TowPoints on LX
6 replies to this topic
#1 SmacT
  • 1,026 posts
Posted 29 July 2024 - 12:36 PM
Hey all,
With thoughts of the odd Roll Race entering my head, how and where have people attached tow points to their LH/LX/UCs? I am thinking I can mount tow points on the front cross member and rear chassis respectively, but any guidance would be appreciated. Bear in mind it's a flared road car, so wanting to be discreet and avoid tearing off bodywork if used.
#2 yel327
Posted 29 July 2024 - 03:10 PM
Do they need to be proper CAMS sanctioned tow points? Whatever that means!
I was thinking something like those red things that hang out the front of 4x4. Just Google "rated tow points" and you'll see what I mean. They aren't very big things, but they do bolt to a chassis which is something a Torana doesn't really have, but if you made them right you could have them sticking out the front through the front spoiler brake duct holes. The problem is going to be where there is enough strength in the front of a Torana to attach them to, you'd potentially have to go back to the crossmember as you said. At the rear you'd probably be able to look at how an old LH-LX towbar attaches and use that area of the car, but again it's all cheese on a Torana compared to bigger cars.
#3 Shiney005
Posted 30 July 2024 - 09:07 AM
The fabric ones are easy to cable tie up and out of the way until they are needed.
Or do as a lot of modern cars do and have a long eye bolt that screws into a welded on nut.
https://www.gmh-tora...k-towing-point/
Attached File  Screenshot 2024-07-30 070605ssssssss.png   258.06K   4 downloads
Attached File  s-l1600.jpg   52.04K   4 downloads
Attached File  Screenshot 2024-07-30 065436.png   809.55K   4 downloads
#4 yel327
Posted 30 July 2024 - 09:21 AM
What would you attach those eye bolts to Laurie? Not much on a road going Torana front or rear with enough strength to attach it to!
#5 Shiney005
Posted 30 July 2024 - 09:55 AM
The options would be the crossmember, or bore a hole large enough for it to pass through the bumper, and have a nut welded onto the rear of the bumper bracket.   At the rear, I think a plate bolted where the tow bar normally goes as you suggested.
#6 SmacT
  • 1,026 posts
Posted 31 July 2024 - 04:47 PM
Thanks all. Bumper bracket seems the go for the front one, though not very discreet! Ha ha. Anyway, will have a think, that's all a big help.
#7 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 08 September 2024 - 12:00 PM
Hi guy's,
one a bolt through my bumper for the tow bracket.
Attached File  IMG_1717.jpg   56.5K   3 downloads
Attached File  IMG_1718.jpg   66.03K   2 downloads
Regards Mando.
