Diff orientation and control arms
23 replies to this topic
#1 kimbo
kimbo
  • 110 posts
  • Name:Kim
  • Car:LX Torana Hatch (looking 4 1)
Posted 04 May 2024 - 02:33 PM
So I had a Borgie done up with the shocking mounts moved in 10mm. Now it's in the car it almost looks as if the lower control arm mounts are not in the right spot. The diff points downward significantly to my eye. Any comments or observations welcome.Attached File  20240504_095410.jpg   77.79K   5 downloadsAttached File  20240504_091134.jpg   65.11K   5 downloadsAttached File  20240504_082633.jpg   52.86K   5 downloadsAttached File  20240504_090020.jpg   75.69K   6 downloads
Sent from my SM-G988B using Tapatalk
#2 76lxhatch
  • 7,227 posts
Posted 04 May 2024 - 05:42 PM
Measure it. Compare the pinion angle at ride height to the transmission angle and see what you have.
#3 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 May 2024 - 07:13 PM
A straight perpendicular line from the diff at ride height will be about 140 to 150mm lower than the transmission output shaft.
#4 76lxhatch
  • 7,227 posts
Posted 04 May 2024 - 07:39 PM
No, measure the angles of the pinion and the transmission. The difference in angle is the only thing that matters.
#5 neglectedtorana
neglectedtorana
  • 1,079 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 04 May 2024 - 08:03 PM
there is a Tremec app you can get and use your phone as an angle finder
think its called Tremec toolbox
#6 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 May 2024 - 08:38 PM
I get it that the angle is important when you are close. However based on the maths I did that 150mm equates to 6.8 degrees. What I am dealing with here is a diff that wasn't fabricated correctly. I have to work out my plan of action going forward.
#7 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 May 2024 - 08:49 PM
Unfortunately I need to have a driveshaft for that app to work. I don't want to order my driveshaft until I can get this roughly right.
#8 76lxhatch
  • 7,227 posts
Posted 04 May 2024 - 09:54 PM
It may or may not be right but you still haven't measured it yet. Forget about everything else, you need the difference in angle between the pinion and the transmission - if you have a digital angle finder, simply zero it on one end then take the reading from the other. You don't need a driveshaft in place to measure this, just compare the diff flange to the output shaft.
#9 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 May 2024 - 10:18 PM
Yep ...7 degrees is the difference at anticipated ride height
#10 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 May 2024 - 10:31 PM
The picture shows how I worked it out using straight edges and squares.Attached File  20240504_202856.jpg   49.57K   6 downloads
#11 rexy
rexy
  • 3,788 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 05 May 2024 - 12:07 AM
Adjustable arms should give you what you need.
#12 RallyRed
RallyRed
  • 8,252 posts
  • Car:LC GTR etc
Posted 05 May 2024 - 08:43 AM
Worth putting the axles and wheels on and re measuring it at real world angle?  i.e. may be a little different.( better/worse)
p.s. I think you can get concentric bushes for this?  not sure, but they do something like this for track cars to keep the angle to a minimum. Helps uni joints last.
#13 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 05 May 2024 - 12:48 PM
Coming to the realisation that I might need a new diff. Pictures are left vs rightAttached File  20240505_093922.jpg   65.46K   4 downloadsAttached File  20240505_093908.jpg   60.37K   4 downloads
#14 RallyRed
RallyRed
  • 8,252 posts
  • Car:LC GTR etc
Posted 05 May 2024 - 01:33 PM
Yikes!
#15 bat 53
bat 53
  • 525 posts
  • Name:albert
  • Car:lc gtr
Posted 05 May 2024 - 07:38 PM
which butcher did that
give it back to who done it and get them to fix it
sorry but if people spend good money to get things done
shoudn't have to except that
#16 Shiney005
Shiney005
  • 9,970 posts
  • Name:Laurie
Posted 06 May 2024 - 10:14 AM
Wow. Name and shame Kimbo.  I need to get one built in Perth soon.
#17 LJ RB30
LJ RB30
  • 1,051 posts
  • Name:Trevor
Posted 06 May 2024 - 02:04 PM
Ouch! That’s crap.
#18 neglectedtorana
neglectedtorana
  • 1,079 posts
  • Name:Tom
Posted 07 May 2024 - 08:01 PM
Have you checked your control arms are equal length, just in case they have worn over the last 45 years
#19 Heath
Posted 08 May 2024 - 08:52 AM
So they haven't clocked the flanges to line up with each other on the diff housing. Is there any recourse available?
If you have adjustable arms, you should be able to put it together so that the pinion points the right way, but one of your brake calipers won't be clocked up exactly the same way as the other (not that anyone else will notice).
#20 Dr Terry
Dr Terry
  • 3,354 posts
Posted 08 May 2024 - 09:48 AM
It's not just "not that anyone will notice it", it's also that the handbrake cable may or may not reach or sit properly.
Dr Terry
#21 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 08 May 2024 - 10:01 AM
Dr Terry
I am going through the process of trying to get a new diff. I have also ordered McDonald Bros Lower trailing arms just in case. I will also know that the brakes are on the piss even if the hand brake works fine :-(
#22 4dabush
4dabush
  • 236 posts
  • Name:Adam
  • Car:73 LJ S
Posted 08 May 2024 - 09:11 PM
And if they F…d that up, would you trust that the tubes are square to the pinion, or the welds are any good? I reckon Kimbo is on the right track trying to get recourse.
Kimba, it’s the adjustable upper control arms you’ll need to adjust pinion angle. If you are buying lowers, you are half way there!
#23 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 13 May 2024 - 07:35 PM
The update is that they are going to send me a new housing
#24 LJ RB30
LJ RB30
  • 1,051 posts
  • Name:Trevor
Posted 13 May 2024 - 11:05 PM
