310ci / Full Manual Trimatic / 31 Spine 9”
Terry’s LH
Started by
Terry Marsh
, Aug 04 2024 10:36 AM
3 replies to this topic
#1
Posted 04 August 2024 - 10:36 AM
After 8 x Months of Hard Work I’m starting to get somewhere.
#2
Posted 04 August 2024 - 02:18 PM
C'mon bro got to give more specs than that as there are a few v8 tragics left on here that will know what you're talking about...
Could be a stroked out 253 for all we know & yes there are a few if you're on pro holdenv8 fb page.
1/8th times look good for mid 10's so it's got more in it
#3
Posted 04 August 2024 - 03:44 PM
I haven't seen a Pro Scoop for a while.
#4
Posted 07 August 2024 - 08:52 AM
Engine is 308 - 20 thou over - std 308 Crank with M&W 4xBolt Conversion / H-Beam Rods with SRP Pistons / CNC Ported Cast Iron VN Heads / Crane Cam / Yellow Terra 7/16 Stud Mounted Roller Rockers / Edelbrock High-Rise Single Plane Manifold / 25 year old Hybrid 850 Base 650 Body Holley Carb / MSD 6AL + MSD Distributor / Custom 1 3/4 “ Tri-y Extractors / 5500rpm Dominator Hi-Stall Convertor / Highly Modified Full Manual Trimatic.
Running std 98 Octane Pump Fuel.
Hoping to eventually run 10.5 - 10.6
