M20 gearbox part numbers.
10 replies to this topic
#1 gad05
gad05
  • 422 posts
  • Name:Graham
Posted 24 February 2024 - 06:35 PM
Just stripped a m20 box.
On the main case is part no. T453483.
What do the numbers mean ?
Cheers Graham.
#2 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 24 February 2024 - 06:45 PM
That's the serial number of the transmission, date of trans should be early 1973
#3 hanra
Posted 24 February 2024 - 07:20 PM
I’ve always known that my M21 gearbox was not original.
Its serial number is T423745.
Date code K52
10th May 1972?
#4 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
Posted 24 February 2024 - 07:48 PM
K52 will be October 5th 1972. The earlier format was month in letters A-L, A=January M=December (no I as to not confuse the I with a 1), then day of month 1-31 then last digit of year.
Early in 1973 the date changed to day, month (still as a letter), year e.g my GTR trans is 2K3 2nd October 1973 serial T552323
#5 Bigfella237
Posted 24 February 2024 - 07:56 PM
Yep, the early system was American, you know, how they have the month, then the day, then the year.
Cheers Graham.
Just out of interest, Graham, can you find the the three-character date code cast into that case as well?
#6 gad05
gad05
  • 422 posts
  • Name:Graham
Posted 24 February 2024 - 09:00 PM
Will have a look for that date code tomorrow.
l was told the box came from a LJ gtr wrecked in the nineties.
#7 Bigfella237
Posted 25 February 2024 - 09:20 AM
Also, if you have it apart (or at least have the selector cover off), try and find the part number stamped into the cluster shaft. That may help narrow-down what it came out of?
And the part number of the reverse gear will identify whether it was originally a 6 cyl M20 or V8 M20 (converted to 6 cyl)?
Well, assuming it hasn't been 'Frankenstein'd' together from odd parts, of course!
Edited by Bigfella237, 25 February 2024 - 09:24 AM.
#8 gad05
gad05
  • 422 posts
  • Name:Graham
Posted 25 February 2024 - 08:32 PM
Can only read last number on date code. 3 Assuming that means1973.
Cluster reads 2813496 L88.
#9 Bigfella237
Posted 25 February 2024 - 09:43 PM
Yep, 2813496 is just a standard M20 countershaft... Common to all the bog standard 4, 6 & 8 cylinder M20's.
Unfortunately, it's not one of the homologation boxes then (which would make it worth substantially more $$$)!
#10 yel327
Posted 26 February 2024 - 05:52 AM
Not quite. Early HQ commercial 6cyl M20's use a different cluster (this box's code changed to M22 once the regular M20 became available in 6cyl commercials and/or they started stamping driveline codes on the BODY ID tag). And the standard XU1 aussie M20 also used a different cluster.
#11 Bigfella237
Posted 26 February 2024 - 08:14 AM
Not quite. ~
That's why I said "bog standard"! I realise there are odd versions here 'n there that don't use that cluster, but the vast majority of Aussie M20's do.
My query was mainly whether it may have originally come from an XU-1... You never know?! :driving:
