanised.
#23 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 13 April 2023 - 10:39 AM
recently completed a trailer 1500kg
didn't have to do any of that
not even engineering
#24 yel327
Posted 13 April 2023 - 11:36 AM
Would have been the same if I made this trailer. But it was an existing one that I modified, hence had to be Engineered. You can still home make them and affix your own compliance plate.
#25 Ice
Posted 13 April 2023 - 06:47 PM
Receipts you say the diff was built 30 years ago and so was the tail shaft and painted black with XD Ford brakes
So your suggesting it all has to pulled apart to be inspected ?
sounds like a costly exercise ffs
Cant i just say its a large Banjo  :)
