173 Bolts painted or not?
25 replies to this topic
#1 Flaming Skull 57
Flaming Skull 57
  • 143 posts
  • Name:John Harris
  • Car:LC Torana "Gilberts Stinger"
Posted 18 July 2023 - 03:08 PM
Hi All
When I restored my LC I painted everything on the engine RED, all bolts included. Now I have time I want to make sure the bolts are as they came out when manufactured. Painted RED or Unpainted.  Does anyone have a detailed picture of the original Engine/drive line?
I'm looking at
Thermostat top bolts
Thermostat lower housing to engine bolts
Alternator adjusting bolt.
Alternator slide tensioner/adjuster
Alternator Lower bracket
Alternator Lower bracket bolts
Starter motor mounting bolts
Engine mount bolts
6 x Side plate bolts
Rocker cover bolts and washers
Fuel pump mounting bolts
6 x Oil pump bolts
Head stud bolts
Distibutor clamp and bolt
Bellhousing bolts
Clutch inspection pan
John
#2 Flaming Skull 57
Flaming Skull 57
  • 143 posts
  • Name:John Harris
Posted 18 July 2023 - 05:25 PM
Also, should the bellhousing be painted RED?
#3 claysummers
Posted 18 July 2023 - 05:57 PM
I understand that the assembled long motors were painted with gearbox attached and the bellhousing just copped overspray where it bolted up. Based on that you can envisage which bolt heads wore red.
#4 yel327
Engines were run on natural gas then painted. They didn’t have a carb or alternator but had most everything else including bellhousing and clutch (or flex plate). So everything got painted with some basic masking hence why the overspray all over the bellhousing edges, over V8 valley cover etc. I can’t tell you exactly which bolts were painted and which weren’t but if you think about the above it will get you close. I don’t think they had an alternator or balancer pulley on them at the engine plant either.
Clay, gearboxes didn’t get attached until the VAP.
Edited by yel327, 18 July 2023 - 05:59 PM.
#5 claysummers
Posted 18 July 2023 - 06:05 PM
So just the bellhousing attached, thanks Byron. I’m old enough to remember when we converted over from “town” gas to natural gas. We had to get the stove re-jetted. Would have been about 1970. Very interesting that they spun them up on NG.
#6 yel327
Posted 18 July 2023 - 06:21 PM
It may not have been identical to gas we get plumbed today. Remember GMH like any industry would have used gas for any number of heating applications. The engine plant would have used it for a number of reasons. It may well have been Town gas, I just use the term as whatever was around in the 60’s and 70’s for industry and domestic purposes.
#7 claysummers
Posted 18 July 2023 - 08:34 PM
Hate to digress…..
Remember the gas works with the inflatable bladder in a steel cage what seemed like 30m high? Grey soot coating everything in a 40m radius. Corner of Sturt and Marion Roads where Pedders is now.
#8 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 19 July 2023 - 12:40 AM
This may help.Attached File  image.jpeg   61.97K   17 downloads
#9 Dr Terry
Dr Terry
  • 3,359 posts
Posted 19 July 2023 - 07:47 AM
On your list just about everything (including water pump & thermostat housings) was painted red, except the following:-
Fuel pump & bolts
Engine mounts & bolts
Alternator & bolts
Starter motor & bolts
Distributor clamp & bolt
Clutch cover & bolts
As mentioned above, the bellhousing copped a lot of over spray as did the part of the manifolds nearest the head (they were loosely masked off). The alternator adjusting arm & lower bracket were also painted in situ.
After painting, the distributor, starter & other items were then mounted prior to test running (on gas as mentioned), then the carby was fitted before fitting the engine to the car.
Dr Terry
#10 Indy Orange
Indy Orange
  • 2,987 posts
Posted 19 July 2023 - 08:41 AM
Another pic here .Note the small amount of overspray on the bell housing.
Edited by Indy Orange, 19 July 2023 - 08:43 AM.
#11 sibhs
Posted 19 July 2023 - 08:43 AM
Fuel pump & bolts
Alternator & bolts
Dr Terry
Hi Dr Terry, Surely the clutch cover is painted Red?
Regards
#12 Flaming Skull 57
Flaming Skull 57
  • 143 posts
  • Name:John Harris
Posted 19 July 2023 - 08:48 AM
Thank You everyone. Interesting about the engine being initially run on gas.
#13 Dr Terry
Dr Terry
  • 3,359 posts
Posted 19 July 2023 - 11:45 AM
Regards
This seems to vary from model to model. In the early days (EH/HD etc.) I believe the clutch cover was painted red, as was the water pump pulley.
However later cars have the water pump pulley painted black & the clutch/converter cover also painted black. I'm not sure when the change was.
Dr Terry
#14 claysummers
Posted 19 July 2023 - 02:14 PM
My HX clutch cover balancer and water pump pulley were all painted red from factory.
#15 yel327
Posted 19 July 2023 - 05:22 PM
I’ve never seen a red water pump pulley on any GMH 6cyl or V8 even imported V8 HK onwards. Having said that I haven’t taken much notice of 6cyl prior to HQ. I can recall seeing red ones on EH engines I think when I had a few 179’s way back.
#16 Dr Terry
Dr Terry
  • 3,359 posts
Posted 19 July 2023 - 05:48 PM
I'm not sure about the change to the clutch cover paint, but I think that the black water pump pulley was an HQ onwards thing. I'm certain that EH/HD/HR had red pulleys.
An interesting story on that one. We had a member of our car club asked us a question about the colour of the pulley bolts. We has an older guy visiting from Victoria who actually worked in the GMH engine plant & his answer was so precise.
He said that 2 of the bolts should be red & the other 2 should be plated. The reasoning was simple. The pulley was fitted in the engine plant using only 2 bolts before being painted. Then before the engine went into the car, these 2 bolts were removed to fit the (black) fan, then refitted. 2 additional (unpainted) bolts were then added.
One for the purists !!
Dr Terry
#17 Ice
Posted 19 July 2023 - 07:22 PM
Dont put over spray  on you’re bell housing
A -it looks like shit and
B -its  a bit wanky if you know what i mean  :)
#18 claysummers
Posted 19 July 2023 - 07:42 PM
Second thoughts my HX pulley most likely black and probably the HK as well.
#19 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 19 July 2023 - 08:39 PM
I've been told that the water pump wasn't painted. Were these fitted during testing the engine or did they have another way to run coolant etc through them for this purpose? Obviously if the pulley was fitted then the water pump was too. But was this constant across various time periods eg EH to LX etc?
#20 S pack
Posted 19 July 2023 - 09:10 PM
The clutch cover on my LJ was rocket red same as the engine. From memory (albeit sketchy) the fan pulley was black but I painted rocket red and no fan bolts ever had red painted heads.
Edited by S pack, 19 July 2023 - 09:11 PM.
#21 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 19 July 2023 - 09:26 PM
My 73 LJ has a black fan pulley.
#22 Indy Orange
Indy Orange
  • 2,987 posts
Posted 19 July 2023 - 09:42 PM
Made the mistake of painting mine until I discovered they weren’t painted,had to remove the paint and start again.
#23 claysummers
Posted 19 July 2023 - 10:08 PM
Heh heh heh…..
On the water pumps, my original HK 186 was unpainted as far as I can recall. I should have kept that but the subframe and hanging panels rusted to frOck.
#24 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 20 July 2023 - 12:25 AM
Same here
#25 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 20 July 2023 - 10:25 AM
unsure how original mine are
pulley and cover both rocket red
checking a photo of a cf engine they were painted
