Drivers side door mirror seal.
13 replies to this topic
#1 Shiney005
  • 10,074 posts
Posted 22 January 2024 - 12:26 PM
Wanted to buy.
I thought they were the same as Holdens, but the LH and LX Torana door mirrors have a different shaped gasket. The angle you can see from the end on shot is not present on the Holden ones because the shape of the door is different. The aftermarket ones are all of the Holden type.  Mine is still usable, but it has a chunk missing from it and would like to get a good one if there are any out there.
I am having trouble finding an RH exterior mirror in the HQ parts book to compare the part number.
Attached File  IMG_0517smaller.jpg   79.02K   5 downloads
Attached File  IMG_0518small.jpg   103.99K   5 downloads
Attached File  IMG_0519small.jpg   212.37K   6 downloads
#2 yel327
  • 14,007 posts
Posted 22 January 2024 - 12:54 PM
I'll look in HJ-HZ books for you. Somewhere in my shed would be (or at least would have been) Torana mirrors and seals off my hatchback. No idea where though. There were a pair of mirrors with those plastic bits attached with tie wire still inside the LH SLR5000 body that went to Greg at ClassicOzWreck to be cutup for rust repair sections, but its remainder was scrapped a few years ago. When I'm up on the mezzanine next I'll have a look at one of the shelves and see if there are mirrors up there still.
#3 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 23 January 2024 - 09:08 PM
From a scanned copy of a HJ parts manual. It doesn't have a cover in the pdf so I don't know what issue date the manual is
HTH Kev
#4 hanra
  • 11,064 posts
Posted 23 January 2024 - 09:35 PM
#5 Shiney005
  • 10,074 posts
Posted 24 January 2024 - 07:58 AM
Well that confirms it.  Now who has one lying around?  I suppose no one will want to give them up now. Ah well. Time to hit ebay.
#6 hanra
  • 11,064 posts
Posted 24 January 2024 - 10:49 AM
Im sure when I bought my NOS LH mirror it came with a packet of a few NOS rubber pads. Was so long ago. Ill have a poke around but I just cannot recall now.
#7 dattoman
  • 16,497 posts
Posted 24 January 2024 - 09:03 PM
Silver car ?
#8 Maccavee
Maccavee
  • 40 posts
  • Car:LH SL/R 5000
Posted 24 January 2024 - 11:55 PM
Just saw this post and thought I’d check my LH for ya, pulled it off the car and it turns out she’s actually got an HJ left hand side mounting pad.. haha
Good luck with the search
Edited by Maccavee, 24 January 2024 - 11:57 PM.
#9 Shiney005
  • 10,074 posts
Posted 25 January 2024 - 08:58 AM
Silver car ?
No mirror on either of those right hand front doors Datto. I will have another look in the loose stuff.
Edited by Shiney005, 25 January 2024 - 08:59 AM.
#10 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
Posted 25 January 2024 - 02:55 PM
Hi Laurie I went through my spare parts at home, the only LH one I have is damaged unfortunately, a piece missing and a crack at one end.
You can have it for the cost of postage if it's any good to you. Not sure if it could be plastic welded, probably only good for a sample if you were to try and get some 3D printed.
Cheers Kev
#11 Shiney005
  • 10,074 posts
Posted 25 January 2024 - 07:23 PM
Thanks Kev. I think mine might be in better shape though.  :)
#12 Shiney005
  • 10,074 posts
Posted 09 March 2026 - 12:12 PM
I have taken a few photos of the Torana and Holden ones side by side.  Brad, I don't suppose you had a look for your spares if you had any? Also chasing the gasket used to seal the screw holes in the door.
All picks are of drivers door mirror.
LH Torana on left. Holden on right.
Attached File  Mirror gasket. LH on left. Holden on right.JPG   94.73K   0 downloads
LH top. Holden bottom.
Attached File  Mirror gasket. LH on top. Holden on bottom.JPG   194.68K   0 downloads
Attached File  Mirror. LH Torana on top. Holden at bottom.JPG   290.47K   0 downloads
LH with the gasket for sealing the screw holes in the door.  Mine is broken, so I am looking for one of these as well.
Attached File  Mirror. LH Torana with screw gasket.JPG   319.5K   0 downloads
#13 hanra
  • 11,064 posts
Posted 09 March 2026 - 12:57 PM
I always planned to have a dig through my box of bits but it never happened.... Ill try to remember this weekend.
Is the gasket that comes in this kit no good?
Holden Mirror Support Lock Tab Kit HQ HJ HX HZ WB LH LX UC x2. GTS or Stalk - H1001
Edited by hanra, 09 March 2026 - 12:58 PM.
#14 Shiney005
  • 10,074 posts
Posted 10 March 2026 - 08:33 AM
Thanks Brad. I hadn't seen those Resto Country gaskets.  If I can find a good mounting pad I won't be too worried about sending my current one to Mick McArdle at RPA to get them reproduced.
